OGDAK's ZJ moving 12/04/2022 - Page 8
Page 8 of 19 FirstFirst 123456789101112131415161718 ... LastLast
Results 176 to 200 of 462
  1. #176 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Quote Originally Posted by Firestarter
    great build mate. looks like it's all coming together.
    whats your exhaust setup like? i saw that you used a random tech cat and stock manifolds (i think), but didn't see the muffler. sounds like either a small magnaflow, a bullet muffler, or maybe a glasspack. regardless, sounds great.
    Thnx
    All correct, as for the muffler it is home made by Mav ©
    There are a few pic's here in this thread.
    and some more
  2. #177 Re: Ogdak's ZJ - V8 testing 07/01/2006
    What have we done lately, well not much.
    After all it is my vacation
    Earlier this month I "lifted" the hood
    Used squarre tube for this 40*40*2 220 long, all millimetrs
    Also started on a pair off mini ramps, to help fine-tuning the "flex" later on.
    Used corner 30*30*3 and bar 40*5(all millimeters again)
    Tested by Beest, watch the Mallcrawlin.com sticker.
    After some minor adjustments, the final result.
    Because there will be some extra switches and warning lights, I´m gonna adjust the center console a little.
    First in wood, to get some idea´s
    Something like this.
    The passenger side out off 1mm stainless steel.
    In place including the top side.
    After ´bending´ the top piece it will be something like this.
    in the "project".
    That´s right it was hot in the garage today, just a little over 100 Fahrenheit.
    First attribute in place, winch control lock.
    You never know with small and big children in a jeep toy.
    Have a nice vacation.
  3. #178 Re: Ogdak's ZJ - Iron work 07/20/2006
    Center console looks trick.
  4. #179 Re: Ogdak's ZJ - Iron work 07/20/2006
    Sorry Dirk, but I don't understand what you mean to say.
  5. #180 Re: Ogdak's ZJ - Iron work 07/20/2006
    He means it looks bad ass!
    Might I add, your whole ZJ progression looks "trick".
    Nice work.
  6. #181 Re: Ogdak's ZJ - Iron work 07/20/2006
    thanks, learning slang every day.
  7. #182 Re: Ogdak's ZJ - Iron work 07/20/2006
    Jun 2005
    Paradise, Newfoundland Canada
    Very nice center console, I like it.
    Anthony
  8. #183 Re: Ogdak's ZJ - Iron work 07/20/2006
    Junior Member Beest's Avatar
    Apr 2005
    The netherlands
    I want a update.......
  9. #184 Re: Ogdak's ZJ - Iron work 07/20/2006
    Quote Originally Posted by Beest
    Ja ja,
    nice avatar btw.
  10. #185 Re: Ogdak's ZJ - Iron work 07/20/2006
    So it has been a while, but have done some minor things.
    A month ago I was working on the center console, let's proceed.
    Made 2 incab whinch control switches
    Major thing however this week was, DS's are done.
    I couldn't resist so last night I drove it on it's own engine power.
    4 feet backwards and 2 feet up.
    In 2 wheel drive, since the front pumpkin is still empty.
    Don't mind my big smile.
    Next update will be quicker, I think.
  11. #186 Re: Ogdak's ZJ - Iron work 07/20/2006
    Jun 2005
    Awesome man.
    Close and Closer to being finished.
    Anthony
  12. #187 Re: Ogdak's ZJ - Poser shots 08/13/2006
    Senior Member nate's Avatar
    Palmer, AK
    I need to built some ramps like that so I can sit under low cars when I'm working on them... wonder if I would built 4... it'd be like a homebuilt lift kinda sorta
    03 Subaru WRX
    98 Dodge Ram 2500 CTD
    98 Jeep ZJ
    95 Dodge Ram 3500 CTD
  13. #188 Re: Ogdak's ZJ - Poser shots 08/13/2006
    I've got some 8" high plastic ones I got at Pep Boys. They work fine when trying to get a drive axle up, but not so hot on non-drive axles. I was trying to pull the ZJ up onto them once after blowing up the front d-shaft and part of the t-case, only had RWD. The fronts kept pushing the ramps, they wouldnt stay put, so I was trying to really ease the ZJ up them. Somehow or another I ended up shooting the rear ramps out from underneath the Jeep, out of the garage (door was open), and into the street. It was pretty badass.
  14. #189 Re: Ogdak's ZJ - Poser shots 08/13/2006
    Senior Member 2jeepsforus's Avatar
    Sep 2005
    Smethport, PA
    Why didn't you just block them with a cinder block or something that was somewhat heavy. I would hope that you figured that out soon there after
    1998 5.9, 5.5" Front/ 4.5" Rear (RE), 33/12.50's Trxus MT's, ARB Bumper w/Warn 9500HS, 231HD...SOLD...Stupid Divorce!!
    Quote Originally Posted by canadian_driver View Post
    start giving teachers guns... or tazers.... or clubs or just a 2x4 with a nail in it
  15. #190 Re: Ogdak's ZJ - Poser shots 08/13/2006
    Jan 2006
    Raleigh, NC
    Or jack it up and set them under the wheels?
  16. #191 Re: Ogdak's ZJ - Poser shots 08/13/2006
    They won't work well for low cars since the ramp is 38 degrees up.
    They are only 4 ft long and 2 ft high approx.
    Made just a pair for fine tuning on the suspension, seems to work out pretty wel.
  17. #192 Re: Ogdak's ZJ - Poser shots 08/13/2006
    Quick enough?
    Obvious had to try the front on the ramp also.
    Got the ramp fixed too the ground to avoid it shooting away, so still in 2 wheel drive.
    By the way, I'm a little over 6 ft, standing eye to eye with my left headlamp
    Enough travel on the rear shocks
    Coils are doing better then exspected
    Little dusty
    Detail
    The hydro assist still fit
    All for now
  18. #193 Re: Ogdak's ZJ - Iron work 07/20/2006
    Quote Originally Posted by ILikeMud
    Awesome man.
    Jup, it's about time.
    It is almost about two years since I drove it on/off - road.
  19. #194 Re: Ogdak's ZJ - More poser shots 08/13/2006
    Senior Member cashflowdub's Avatar
    alex bay
    this is about the sickest BUILD EVER I WANT MORE
    95 Zj on 32s
  20. #195 Re: Ogdak's ZJ - Iron work 07/20/2006
    Jun 2005
    Quote Originally Posted by ogdak
    Wow, bet you can`t wait till it`s finished.
    Anthony
  21. #196 Re: Ogdak's ZJ - Iron work 07/20/2006
    Guess one off the biggests lessons on this project is, to have all(or a lot) off the needed parts in storage before taking things a part.
    So the actual build time will be a lot shorter.
  22. #197 Re: Ogdak's ZJ - Iron work 07/20/2006
    Jun 2005
    I hear you but at the same time, gather parts can be a pain too. I've been gathering parts for my trans swap since Feb of this year.
    Did you buy most your parts from the US or a mix?
    Anthony
  23. #198 Re: Ogdak's ZJ - More poser shots 08/13/2006
    Senior Member violatedppl's Avatar
    Aug 2005
    Danville CA
    I still think that is the most badass rear bumper Ive seen on a ZJ.
    08 tundra double cab 5.7 4x4
    I am jeepless at the moment.
    Sold- Stock 03 WJ, 4.7HO. lift coming soon.
    Sold-97 ZJ laredo 4.0, 242 RE BB, 31" BFG MTs, custom rear storage boxs, magnaflow hi flow cat, flow 70 series, 2.5 inch exhaust, jks quicker discos and some other crap
    http://www.cardomain.com/ride/2221028
  24. #199 Re: Ogdak's ZJ - More poser shots 08/13/2006
    steel, tires, e-fan and the Xj D30 are bought local.
    probably forgetting som small parts.
    Quote Originally Posted by violatedppl
    x2
    Thanx, Sjikita did the drawing and manufacturing off it.
  25. #200 Re: Ogdak's ZJ - More poser shots 08/13/2006
    Jun 2005
    What tires are those anyhow? Maxxis?
    Anthony
There are currently 14 users browsing this thread. (0 members and 14 guests)
