I'll get this year's thread rolling!
I have a set of Mopar D30 OPEN shafts as spares. Original to my Jeep. Good boots and joints. 130k miles on 'em. $75
2 sets of Mopar D44 OPEN rear shafts as spares. One pair is original to my Jeep, the other was pulled at the yard. $75 per pair.
JKS rear Adj. control arms. Less than 8kmiles on them, never off road so no scrapes, scratches or rust. I believe the will work for TJ, ZJ or WJ. They were in my WJ and I will include the JKS spacers for WJ use (really a stack of grand 8 washers). $200
Adj. front upper control Arms. Were on my Jeep when I purchased it. I believe they are from Rocky Road. TJ, ZJ, XJ, or WJ. $90
Fixed front lower WJ control arms from Rocky Road. Need new poly bushings. Were on my Jeep when purchased. $25
Rocky Road WJ A Arm spacer. On my Jeep when purchased. $45
Maybe some other stuff laying around....
Might want to also post on Facebook
Anybody need 4.10s for dana 30/35? Or Yukon shafts for 35?
Also who would be interested in a Waeco/Dometic fridge cf-18? I have a line on 2 and need only 1.
$180, you would be 2nd in line. I actually have 3 fridges right now, I have 2 18s and a 35 I am trying to figure out which one I keep. Justin has dibs on what's left.
Anyone need a ZJ? I'll bring the black one is someone wants to purchase it
I have a couple axles up for grabs!
Ford 8.8 4:10 LSD
Trussed and ready for triangulated uppers
Ballistic fab diff cover
W/disc brakes
$450 obo
96' zj hd 44a
3:73 gears open
Unbolted stock!
W/disc brakes
$250
Also have 4:10 gears for a hp d30
$50
Zj steering box brace
$25
Zj steering box
$50 obo
and a few other d30 parts
Build it. Lock it. Crawl it.
Feeler = We just swapped in a D44A into Kyle"s WJ and therefore have a WJ D35 with 3.73s for sale. Complete and in good shape minus the brakes. Let em know if hter is interest and I can bring it to GSW.
I have a WJ Dana 30 w/ 4.56s, diff cover (can't remember the brand), and JKS tie rod. Needs new everything from BJs, to tie rod ends to possible breaks. $200 obo
I have the following available:
ZJ Rubicon Express 3.5" springs, F & R (have sagged about an inch)
ZJ/XJ Rubicon Express HD front track bar and frame side mount (new axle side bushing)
Ford 8.8 axle shafts, perfect for trail spares
Dana 44 TrueTrac, for 3.92 and numerically higher gears. was used in front application. (this is the LS with the helical gears, no clutches to wear out)
Single Poly engine mount insert, can be used on 96-98 trans mounts (which is why I have only one).
Various 231 and 242 shifter bezels
ZJ specific 231 selector switch
Kevins/JKS ZJ front track bar, needs new bushings. Also the frame side mount is home made.
I'm looking for:
35's
17X8 wheels with a 5x5.5" bolt pattern
Looking for a busted WJ CV shaft. I want to use the outer only portion of along with a spare unit bearing hub for a trail fix. I will take a standard broken Dana 30 outer but prefer a WJ type so the tone ring works with my speedometer.
Might have something better you. I pulled the fake "stub" shaft from a 2wd WJ as a trail spare but don't need it any longer since I went to the 44 Front. Also have a D30 cover and spare set of Dana 30 WJ shafts if anyone is interested.
Justin,
The 2wd drive stub shaft is absolutely perfect and what I was really looking for. Thanks.
We have spare shafts for Kyle's Jeep. Mine is 30 splines with a locker so I am just looking for an emergency spare in case I break a shaft.
I will give you something for those 8.8 shafts and 231 selector bezel.
I have a stock Ford 8.8 Explorer driver's side shaft, if someone else needs an axle shaft.
You have both sides Ted? Seems like you used one of them already.
I also have a mile marker winch 8000lb elec winch brand new still in the box!
$300 obo
I have at least 2 gallons of unopened green prestone. Free for anyone who could use it.
If you could bring it I can use it!
Sure thing. Assuming you are still good for those shafts?
You bet!
Great!
