GSSE Checklist
Thread: GSSE Checklist
Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
  1. #1 GSSE Checklist
    - Pick Jeep up from shop with a new tranny
    - Wire up the full gamut of lights
    - New trailer tires
    Nothing too crazy, so hopefully I won't be scrambling last minute to get ready, but I'm sure something will crop up. I have 1 (possibly 2) local wheeling trips planned before GSSE. They should be "easy" trips, so I figure anything I break on those trips would have broken in Harlan -- just filtering out the weak links!
    Test
  2. #2 Re: GSSE Checklist
    rebuild front shock- check
    gusset front upper link mounts- check
    brace driver side airbump pad- check
    swap axles under trailer- check
    wire horn- check
    complete front firewall- pretty ambitious, can wait
    drain front diff and retorque ring gear bolts- check
    install speakers and amp
    install PVC ring inside H1 lock- check
    mount second fire extinguisher- can wait
    install front limit straps- check
    lube driveshafts- check
    cut out hole in skid for oil changes- can wait
    buy bailey a new solenoid- who are we kidding, bailey doesn't wheel
    build new rear upper link mounts- check
    nut and bolt everything... twice- check and check
    yes, I still keep a spreadsheet
  3. #3 Re: GSSE Checklist
  4. #4 Re: GSSE Checklist
    Quote Originally Posted by paulkeith View Post
    believe it or not, that was just a copy paste
    not intended to be a hint
  5. #5 Re: GSSE Checklist
    Jul 2008
    North Carolina
    Well one thing is crossed off my list...
    Picked up this baby this weekend
  6. #6 Re: GSSE Checklist
    Quote Originally Posted by BigClay View Post
    You have no idea how jealous I am.
    But I'll be interested to hear how that tahoe does in the hills around harlan!
  7. #7 Re: GSSE Checklist
    Member S-10 Seanzy's Avatar
    Aug 2006
    Bristol, TN
    Did you get a chance to talk to FOA? Was this the reason that the coilovers took a shit?
  8. #8 Re: GSSE Checklist
    Quote Originally Posted by S-10 Seanzy View Post
    no I don't think FOA would really give a shit anyway. I've been using my semi-tight winch rope as a front limit strap and it took a toll on my fairlead mount. I straightened and braced that up last night but I need regular limit straps too. Gonna take the shocks apart probably this weekend and see what's up.
    and damn I knew I had stuff missing from that list...
  9. #9 Re: GSSE Checklist
    Midlothian Virginia
    Finish truss
    install coil over mounts
    install coil overs
    flex test to see what hits and how the spring rates are
    fix engine
    Uber one Ton ZJ Tech
    PSC Full Hydro Tech for ZJ
  10. #10 Re: GSSE Checklist
    Jul 2008
    North Carolina
    You were actually the inspiration for me going with a new trailer vs a used one, figured it was safest to go with new. As for the Tahoe, I know it will be no speed demon, but hopefully other than that it will be OK.
  11. #11 Re: GSSE Checklist
    Sep 2006
    Cleveland, MS
    Just make sure you check your trans often. If you going to have an issue, that would probably be it. You don't need a turbo diesel power to tow a grand. It is a bonus for sure, but I think your Tahoe will be fine power wise.
    As for my checklist:
    - replace all my bushings in the long arms and tracbar.
    - lower it down about 2" front and rear
    - replace the bulbs in my gay assed ProComp 130's
    - move the welder, generator, air compressor on to the gooseneck
    - finish my skidplate
    - pack my spares and tools in the jeep
    I'm still waiting on the inexpensive shit to break!!!
    '02 WJ with 60's, locked, full hydo, ORI's, on 40's, and still have air conditioning!
  12. #12 Re: GSSE Checklist
    Trans temp gauge and a aux cooler might be your best friend. Heat is the killer.
  13. #13 Re: GSSE Checklist
    Jul 2008
    North Carolina
    Quote Originally Posted by indy242003 View Post
    Thanks guys. I have a stock tranny cooler on it right now, but I have a bigger new one I am going to install before GSSE. I am also going to change the tranny fluid and install a tranny temp guage.
  14. #14 Re: GSSE Checklist
    Midlothian Virginia
    The guy who towed me to bigdogs is 98% sure he has off work that weekend.
    Looks like I need to get cranking on this shit!
  15. #15 Re: GSSE Checklist
    Jul 2008
    North Carolina
    On my to do list in Harlan, not be the second in Kentucky history
    http://news.yahoo.com/s/ap/20100629/...us_bear_attack
  16. #16 Re: GSSE Checklist
    maryland
    Been working on my list for a few weeks now and seems to keep getting longer
    -new bearings in pass. hub (torn down needs reinstalled)
    -fix leaky front diff (torn down and waiting on lube lockers)
    -new track bar mount (work in progress)
    -replace front output seal on xfer case
    -extend front CA's an 1"
    -fix Driver side bump stop
    -raise pass seat
    -fix rear gate
    -new tube doors with skins to keep mud out
    -fix slow leak with one beadlock
    -vac 20# of dirt out of jeep
    - drill and tap rear bumper to get up and down play out of it
    -rear tube fenders
    -fix OBA
    -double check all bolts
    -also I would like to install tranny and hydro temp gauges.
    A few things on there on necessary but I would like to have them finished in time.
    Also how the rain been down there, is it muddy or dry?
    93ish zj, d60s, 38.5 maxxis, and a bunch of other expensive parts to make them work.
    Truck stacks, for when your trucks nuts are just not gay enough anymore.
  17. #17 Re: GSSE Checklist
    Quote Originally Posted by slim616 View Post
    -raise pass seat
    -fix rear gate
    -rear tube fenders
    -fix OBA
    When we were there a couple weeks ago it was a little less slick than it was last year at GSSE. It rained a lot the week before we went but it wasn't the slickest I've ever seen it. Of course there is still plenty of time for the place to dry out or get completely soaked between now and then...
  18. #18 Re: GSSE Checklist
    Senior Member zjeepin's Avatar
    May 2005
    Boone NC
    our little nook of the smokies has been really dry for the last month or so but like cam said there is plenty of time for that to change.. the last 2 times i've been at harlan its been dry, personally i think a slopfest is in order
  19. #19 Re: GSSE Checklist
    Aug 2006
    Bristol, TN
    My to do list...
    Fix Will's shit for him...
  20. #20 Re: GSSE Checklist
    My to do list...
    completely rebuild Will's shit for him...
    upload June Harlan vids
    fixed
  21. #21 Re: GSSE Checklist
    maryland
    we did the slop fest last year, i'm hoping for a dust bowl.
  22. #22 Re: GSSE Checklist
    Apr 2008
    Tn
    Dust sucks. I'd go for a light raing in the AM to keep the dust down.
    My list-
    - plumb/install hydro assist cooler
    - trim front and rear fenders
    - add wheel well tube protection
    - get brakes working better
    - straighten lower control arm
    - add some lights
  23. #23 Re: GSSE Checklist
    May 2005
    Boone NC
    Quote Originally Posted by rstrucks View Post
    coming from the guy with a windshield and all 4 windows that roll up...
  24. #24 Re: GSSE Checklist
    Apr 2008
    Tn
    Quote Originally Posted by zjeepin View Post
    And A/C!
  25. #25 Re: GSSE Checklist
    May 2005
    Boone NC
    And A/C!
