I bought the PSC kit because it came with about 90% of everything you need to successfully install full hydro onto your rig.
EVERYTHING you need to install is pictured here.
The only things that do not come with this kit are a PS cooler and the 3/4" bolts/nuts/lockwashers that are installed into the steering arms. YOU NEED A COOLER.
The first thing you need to do is swap out your PS pump/res for the PSC pump.
Unbolt your PS pump by the 3 bolts that hold it on, you will need to take the belt off obviously, then rotate the pully to allow the holes to line up to get a socket onto the bolt heads. Once you remove it you need to remove the pully from the pump to put it onto the new pump.
I rented a puller tool from napa which I returned later for a full refund.
The parts you need to remove it are so.
Then apply them in this fashion around the pully.
I did not have a impact at the time, so I had to do it with wrenches, just hold the giant nut, and screw down the threaded bolt until the pully pops off.
To install the pully onto the new pump, apply the pieces like so.
Keep tightening down until the pully is fully seated like so.
Then install it back onto the jeep, routing the belt in the correct design.
Next I moved onto the steering shaft. For an extra 20 bucks you can get a steering column that will bolt right into the stock shaft, but at the time I did not know this and just got the basic 3/4" round one. To install this one you need to drill out the stock shaft using a 3/4" drill bit.
then insert the steering column into the shaft, and weld it up, be sure to weld it in sections and cover everything to make sure slag doesn't get where you don't want it.
While you have the drill bit out, go ahead and drill out the steering arms (which are currently drilled to fit a TRE) to 3/4" as well.
Here is a picture of the 3/4" hole on left, TRE hole on right. It isn't a big difference, but you need to be able to fit the 3/4" bolt into the hole.
Next we will move onto the orbital mount. I designed this little fancy bracket and then welded it on top and bottom to the frame rails. Make sure you weld it where you want the orbital, I made mine a hair further than I should, but it still works fine.
Now you are ready to mount the orbital, but before you do, make sure to install all of the fittings that came supplied to the kit before you bolt it up, because it can be a pain to get a wrench into the engine bay. You will know when they are tight because the fittings bottom out onto the orbital.
Hold the orbital with one hand, and push the steering column onto the backside until it all lines up, then thread in the 17mm bolts to securely bolt the orbital to the column. Be careful, that bitch is heavy.
Next I installed the reservoir. You want it to be the highest point in the steering setup and I opted to put it in front of the pump so that when on hill climbs and obstacles, the pump is not starving for fluid. I used some simple self tapping screws and went to town. keep in mind you want to mount it in a way that you can run lines correctly, and easily.
Bolt up the reservoir, and install the two pushlock low pressure fittings onto it.
I had to notch the hood a bit to make sure everything was fine when the hood was closed
Now we can start on the actual ram mounting. Ram placement is important because it needs to be setup correctly and in a quality location that will not interfere with anything.
There are many different ways you could design a mount. I just went off the tube that was protecting my hydro assist, and ran some 1/4" plate back to the TNT truss. I made sure this was 100% flat and about as centered as I could get.
Ideally it is easier to weld the ram 100% centered but this is not always achievable. Set the ram to where you want it, and then tack on the threaded feet and then weld them up.
you want to put something on top of them so the slag does not get into the threaded part of the bracket.
Now you can bolt up the ram. Take out the yellow plugs and install the two -6 fittings until tight. Make sure you get the ram shaft equal on both sides. My 8" throw ram allowed me to put 4 3/4" shaft showing on either side of the ram. Use a rubber mallet to push the shaft to the right length.
Make sure your steering is aligned, then cut your tie rod ends to length and weld in the inserts. Mine used the entire length of the amount of tube that PSC gave with the kit. If the ram is not centered, then one tie rod will be shorter than the other.
Thread on the clevises onto the ends of the ram shaft, making sure that the clevises are in a horizontal plane so that you will both heims in the same direction. There are shims that are included with the kit that you might have to take out or add to get the clevises to get in the direction you want. I used all shims on one side, and one shim out on the other.
Then thread the included heim joints into the tie rod ends, then bolt the links to the steering arms and the clevis. The clevis is threaded on one side, but I still added a nut to the bottom for added security.(and my kit came with the nuts) Whether or not your kit comes with the nuts is up to PSC I guess because Pat's did not come with them.
After everything is bolted up, it should look something like this.
Now onto the hose routing. PSC includes a diagram with the kit,and obviously, it needs to be followed correctly.
First I will run the hose from the Main suction port on the res, to the low pressure port on the pump. This line needs to be as short as possible, and always at a downward angle to the pump.
This is how mine is ran.
At first I ran the High pressure hose from the pump to the orbital with the included line and fitting. But then after some friends knocking sense into me, I remembered that the puslock style fitting is NOT something you want with the high pressure side of the system.
This is what happens if you use the pushlock fitting with the HP port.
I later changed it with a High pressure line and a reusable fitting that will not blow off.
To install these reusable fittings, do the following. Cut the hose to the length you want, then screw on the threaded portion onto the line. It is left handed thread.
Screw it on until it bottoms out and meets the threaded part of the fitting.
then screw on the 90* fitting until it bottoms out, or gets very close and then tweak it to get it at the right direction you want.
After getting those two lines run, I went on to mount the main lines of the ram.
The right port ram is routed like such.
The left port is mounted like such.
You want to make sure these lines have slack in them for droop and flex. It was a pain in my ass to run these lines because of the lack of room. My lines also have a protective cover on them to further protect them from rocks or anything that would want to cut the lines.
The cooler needs to be mounted BELOW the reservoir. I opted to keep my steering box brace because it is a good mount for my cooler, and stiffens up the front end a tad.
The first line I ran was from the orbital on the low pressure port, to the far side of the cooler.
Mine goes from here
snakes between the engine and fan, I zip tied it later so it will not contact anything, and into the cooler.
The other side of the cooler runs into the upper port on the reservoir.
After everything is ran, it will look like so.
Make sure everything is tight, and all the hoses are routed correctly and fill up the reservoir with your favorite brand of fluid.
cycle the wheel a few times to push the fluid into some of the lines and to work air bubbles out like so.
Then start it up and let it sit for 30 seconds.
Then let it sit for 10 min with nothing on and let more bubbles work out. Then make sure fluid is at a good level, turn it on, and cycle the steering back and forth about 15 times (with tires off ground). Repeat this until the fluid is at a constant level and no air bubbles are in the system.
Then you are done! Make sure nothing leaks and take her for a spin. You want the steering to stop itself, not the steering stops. Obviously i have some cutting of steering stops to do.
I hope this article helped. I might have done things differently than others, but it works for me. I will post a pic and a review of how it drives once I have time to take it for a spin.
Nice writeup maxxX Good info, I might be using it in about 9 or 10 years
how did the bearing hold up in the orbital to column adapter through the welding to the u-joint?
I welded on mine super carefully and in short durations and it still absolutely fubared my bearing. I should've disassembled it. oh well.
very nice write up. Out of curiosity how is the speed of turning the wheels lock to lock compared to your old set up?
http://www.discounthydraulichose.com...nps-parent.htm
Nylon Protective Sleeve 1.05" ID (NGB-0121, by the foot) $1.25 a foot
I burned it on fast, then spun it after wards and it sounded fine.
well fuck, oh well.
It honestly turns about the same. I will let you know once I test drive it.
is the power of a hydro steering system really enough to damage your axle through the steering stops?
I think you can blow/damage the seals in the ram if it hits the locks with too much pressure, but don't quote me on that.
The ram should be hitting the max stroke AT THE SAME TIME the knuckles hit the stops.
Otherwise kiss your knuckles goodbye.
Reid racing knuckles have longer than usual stops for the purpose of trimming to desired length. Mine will be trimmed down to attempt to get steering to stop itself.
Also, wouldn't allowing the cylinder to be the travel limiter put the cylinder at risk of being damaged? Say you got the tire wedged in a rock and momentum/gravity/weight of the vehicle was twisting the tire and the knuckle trying to overextend the cylinder? I don't know the answer and have never witnessed this happening, anybody else?
EDIT; after thinking for a second, I guess all hydraulic cylinders stop themselves when you reach the travel limit. Internal stops?
Guess who didn't take the hydraulics class at tech school.
I have no experience with full hydro. I'm not a mechanical engineer, but I am a computer engineer and stayed in a number of Holiday Inn Expresses. Here is my line of thinking for setting steering stops.
Setting the steering stops such that it limits the throw of the ram is setting yourself up for knuckle failure or possibly blowing a seal (get your mind out of the gutter, I would never do that to a seal).
If you don't have any steering stops, the ram will stop itself. However, when your steering is maxed out by the ram, any additional force on the knuckle (i.e. wheels at full lock with the rig pointed downhill) will be transferred to the maxed out steering ram -- possibly damaging it. I believe this is the same line of thinking as Ryan.
So you want your steering stops to be set to when your ram maxes out since there are bad situations that could occur if they aren't.
Please feel free to point out any errors in my line of thought.
Do the reid knuckles have steering stops on the front and back of the knuckle?
Dammit, you read that before my typical post-post grammatical corrections
I'd say that about 90% of my multi-sentence posts are edited at least once to correct some error within about 5 minutes of posting... But we digress...
I figured I would add these from other threads since they should add good tech to the thread. Both of these were in response to "Why choose PSC instead of other options (Howe, POS, etc.)?". Click on that fancy little white arrow next to the username in the quote block to go to the appropriate thread those comments were originally posted in.
