OGDAK's ZJ moving 12/04/2022 - Page 14
Page 14 of 19 FirstFirst ... 45678910111213141516171819 LastLast
Results 326 to 350 of 462
  1. #326 Re: OGDAK's 9" truss 02/01/2009
    @KDUB & jborushko, thanks
    Due to the fact that my sons soccergame was canceled this morning,
    I got the change to go pick up the bead_locks
    Sharp
    The inner bead-lock on the rim.
    Detail
    The outer bead_lock on the tire.
    Need the check out the fuctional difference for the smaller vs bigger washers.
    The bigger ones sure look better
    Preping, I think this is the first time I put a wire wheel to something brandnew.
    Amazing what a jeep can do to you.
    Whit washers M6 centered and made a clamp to fixate.
    To avoid warpage made 2 by 2 welds.
    Didn't have much practice on the tig, but these are the first to stay.
    So made a start, 5 to go.
  2. #327 Re: OGDAK's 9" started on the Bead_Locks 02/07/2009
    Senior Member SOLITUDE's Avatar
    Brunswick, GA 31523
    nice work. Where'd you order the bead-locks from?
    1993 Jeep ZJ V8 5.2
    HP44/9", 4.88's, Detroit, OX, Clayton's, ALL IN PROGRESS
    LINK TO MY PAGE
  3. #328 Re: OGDAK's 9" started on the Bead_Locks 02/07/2009
    Quote Originally Posted by SOLITUDE View Post
    Thnx, after finishing the drawing, a friend had them cut at a fab. shop he works with.
  4. #329 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    maryland
    I really liked how that truss turned out. If I had time and a plasma cutter i think I definitly would of tried to copy that. On the slider it would be kind of interesting to weld steel at a angle to create almost a boat side with it. I know it would suck for trying to get a high lift on it, but it would definitly slide along the rocks.
  5. #330 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    Just read this thread start to finish, AWESOME!
    Your attention to detail and the patience you possess is inspiring.
    Keep up the good work.
    Neil R.
    Funniest thread on MC
  6. #331 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    Quote Originally Posted by slim616 View Post
    Since i'm planning to replace the doors for tube, I think it will work to get a high-lift on. I'll measure later
    Quote Originally Posted by fortCollinsZJ View Post
    Thanks
  7. #332 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    Quote Originally Posted by ogdak View Post
    I'll measure later
    never did, so today I just put the jack to it.
    Besides that I have not done anything to the "family car" in the past 6 months.
    The bead-locks were welded, and painted on the inside.
    Today I painted the outside the first time.
    I think the next progress posting will be less then 6 months.
  8. #333 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    Senior Member dp96zj's Avatar
    Texas
    Good!
    This build is one of my favorites, definitely my favorite off-the-continent build. The wheels look awesome!
  9. #334 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    Thanks, lol how many "off-the-continent builds" are there these day's
  10. #335 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    After putting 1 tire on the rim with a lot off force.
    For the next 4 I'll go to a tire shop.
    Started to tighten the outer with 8 bolts, but already after 2 turns it started to cone.
    The space between is 22 mm, not that weird that it cones, despite the fact that the bolt holes are only 5 mm from the edge.
    Time to make an anti coning ring, which is also gonna be a centering ring
    First attempt will be out off 22 mm MDF
    First round.
    After 4 rounds, I'm through.
    Perfect fit.
    Making 5 off them, saves a lott of time dialing in the mill.
    2 more for the outer diameter.
    When this fails, next try will be with PE.
  11. #336 Re: OGDAK's More Bead_Locks 09/02/2009
    Lookin' good.
    It's always something isn't it.
  12. #337 Re: OGDAK's More Bead_Locks 09/02/2009
    Wait, so why are you using MDF on your wheels? Just a template I hope, that mdf is going to disintegrate when it gets wet.
  13. #338 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    Why MDF? cause it's easy to work with, off coarse it will be well painted.
  14. #339 Re: OGDAK's Started on the Bead_Locks 02/07/2009
    In that case you may want to coat it with some epoxy formulated for immersion.
  15. #340 Re: OGDAK's More Bead_Locks 09/02/2009
    Nov 2004
    That's what I was thinking. Does the anti-coning ring have to have any "give" to it? Why not make it out of a narrow strip of steel just thinner than the bead of the tire, bent into a hoop and welded to the inner radius of the inner ring?
    Poetry in commotion.
  16. #341 Re: OGDAK's More Bead_Locks 09/02/2009
    The reason why I want to go for the rings over the steel strip thing is that the will help to center the tire on the rim on the bead_lock side.
  17. #342 Re: OGDAK's More Bead_Locks 09/02/2009
    @ ATL ZJ, you got me thinking, so it's a template after all.
    Time to copy 32 to holes, clamped
    drilled,
    milled the inner radius.
    nice fit
    almost flat
    After looking in how to make this durable for outside use, suitable paints are quite expensive
    picked up something else.
    20mm trespa
  18. #343 Re: OGDAK's More Bead_Locks 09/02/2009
    First one milled, took about 7 or 8 round's
    Outer on to match the 32 holes.
    Half way round, needed to sharpen the new HSS12CO drill
    All 32 done.
    Next milling round,
    done.
    Nice fit, centered with for pieces of M12 thread.
    Enough room for the 90 degree valve.
    Tightented with 8 bolts/nuts, got enough pressure to seat the tire on the inside off the rim.
    About time to order a big bag off bolts, nuts and rings.
  19. #344 Re: OGDAK's Bead-Locks 09/17/2009
    Awesome. Looks like a much better material for the application.
  20. #345 Re: OGDAK's Bead-Locks 09/17/2009
    Nov 2004
    Ditto. Hopefully you didn't make all 4 (or 5) out of the MDF before you changed your mind.
  21. #346 Re: OGDAK's Bead-Locks 09/17/2009
    Just completd 1, the other 4 only the outer diameter.
  22. #347 Re: OGDAK's Bead-Locks 09/17/2009
    So something else, found something on the intenet.
    Went for a ride today to come back with this
    Rearaxle
    Frontaxle
    Took a while to get it in the shop.
    King-pin knuckle and dual calipers.
    Lock-outs
    Also wheels/tires, already bought these kind off rims about 5 years ago.
    Then they were 15*7 5*4.5 these are 16.5*10 8 lug
    Taking a peek, looks good
    Limited Slip
    27 spline Dana35 C-clip,
    30 spline 9"
    35 spline 10.25"
    Full-floater part.
    Firts remove all the parts, then on with the real work.
  23. #348 Re: OGDAK's Axles 10/15/2009
    Austin, TX
    So now you have a pair of mogs, D44/9, and now a D60/Sterling 10.25... care to send me the pair of mogs?
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  24. #349 Re: OGDAK's Axles 10/15/2009
    Houston, TX
    haha shipping might be a little expensive!
  25. #350 Re: OGDAK's Axles 10/15/2009
    Axles enough. I'll hang on to the mogs,
    still want to do something with them on a real chassis car.
    As for the D44/9 combo's, looks like it's time to let those go, have 2 pair off them.
There are currently 9 users browsing this thread. (0 members and 9 guests)
