TnT install - Page 2
Thread: TnT install
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 57
  1. #26 Re: TnT install
    Quote Originally Posted by OverkillZJ View Post
    Wow. you've never seen Claytons flex like TNt'S Des.... don't make me call you out on that..
    Im' unbiased on that, but I don't undertsatnt the basis for your staememt, so I'll call you out on it.
    Wow, apparently i had a few last night, based on my spelling / typing!
    Just about all the LA kits will flex the same, even RK or Rusty's (doesn't mean i'd ever consider running it.) - Claytons does bind up front, as will any radious style front, but I've yet to see anyone twist a tube or have an issue with it.
    Really just make your decision and buy one, you don't hear anyone bitching about either kit...
  2. #27 Re: TnT install
    Staunton, VA
    So I took out all the rustys stuff, to me it seemed like it was just a crossmember with long arm brackets added to it. Not much more stronger than stock in my opinion, and I am basing that on the lack of bracing. The TnT kit had extra bracing on the sides, yes the rustys kit did as well but the material used in the brace...ehh left something to be desired, since they were bent when we removed the side braces
    Anyway. Got it installed, my only complaint is that he wasnt clear that the brackets were sided IE passenger and driver side support brackets
    so after a few headaches and finally seeing if the brackets were sided, we finally got it installed
    I do have pics, but mostly of the crossmember, which weighs in at 60 pounds according to UPS. All in all I say its going to be a good kit. I will def get a review post on it when I cant but since I have a serious electrical gremlin in the jeep I cant get out and test it. Bummer
    I will post the pics up tommorow
  3. #28 Re: TnT install
    Senior Member death-mobile's Avatar
    Jun 2005
    NJ
    Cool man, look forward to seeing it.
    Balltastic.
  4. #29 Re: TnT install
    I am EPIC Staff JordanA's Avatar
    Mar 2007
    Chapel Hill, NC - Winston-Salem, NC
    Can't wait!
  5. #30 Re: TnT install
    Senior Member faststang1's Avatar
    Sep 2007
    Palm Spring's CA
    I cant wait....this might make me go TnT for long arms...lol
    96 ZJ Limited, 5.2 with K&N filter, Hi flow cat, Cherry bomb extreme muffler, Clayton long arms 6" lift, Steering box brace from KOR, KOR track bar Conversion,TnT steering, 242 TC, 8.8 with ARB Locker, dana 30, 4.88 gearing, 35 KM2's
    KOR bumpers
    http://www.mallcrawlin.com/forum/showthread.php?t=17149
    07 CRF250X
  6. #31 Re: TnT install
    Staunton, VA
    Belly Skid
    Sorry for the lack of pics if anyone wants a pic of any particular part let me know I will get them this weekend
  7. #32 Re: TnT install
    Previously "Maatt" Matt's Avatar
    Kiowa, CO
    Where's the grand???
    J/K looks great, now get some trail shots and post back up.
    Project Never-ending
    1997 ZJ - sold
    www.tntcustoms.com
  8. #33 Re: TnT install
    Staunton, VA
    Grand is in the driveway
    It will be awhile, since I cant get it to run and I need to get shafts made. I am hoping to make it to big dogs in april though
    I will def post up some trail pics as soon as I can
  9. #34 Re: TnT install
    Mar 2007
    Looking good.
  10. #35 Re: TnT install
    And it only matters how much USABLE flex any of them have, and more often than not usable flex will not be determined by the brand of the long arms as opposed to the spring and shock combination.
    And just to add a Clayton WJ flex shot:
    EDIT:
    For me, the Clayton vs T&T argument basically comes down to this. If you want something simple that's going to work great and not leave you stranded go Clayton. If you want something that's a little fancier and a hair more intricate but still gets the job done, go T&T. Clayton was my choice because I want my suspension to be as simplistic and dependable as possible, with flex being less important than reliability.
    With either kit you're still eleventy billion times better off than you would be with RK or Rusty's.
  11. #36 Re: TnT install
    Clayton's flexes plenty. The tires are 35". I wouldn't know what to do with anymore flex.
  12. #37 Re: TnT install
    Kiowa, CO
    Quote Originally Posted by JohnBoulderCO View Post
    You could find bigger cracks to drive though.
    1997 ZJ - sold
    www.tntcustoms.com
  13. #38 Re: TnT install
    [quote=BigDaveZJ;183612]
    HEY, I took that picture, where's my .0000000000002???
  14. #39 Re: TnT install
    Sep 2007
    Palm Spring's CA
    I think if u had the same size tires,springs and shocks it would be about the same.....they both seem to be good kits......I was thinking about getting TnT's long arms for my ZJ because I go play in the dunes alot and I'm always rubbing the crossmember so TnT's skid sounds good!!!!!
    KOR bumpers
    07 CRF250X
  15. #40 Re: TnT install
    Quote Originally Posted by faststang1 View Post
    It would be the same suspension travel, but the pic would look different.
    Getting a 32" tire to droop below the slider requires less flex then getting a 35" tire to droop below. If I was on 31's the flex would "appear" to be even more. You have to take into account tire size when looking at "poser" flex pics.
    Both kits flex plenty. I like my Clayton kit.
  16. #41 Re: TnT install
    Kiowa, CO
    35's
    But as stated, both kits are great. I've wheeled IFS for to many years so I'm kinda a flex whore. I will probably throw a rear sway on before summer for more stability.
    And I'm not flexed out yet.
    1997 ZJ - sold
    www.tntcustoms.com
  17. #42 Re: TnT install
    Sep 2007
    Palm Spring's CA
    Quote Originally Posted by Matt View Post
    35's
    I'm a flex whore to....LOL....they both look good!!!!!!
    KOR bumpers
    07 CRF250X
  18. #43 Re: TnT install
    Staunton, VA
    Ok so the install is complete. Quick question, the super flex joints at the cross member end of the lower long arms, is it common for those to feel "different" while driving on a smooth surface?
    It almost feels like they are loose, but after checking things over 2 times now I cant find anything loose.
  19. #44 Re: TnT install
    Junior Member DarkXJ's Avatar
    Mar 2008
    SoCal HiDesert
    Quote Originally Posted by 1fox2go View Post
    Stuff arrived, Super beef. Pics if anyone is interested
    You ordered and received within 4 days? Damn it!! Everyone told me T&T took longer than anybody else so I went a different route. But T&T was definitely my preferred source. They include a belly skid for XJs also and the flex shots I've seen of some XJs with their kit were amazing. Well, now I know for the future, when I decide to go ahead and do long arms anyways.
    96 XJ 6/5" lift (f/r) 30x9.5 MTs - goin bigger once I ditch the - welded 8.25 rear, HP D30 front, cut fenders
  20. #45 Re: TnT install
    Clayton's and 35's:
    That is not full droop either. With any decent (read: not RK or Crusty's) longarm kit flex is limited by the length of the springs and shocks, not by the arms themselves. Claytons is simple, pure beef, and most of all reliable. IF I ever break I will send it back for free replacement.
  21. #46 Re: TnT install
    Senior Member Sudz's Avatar
    Pennsy
    Quote Originally Posted by jsteves View Post
    or brake lines
  22. #47 Re: TnT install
    Sep 2007
    Palm Spring's CA
    Nice!!!!!!
    KOR bumpers
    07 CRF250X
  23. #48 Re: TnT install
    Arizona
    Clayton's and 35's:
    Did I take this photo?
  24. #49 Re: TnT install
    I pulled it from our camera. You may have a very similar one if were standing next to my brother taking pictures.
  25. #50 Re: TnT install
    Staunton, VA
    Got some flex shots
    The steering geometry is outta wack so it limits the front travel
