Project Hookup - Now with Solar - Page 2
Thread: Project Hookup - Now with Solar
Page 2 of 17 FirstFirst 123456789101112 ... LastLast
Results 26 to 50 of 416
  1. #26 Re: DA Hookup
    Mountain View, California, United States
    Got a chance to do some wheeling over the weekend...
    Bro's TJ, Showing me up on 32's...
    Will
    99 4.0 DubJ 35"MTRs/ Custom IRO LA's/ Currie 9" housing/ Yukon 4.88 Gears 35 spline Grizzly Rear Lockers and ARB Front.
    The Hookup Build http://www.mallcrawlin.com/forum/showthread.php?t=12701
  2. #27 Re: DA Hookup
    Some More pIX
    Will
  3. #28 Re: DA Hookup
    Virginia, Hburg
    Quote Originally Posted by WJJEEPIN View Post
    TJs don't show grands up, you were just driving like a pussy.
    WJ-OME-JKS-KEVINS-32' BFGS-SOLD
    WK-DayStar-Spidertrax-BFGS-whoohoo
    Search, helping dumbasses everywhere.
  4. #29 Re: DA Hookup
    UMMM Sure.
    On that obstical, with his 32's and 3" lift and shorter wheel base he had more clearance and a better breakover angel. Where as my 4" with 30.5's I had less clearance. I did fine, and got way better flex with my adjustable ca's but clearance is clearance.
    Thanks for the comment
    Will
  5. #30 Re: DA Hookup
    Virginia, Hburg
    Just giving you shit. I understand the geometry involved.
  6. #31 Re: DA Hookup
    Quote Originally Posted by DerekL View Post
    No worries, Just pushing back..
    It REALLY made me want 33's.... Now just need my money tree to bloom.
    Will
  7. #32 Re: Project Hookup
    Oct 2007
    southport, NC
    love the jeep man. does the tie rod over the knuckle make any different in the steering at all. im looking to do that to mine.
    99 wj, 4.5, 265/75r16.
  8. #33 Re: Project Hookup
    Member ZachJ's Avatar
    Sep 2005
    Richmond/Chico, California
    what trail did you run??? how challenging was it.
    BTW nice WJ.
    95 Grand Cherokee V8 RE 3.5" + 2" spacers, Clayton Long Arms, RE front adj. Track Bar, Ford 8.8 w/ Detroit Truetrac, JKS quick discos, 3" FM 40 + Carsound Cat, 33" Maxxis Bighorn Radial, KOR radiator support, KOR LP1 sliderz, Ford E-Fan swap, tranny and gas skidz, more crap...
    overlandgears.com
  9. #34 Re: DA Hookup
    Nov 2007
    Virginia
    Nice WJ man, you need some 32's or some 33's though for sure
  10. #35 Re: DA Hookup
    Quote Originally Posted by grandJ910 View Post
    Hey Grand,
    Thanks! Just put on some 4.5" RK springs so I need to put up some new pics.
    AS for the flip, little difference. Its actually better because my oem TR were shot. And after flipping the DL the geometry is a little off and I get minor bumpsteer. The TR flip from IROR uses hemi joints which were nice and easy and didnt require any welding.
    Quote Originally Posted by ZachJ View Post
    BTW nice WJ.
    That was Strawberry Pass. Its only a few miles from Kirkwood snow mountain in Nor-Cal. The first 1/2-1/3 is no challange, more or a dirt road with some minor obstacles. But great camping spot with a killer view of Caples Lake and the snow mountain accros the way. The second 1/2-1/3 is definatly more technical. There was a rock squeeze that is awkward and tippy. And a couple rock gardens and one Very tippy spot. I hear a guy hit it and his roll meter hit 30. All in all very fun and a great location because it drops you off on HWY 50 which takes you back into S. Lake Tahoe.
    Quote Originally Posted by TheNightFox View Post
    Yeah, I'm stoked and bummed about the decision at the same time. I'm stoked I only paid like 400 for all 5 MTR's and I didnt have to regear and I still get ok mileage. I'm bummed for obvious reasons. I will be replacing my axels with the JK's D44's in the not to near future and at that point will be swapping in 33-35's.
    Will
  11. #36 Re: Project Hookup
    Dec 2005
    portland oregon
    Nice wj,looks like it keeps growing.I plan on doing the jk44 swap soon to.Have you figured out how to make the electric lockers work,i guess they have a low voltage pulsed signal to keep them engaged.That is the only problem i see in the swap.
  12. #37 Re: Project Hookup
    Quote Originally Posted by merkur 92 View Post
    Yeah i need to stop spending money on lift and start focusing on axels and some LA's.
    Sounds like your closer than I in the JK swap. I was talking with the guys from Iron Rock Off Road and they are currently producing a JK44 with all the braketry for the WJ... He was saying that they are hoping to have it for sale by the end of the year. You might want to give Josh @ IROR an email as I am sure they have the answer to getting the locker working and can either give you the answer or get you the parts necessary to get er done..
    Will
  13. #38 Re: Project Hookup
    Speaking of lift here are the 4.5"RK springs vs. the ome/bb.
    Here are the before & After front wheel well shots.
    Will
  14. #39 Re: Project Hookup
    And here are the rear Wheel Well before and after shots.
    The front is just about the same, just a little taller.
    The reason I got these springs was because I wanted to compensate for all the Shit I keep in the rear and the sagging it was causing. It was hanging me up so after I installed the rear I checked it out and it was still sagging so I jacked it back up and put the rear BB back on and it now has the tilt like from the factory.
    Now I can walk under the rear hatch and I dont crack my head on it. The new measurements are 21.5" in front (from wheel center to fender lip) and 22.25" in the rear. I'm diggn it.
    Will
  15. #40 Re: DA Hookup
    Nov 2004
    What are hemi joints? Do you mean heim? If so, dat's baaaad on a steering part.
    Poetry in commotion.
  16. #41 Re: DA Hookup
    Quote Originally Posted by SuicideTireZJ View Post
    Oops yea I meant heim, I think my computer auto fixed it. There are pics in 17 & 18...
    I have heard both arguments on the use of them. Fact is I know multiple people who have them on their rigs and have had NO issues. This is only the TR which is a L to R function and no 3D movement. As long as I keep an eye on them making sure they arent loosening up there good. Its on a check list along with the 100 other things on my rig that need to be routinely inspected...
    Will
  17. #42 Re: Project Hookup
    Oct 2007
    southport, NC
    thanks for the info man.
    the new coils look good.
  18. #43 Re: Project Hookup
    Virginia, Hburg
    So the JK axle is wide enough for a WJ? I thought about that when the 44's came out from Mopar, good to know, and keep me in mind when you go long arms with those shorts you got... (-:
  19. #44 Re: Project Hookup
    Yup their even wider than the WJ axels. If memory serves me on wjeeps.com is sais that our axels are around 59" wide. The new JK44's are 62" wide. So with the wider axels and a good rim tire combo you could really widen your stance.
    But I am at least a year away from that step. Babies are EXPENSIVE....
    Will
  20. #45 Re: Project Hookup
    Member C.C.Reed's Avatar
    Oct 2005
    AR
    Incorrect. . . stock WJ is 63.5" WMS to WMS.
    '99 WJ
    If you tell me I'm the wind beneath your wings I'm gonna hit you in the sack with my sledge hammer!!!
    You find me a girl that can be trusted, and I'll show you a talking unicorn that shits peppered bacon on demand.
  21. #46 Re: Project Hookup
    Dec 2005
    portland oregon
    The jk axles are a little over 2" wider than a wj,even if you wanted the stock width you could make that up with wheel backspacing.I like being a little wider when you go taller.
  22. #47 Re: Project Hookup
    Virginia, Hburg
    Quote Originally Posted by C.C.Reed View Post
    Congradulations you can read and give useless comments, when your mom comes in for parent teacher confrence i'll show her your gold star!
  23. #48 Re: Project Hookup
    Cleveland, MS
    Not to get into your cock measuring contest, but they are 63.5" WMS to WMS. Don't take our word for it though. Get a tape measure and find out yourself.
    I'm still waiting on the inexpensive shit to break!!!
    '02 WJ with 60's, locked, full hydo, ORI's, on 40's, and still have air conditioning!
  24. #49 Re: Project Hookup
    Nov 2004
    Wow, both of you guys need to fucking chill. This isn't even your thread!
  25. #50 Re: Project Hookup
    Oct 2005
    AR
    No shit. But everytime you try to correct someone to help out, some kid with a Jeep mommy bought him makes some dumbass comment. I was just trying to point them in the right direction.
    The JK's are not 2" wider. They are 1.5" shorter.
    I deleted my other post.
    WJJEEPIN, if you are seriously interested in the JK's, they can be had for relatively cheap ($2800 plus freight). The set listed on Pirate come with JK brackets but I am sure Clayton would be willing to get the correct brackets out quickly.
    http://www.pirate4x4.com/forum/showp...60&postcount=1
    Good luck.
    '99 WJ
