The Bumblebee build - Page 2
Thread: The Bumblebee build
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 55
  1. #26 Re: The Bumblebee build
    Mar 2011
    Lakewood, CO
    It was moved back from that photo. It is 24" from the rear of the front crossmember to the rear of the rear. I reversed the claytons stiffeners so my upper mounts will project a little forward. If they must self clear a little, so be it.
    01 WJ
  2. #27 Re: The Bumblebee build
    Looking good brudda - sorry I forgot to call you back last month....been a bit busy with work.
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  3. #28 Re: The Bumblebee build
    Mar 2011
    Lakewood, CO
    Thanks Jim.
    Trying to line up the next project while finishing this one.
    I picked up a nodular 9" case on the cheap.....only 1 bearing cap.
    Is it as simple as getting another or are they matched somehow?
    never mind above. bad memory, just missing a bolt....
    Also, even with the icky Denver weather on Sat. I managed to install and run the antenna wire for my shinny new CB radio. No more borrowing one.
    01 WJ
    Mar 2011
    Lakewood, CO
    Attachment 6749
    Attachment 6751
    Finished my rear crossmember and link mounts. Had to remove and modify the lower mounts on the rear axle so it's taking a little longer than I expected I should be done this weekend are
    Sent from my ADR6400L using Tapatalk 2
    01 WJ
  5. #30 Re: The Bumblebee build
    Senior Member IndyZJ's Avatar
    Apr 2007
    Indianapolis
    How much vertical separation do you have in the rear mounts?
    re: testy
    scrotum.
  6. #31 Re: The Bumblebee build
    Mar 2011
    Lakewood, CO
    4.75" at the frame side and 10" at the rear axle.
    01 WJ
  7. #32 Re: The Bumblebee build
    Member dyn0mitemat's Avatar
    Jun 2011
    ↑↑ This side up ↑↑
    I was curious as well, as it doesn't look anywhere near 4-5" from the pictures. If those are your numbers you should be fine
    98 ZJ - Build hd44/88, 35s, long armed, locked, blah blah blah...
    Build thread
  8. #33 Re: The Bumblebee build
    Junior Member fluxcapjr's Avatar
    Feb 2013
    denver
    I'm really liking that purty yellow paint job I did
    Mar 2011
    Lakewood, CO
    Oops. Either the z turn or the car wash.
    01 WJ
  10. #35 Re: The Bumblebee build
    Mar 2011
    Lakewood, CO
    I do believe I just got lucky.
    ARB for Dana 44 $150.00
    Lets hope it works/fits
    I will be calling ARB with the units S/N monday to verify aplication and P/N
    It looks right to me and my HP44 shaft fit in it.
    In the mean time I have to fix the design flaws in my front suspension before GSW. After 3 trails the bushings are trashed at the axle side on my lowers.
    01 WJ
    Mar 2011
    Lakewood, CO
    Lower control arm bushing after three trails in Moab. Good thing it went out and came back on a trailer. not to mention the broken drive shaft and yoke.
    Sent from my SCH-I605 using Tapatalk 2
    01 WJ
    Mar 2011
    Lakewood, CO
    01 WJ
  13. #38 Re: The Bumblebee build
    I would call that "expired". Let's hope the new mounts with better geometry, extend the next one's "life".
  14. #39 Re: The Bumblebee build
    Mar 2011
    Lakewood, CO
    A little shave
    And a little truss.
    Finally some progress on the 9.
    01 WJ
  15. #40 Re: The Bumblebee build
    Highlands Ranch, Colorado
    Looking Great.
  16. #41 Re: The Bumblebee build
    Mar 2011
    Lakewood, CO
    So things are progressing. I am now rocking a 60 up front and am in the process of cleaning up the installation, stretching, and 3 linking it.
    Sent from my XT1650 using Tapatalk
    01 WJ
  17. #42 Re: The Bumblebee build
    Member dubj's Avatar
    denver, colorado
    Any plans to reinforce that upper link mount frame side? And is there enough space between the unibody and the bracket for a nut or will you be going into the unibody?
  18. #43 Re: The Bumblebee build
    Mar 2011
    Lakewood, CO
    I sleeved the frame so a 9X5/8 gr 8 bolt will go through from the outside. The mount itself is a combo of 1/4 and 3/8 thick material and will be boxed on the back side.
    01 WJ
  19. #44 Re: The Bumblebee build
    Putting a 14 bolt in
  20. #45 Re: The Bumblebee build
    All done! Just a few loose ends.
  21. #46 Re: The Bumblebee build
    Fruita, CO
    I think it needs to go bigger... lol looking awesome man!
    Because Jeep.
  22. #47 Re: The Bumblebee build
    Looks great, Tyler!
  23. #48 Re: The Bumblebee build
    Dang, nice work. Glad you found a 14bolt that worked for you.
  24. #49 Re: The Bumblebee build
    2nd floor Yuma, AZ motel
    That fender chop is beautifully hideous.
  25. #50 Re: The Bumblebee build
    Quote Originally Posted by ELLLLLIOTTTTT View Post
    Jesus wasn't around to do his!
