Stage II - bigger, heavier, slower. - Page 10
Thread: Stage II - bigger, heavier, slower.
Page 10 of 10 FirstFirst 12345678910
Results 226 to 249 of 249
  1. #226 Re: Stage II - bigger, heavier, slower.
    SL,UT
    WOW. Ryan that is some damn fine work there. Not much else to be said. Jealous for sure!
    The password is newbgasm.
    www.crawlerready.com
    "For The Truly Addicted!"
  2. #227 Re: Stage II - bigger, heavier, slower.
    Jan 2010
    SLC UT
    Looks great man!
    93 ZJ long arms, 35's, F/R Long arms, 4.56 gears, and a bunch more
    98 5.9 slate gray 4" lift with stuff (sold)
    96 ZJ Lift, Long arms, 35's and a bunch of other shit! (RIP)
    [ IRONMAN 4X4 FAB ] [ RACELINE WHEELS]
  3. #228 Re: Stage II - bigger, heavier, slower.
    Staunton, VA
    Nice work! When you planning to make it back up to crozet?
  4. #229 Re: Stage II - bigger, heavier, slower.
    Apr 2008
    Tn
    Thanks guys.
    Quote Originally Posted by FortCollinsZJ View Post
    Everything looks stellar as per usual! The bolt on truss is trick! And the clearance for the upper links. Awesome stuff Ryan.
    Is it a total bitch to get to the bolt for the upper on the passenger side, due to the muffler?
    What muffler and cat are you using, those both look like the dimensions I need.
    Yeah, the bolt on truss was a PITA. I wanted to make the diff cover removeable with the truss on so that took some work and I had to redrill/tap one of the diff cover bolts and cut a hole in the truss top plate to access the bolt.
    Not sure about that top bolt - hadn't had to remove it yet. I'm pretty sure if I just remove the exhaust hanger I'll be able to get it out.
    Magnaflow high flow cat and Hushpower muffler. Sounds good...... IMO. Clearance is the reason I went with the Hushpwer over my old Flowmaster.
    Quote Originally Posted by 1fox2go View Post
    Not sure when I'll be headed up to Crozet with my Jeep again. Next time might just be riding shot-gun in Stu's MJ.
  5. #230 Re: Stage II - bigger, heavier, slower.
    Jul 2008
    North Carolina
    Quote Originally Posted by rstrucks View Post
    I just put a hushpower on mine as well, good sound and great clearance.
  6. #231 Re: Stage II - bigger, heavier, slower.
    Sick! I like how you braked the stiffener to follow the contour on the rail. Its the little things..
    2004 Ford Lightning
  7. #232 Re: Stage II - bigger, heavier, slower.
    Staunton, VA
    Cool just tell him to give us a heads up and we will hopefully have our stuff ready
  8. #233 Re: Stage II - bigger, heavier, slower.
    I dunno how I feel about the upper bracket but I am sure it will hold up. Looks good!
  9. #234 Re: Stage II - bigger, heavier, slower.
    Damn Ryan, all the new work is GREAT looking! Extremely clean and uniform, and I like how you went the extra mile for the uptravel
  10. #235 Re: Stage II - bigger, heavier, slower.
    Seattle, WA
    Haha, deffinitely a cleaner solution than my self clearancing floor boards
    I collect Jeeps.
    The Polar Bear Detailed Build
  11. #236 Re: Stage II - bigger, heavier, slower.
    Apr 2008
    Tn
    It's the little things that take all the time too. And I know you know this! Thanks man.
    Quote Originally Posted by zj95maxx View Post
    I have thought about making a skid that goes from the t-case crossmember to the mounts to strengthen everything and tie it all together. I did take a look at everything after the first time out and nothing seemed to be flexing - enough to leave any evidence anyway.
  12. #237 Re: Stage II - bigger, heavier, slower.
    Clemson, SC
    Dont even know if you still have this guy... but do you have any details/pictures on your rear bumper? I've got to start fabbing a bunch when exams are done in the next couple weeks. Looking through here for some designs and just noticed yours for the first time for some reason. Really like the smaller tucked up look it has.
    -Ronnie
    98 5.9 on 35s
  13. #238 Re: Stage II - bigger, heavier, slower.
    Pretty sure he sold it but he probably still has a lot of pics.
    2004 Ford Lightning
  14. #239 Re: Stage II - bigger, heavier, slower.
    Seattle, WA
    Steering finished. I would have mounted the tie rod higher but it would have interfered with the coils. The drag link I attached to the pass. side steering arm by welding on a heavy duty "tab". The hole for the drag link is about 6.25" from the BJ center which is about the same distance for the pitman arm center to center measurement. It works and steers well.
    Long shot, but do you know what your WMS-WMS ended up being when you converted this to a full 60? I'm collecting parts and running number for a 609 build and I think I want to hit 65" WMS.
    I collect Jeeps.
  15. #240 Re: Stage II - bigger, heavier, slower.
    Apr 2008
    Tn
    I've got a notebook in the garage with measurements in it. I should have the WMS. I'll take a look tomorrow evening.
  16. #241 Re: Stage II - bigger, heavier, slower.
    Jul 2008
    North Carolina
    Damnit, when I saw Ryan had bumped this thread, I thought "hell yeah, he is buying it back!"
  17. #242 Re: Stage II - bigger, heavier, slower.
    Seattle, WA
    I'd appreciate it. Thanks.
    I collect Jeeps.
  18. #243 Re: Stage II - bigger, heavier, slower.
    Apr 2008
    Tn
    Sorry dude, I have a bunch of measurements but no WMS-WMS. If it helps I have written down that the WMS to the weld on the inner C was just 10.25". I have a few other odd measurements as well.
    I do remember going for about 65" as well. Not sure if I nailed it though. Not much help.
  19. #244 Re: Stage II - bigger, heavier, slower.
    Seattle, WA
    Haha, no worries. That's at least the ball park I was aiming for. Just eyeballing photos of yours, it looks very similar to the silver jeep.
    I collect Jeeps.
  20. #245 Re: Stage II - bigger, heavier, slower.
    Jan 2013
    Charlotte NC
    This build is amazing , your ability to keep the look of the Jeep as clean as you did is great .. I look forward to your future work ..
    Cleveland, MS
    You may be waiting a while.
    I'm still waiting on the inexpensive shit to break!!!
    '02 WJ with 60's, locked, full hydo, ORI's, on 40's, and still have air conditioning!
    Cleveland, MS
    At least for this rig. Ryan sold this one a while back.
  23. #248 Re: Stage II - bigger, heavier, slower.
    Jan 2010
    SLC UT
    Learn to fucking search!!
    Cleveland, MS
    Quote Originally Posted by biggoofy View Post
    Yep. Or just watch Trucks on the power block.
