OGDAK's ZJ moving 12/04/2022 - Page 16
Page 16 of 19 FirstFirst ... 678910111213141516171819 LastLast
Results 376 to 400 of 462
  1. #376 Re: OGDAK's bead-locks 12/07/2009
    Quote Originally Posted by mr. brass View Post
    I love this thread. I want to move over there just to hang out with you, haha.
    Thanks you're welcome, got some beers in the fridge.
    Quote Originally Posted by ogdak View Post
    W'll see what is left of that tomorrow.
    The first day it dropped less then 2 psi, now 4 days later it is still at about 18 psi. I think I'll continue on the other 4 rims next week.
  2. #377 Re: OGDAK's bead-locks 12/07/2009
    Slovenija
    This is the best thread I`ve seen in a long time. Looking forward to see what will happened next
    Now I know what will do to my 97 ZJ
    I also see that you have some axles that you don`t need. Are they for sale?
    What is the price for pair?
    My buddies drives trucks in your country so shipping will not be that much of a problem
    Best regards from Slovenija
  3. #378 Re: OGDAK's bead-locks 12/07/2009
    Thanks,
    As for the axles, If you mean the D44/9" axles.
    They have already been sold.
  4. #379 Re: OGDAK's bead-locks 12/07/2009
    Slovenija
    Yes, this axels I have in mind. So search continuous…
    Where did you order JJ for long arms and which rubber bushing did you use on other side? Any problems with them?
  5. #380 Re: OGDAK's bead-locks 12/07/2009
    Quote Originally Posted by OrangePower View Post
    I used currie's Johnny Joint's ordered them through jks at the time. For bushings just went with the oem mopar bushings from the local stealer.
  6. #381 Re: OGDAK's CO length 12/30/2009
    Recieved a request for my control arm lengths.
    So still had a picture I took off the whiteboard when dealing with that.
    In black are the numbers I grabbed from this board, green is the same as black but in metric units.
    Red is what I ended up with in my built.
    Cause the arms are threaded on one end, they can be length adjusted +/- 2.5 cm(1")
    The tube diameter I used is 55mm(2")
    Hope it helps.
    The arms will be cut up somewhere next year for the 60/10.25 build.
  7. #382 Re: OGDAK's bead-lock's 01/17/2010
    Took it apart anyway, to apply self vulvcanizing tape to the contact space.
    Put it back together and air'd up to about 20 psi.
    Well it's been over a month, it dropped only 1 psi.
    So time to start on the other 4 and get rid off them.
  8. #383 Re: OGDAK's kicking the 8.8 06/15/2010
    Still up for sale
    Haven't done anything with the zj in a long time.
    Cleaned it out, started to look like a warehouse.
    Ripped the floor, just in front off the rear seats due to flexing.
    First off all taking the 8.8 out.
    Emergencybrake, brakeline, airline and breather taken off.
    Parts to go.
    Only 4 bolts holding it in
  9. #384 Re: OGDAK's kicking the 8.8 06/15/2010
    Member leeanderthal's Avatar
    Jul 2008
    Benton Harbor, Michigan, United States
    Is that a similac can? Whats that for?
  10. #385 Re: OGDAK's kicking the 8.8 06/15/2010
    Quote Originally Posted by leeanderthal View Post
    To catch dripping brake fluid.
  11. #386 Re: OGDAK's kicking the 8.8 06/15/2010
    Member delawhere's Avatar
    Aug 2005
    newark delaware
    i think it adds like another 100hp
    98 5.9L Clayton long arm locked armored. ready to rock&roll
  12. #387 Re: OGDAK's kicking the 8.8 06/15/2010
    Quote Originally Posted by delawhere View Post
    That much, was aming for 15
  13. #388 Re: OGDAK's kicking the 8.8 06/15/2010
    Jul 2008
    Right on, use what ya got.
  14. #389 Re: OGDAK's kicking the 8.8 06/15/2010
    Control arm's wil be reused after getting them longer.
    Out
    Flashback, how I started with it 5 years ago
    New axle flown in from the US
    Upper shock mounting beam taken out.
    Starting to look like a warehouse again.
    Time to empty the tank, it need to go.
    Well known fuel consumption
    Warning light still working.
  15. #390 Re: OGDAK's kicking the 8.8 06/15/2010
    Fueltank hoses disconnected.
    Connector and mounting brackets disconnected.
    Completly removed.
    Space.
    Time to take the front out.
    2 Bolts left.
    there it is.
    The custom CA will be reused.
    Back to the rear, mock-up of the 10.25
    As a starting point, pushed the axle 3" back
    This isn't ride hight, axle have to come up higher.
    The width with these 35*12.5 tires isn't too bad.
  16. #391 Re: OGDAK's kicking the 8.8 06/15/2010
    Started a "tire" template, so I can reduce on guessing numbers
    Only a tire thread "print" is missing.
    CA's back in, the lowers I just extended 1" by turning them out.
    Good thing they are adjustable.
    The uppers will be rebuilt to an A-frame, like in a wj.
  17. #392 Re: OGDAK's more 10.25 mock-up 06/26/2010
    Senior Member IndyZJ's Avatar
    Indianapolis
    If you are going to go with a wishbone setup, make sure orient the bolt through the axle side of the wishbone vertically to avoid destroying joints with side loads. I would also suggest a stronger joint such as a 1.25" chromoly heim joint with high misalignment spacers for a 3/4" bolt or even one of the newer Ballistic Fab rebuildable heims of the same size.
    re: testy
    scrotum.
  18. #393 Re: OGDAK's more 10.25 mock-up 06/26/2010
    Thanks Indy for pointing that out.
    Was going to set it up vertically, just haven't thought about upgrading the joint.
    Might as well do that and save the jj's which are now still in good condition.
    Anybody who has a link in their favorite's with hiem joint comparison info, please post.
  19. #394 Re: OGDAK's more 10.25 mock-up 06/26/2010
    Senior Member Lifetime Supporter 5.9 ANDY's Avatar
    southern afganistan
    wtf at the boarded up tire?????
    proud Lance Corporal in the Unted States Marine Corps.
    This website is bad for the health of your vehicles, enjoy your stay
  20. #395 Re: OGDAK's more 10.25 mock-up 06/26/2010
    Indianapolis
    Since you basically have 1 joint keeping the axle from moving side to side, I would stay away from a joint with any "give" to it, such as johny joints and the like, as I would think it would wear a lot faster in that setup.
    I would go with the Ballistic rebuildable heim with 3/4" ball:
    http://www.ballisticfabrication.com/...41_p_1655.html
    Just make sure you ask about the backorder first, then call again when they say they're going to be ready to make sure they actually ship them out to you. They have good parts, but their customer is historically lacking.
    Or the standard Ruffstuff chromoly 1.25" shank heim with their stainless high misalignment spacers for a 3/4" bolt. I would order 2 heims at once in case it devolops play so you don't have to wait on another. It also never hurts to have a spare. Multiple King of the Hammers buggies have run these for multiple seasons.
    http://www.ruffstuffspecialties.com/...8a1acaca621961
    with 2 of these:
    I would also suggest these for either joint:
    http://www.sealsit.com/rodendboots.asp
    because rod ends do not generally like the mud, grit, etc. that it looks like you wheel in.
    re: testy
    scrotum.
  21. #396 Re: OGDAK's more 10.25 mock-up 06/26/2010
    Yep, that is what we have plenty off.
    I have to get out off the country to go to a pile off rocks.
    Thanks for all your input, already put out an email to ballistic.
    what about this one?
    http://www.ballisticfabrication.com/...er_p_1425.html
    thanks
  22. #397 Re: OGDAK's more 10.25 mock-up 06/26/2010
    Indianapolis
    I'm sure they are good, but I have never heard or read a complaint about the Ruffstuff heims. I have bought a couple 7/8" heims from them along with the stainless steel misalignment spacers and they are top notch in quality. It doesn't hurt that they are a sponser here and have a 10% discount code (MALLCRAWL, I believe). As long as they ship internationally, I would save a few bucks and go with them. I've orderd a few times through them and they have always had excellent customer service and shipping times.
    re: testy
    scrotum.
  23. #398 Re: OGDAK's more 10.25 mock-up 06/26/2010
    So much for "customer support"
    Ruffstuff: never even responded to my email.
    Ballistic: They email'd me a S&H quote. After that when I mailed I wanted to order, they never mailed me back for my details.
    Guess I'll take another route.
    As far for build progress, just been making cad drawings for brackets, truss and wheel centers.
  24. #399 Re: OGDAK's more 10.25 mock-up 06/26/2010
    Got the orders from both ruffstuff and ballistic on the move, w'll see how long it will take.
    Started collecting parts for the brakedrum conversion
    Rotor's from a '96 E350, over 30 cm in diameter.
    Perfect fit on a '85 sterling 10.25 axle.
    Front caliper from GM '73-'87 3/4 Ton 4x4.
    Brackets are on it's way.
  25. #400 Re: OGDAK's kicking the 8.8 06/15/2010
    Care to explain what you mean by this? I'm not really understanding the reason to make a template of your tire.
There are currently 18 users browsing this thread. (0 members and 18 guests)
