Project 7/8 Ton ZJ *Buggy time* - Page 8
Thread: Project 7/8 Ton ZJ *Buggy time*
Page 8 of 19 FirstFirst 123456789101112131415161718 ... LastLast
Results 176 to 200 of 464
  1. #176 Re: Project Roose ZJ
    Member Jsk8r1's Avatar
    Oct 2006
    Tucson AZ
    dumbass....
    ZJ is no more
    "GO"...
  2. #177 Re: Project Roose ZJ
    Austin, TX
    Did you go out and buy another one of these?
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  3. #178 Re: Project Roose ZJ
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    will you stop postin that shite1!1
  4. #179 Re: Project Roose ZJ
    Most of my parts came in and I was able to get alittle done today. Had a problem with my order and somehow got a 96-98 crossmember so that pretty much put a halt on things. Should have that worked out tomarrow.
    Still waiting on my Billstien 5100's
    Then after the install Ill order my limit straps and whatnot
    Got the stock skid out, crossmember, took sliderz off...
    Used a flap disc to remove the paint on the unibody... THEN the power went out so I wasnt able to do the other side.. Had to to use the generator to try to finish this side and then I ran outta gas.. so that was the end of that.
    Transmission mount is TOAST..
    And here are some pics of my Switch board, and CB install that Ive been meaning to get up for a long time.
    Switches are for front and rear lights, and then each wheel well individualy (rock lights)
    And a SWR meter permanatly installed
    Mic mount
    Mic wire has quik disconnect so once disconnected you cant even tell I have a CB (as long as you dont notice the 4ft antenna..lol)
    Speaker is for the CB
    Showin some love
    Heres some pics of my "rear bumper"...
    I just cut the factory hitch off and rewelded it higher (zip ties are just holding on the trailer wireing loom)
    Wo0t!!1
  5. #180 Re: Project Roose ZJ
    aka Pikachu piku303's Avatar
    georgia
    that remounting of the hitch looks slick man!
    97 zj ltd. 5.2, 3.5 RE w/ adj track bar, 32 maxxis buckshots
  6. #181 Re: Project Roose ZJ
    Austin, TX
    Mmm, finally a 'real' update.
    I like the hitch/bumper idea too.
    Jon
    95 ZJ, it gone.
  7. #182 Re: Project Roose ZJ
    cool cb placement, i like the rock light controls too.
    sick cb speaker too.
    97 V8 zj.
    03 Cobra with horsepowers
  8. #183 Re: Project Roose ZJ
    Houston, TX
    hmmm I like the hitch thing.... hmmm will have to do that to my front and rear hitches
  9. #184 Re: Project Roose ZJ
    thx for the comments guys...
    Got some more done today..
    Got the x-member screw up sorted out... Im goin to have to convert the tranny mount over to a 96-98 mount.. no biggy
    Bolted in the xmember and dry fitted the other brackets
  10. #185 Re: Project Roose ZJ
    and yes I know the center of the xmember is in upside down...
    just bolted it up in a hurry for mock up.. still have to pull the center back out to change the tranny mount
  11. #186 Re: Project Roose ZJ
    MallCrawlin Vendor
    bshows73's Avatar
    Oct 2007
    Mesa, AZ
    Check this out DJ here is your 14b and Dana 60 http://phoenix.craigslist.org/pts/631691352.html
    Barbaric Suspension & Fab
    KevinsOffRoad.com
  12. #187 Re: Project Roose ZJ
    Lol.. yeah thats the 14b Im picking up this weekend...
    My66coupe on here is selling them...
  13. #188 Re: Project Roose ZJ
    Member ZachJ's Avatar
    Sep 2005
    Richmond/Chico, California
    Did you pick up the claytons flat belly skid. I would like to see more pics of that.
    95 Grand Cherokee V8 RE 3.5" + 2" spacers, Clayton Long Arms, RE front adj. Track Bar, Ford 8.8 w/ Detroit Truetrac, JKS quick discos, 3" FM 40 + Carsound Cat, 33" Maxxis Bighorn Radial, KOR radiator support, KOR LP1 sliderz, Ford E-Fan swap, tranny and gas skidz, more crap...
    overlandgears.com
  14. #189 Re: Project Roose ZJ
    yup i got it... ill get pics...
    ill get pics installed to.. should be in on sunday or monday
  15. #190 Re: Project Roose ZJ
    Houston, TX
    Quote Originally Posted by zj95 View Post
    HURRY UP!
  16. #191 Re: Project Roose ZJ
    todays progress...
    Bryant (Bshows) came over and helped weld in the claytons...
    Drivers side rear mount ground for clearance
    Kevins sliderz were modified to fit
    Didnt get the belly pan in because DHL screwed up the shipping on the trans mount and it wont be here untill tomarrow...
    But as soon as the mount goes in Ill get the belly pan in and get pics for you guys..
    Ill install the front arms in the next few dayz, then onto the rear...
    Thx Bryant for the help!!
  17. #192 Re: Project Roose ZJ
    Also picked up this beauty yesturday...
    The start of my parts collecting for my next phase
  18. #193 Re: Project Roose ZJ
    Oct 2006
    Tucson AZ
    Looks good homo, who loaded that big axle up for you because I know your tiny ass didnt lift it.
    ZJ is no more
    "GO"...
  19. #194 Re: Project Roose ZJ
    lmao..
    My66coupe, his buddy, and me all lifted it...
    I dont even want to lift it off the trailer so Im just gonna leave it there untill I get my backhoe out then Ill lift it with that.. haha
  20. #195 Re: Project Roose ZJ
    Oct 2006
    Tucson AZ
    So I need to make another trip up your way to help you out huh?
    ZJ is no more
    "GO"...
  21. #196 Re: Project Roose ZJ
    lol sure...
    U can help me pull out the 8.8 and weld on the truss...
    Nevermind.. you will prolly forget to put my lug nuts on...
  22. #197 Re: Project Roose ZJ
    Oct 2006
    Tucson AZ
    U can lick my balls, I did put the lug nutz back on.
    ZJ is no more
    "GO"...
  23. #198 Re: Project Roose ZJ
    well your suppose to tighten them douche nozzle...
  24. #199 Re: Project Roose ZJ
    Oct 2006
    Tucson AZ
    pfff whatever I made it home.
    good thing you live in the middle of nowhere and dont need your jeep any time soon and can afford the down time.
    ZJ is no more
    "GO"...
  25. #200 Re: Project Roose ZJ
    your tire almost made it home before u....
