Thread: Project 7/8 Ton ZJ *Buggy time*
Page 17 of 19 FirstFirst ... 78910111213141516171819 LastLast
Results 401 to 425 of 464
  1. #401 Re: Project 7/8 Ton ZJ
    Sep 2007
    Slovenija
    Quote Originally Posted by ZJCHIPMUNK View Post
    ok is it me or does the diff look to be set more to the driver side then center and if it is why is it like that
    I believe he was not standing at the middle of the car when he take that picture. If you look at side windows, you can see that left side is less visible than right side. I think this is the answer, or...?
  2. #402 Re: Project 7/8 Ton ZJ
    Sep 2007
    Slovenija
    I forgot to say, NICE ENGINE!
    What is price for rebuild kit for 318 in USA?
    I think my engine will need rebuild... My oil pressure is acting strange. I must replace oil first and then we will see. But anyway I`m looking excuse to take V8 out and rebuild it.
    Don`t know why
  3. #403 Re: Project 7/8 Ton ZJ
    Put a tape measure to your current axle and report back. Most are not centered.
  4. #404 Re: Project 7/8 Ton ZJ
    Because 14 bolts don't have a centered diff. From the 14Bolt bible:
    Quote Originally Posted by 14 Bolt Bible
    The shafts are different length L and R. The Left is the short side at 31-5/8". The Right is the long side at 37-5/8"
    http://www.pirate4x4.com/tech/billav...ble/index.html
    A lot of other rear axles (i.e. 8.8, most D60s/D70s, etc.) don't have centered diffs. None of them, to my knowledge, are offset enough to cause any driveshaft angle issues.
    As for why it's like that. I'd speculate that in the original vehicle(s) the axle came in, that diff location offered the "straightest" angle between the pinion and the tcase/transmission output. It's probably a lot easier for the car designers to offset the diff than to offset the entire drivetrain (which could throw off weight bias and/or be physically impossible to do) to get ideal driveshaft angles. Again, this is just speculation, so take it with a grain of salt.
  5. #405 Re: Project 7/8 Ton ZJ
    Feb 2011
    laurel hill nc
    i am use to seeing them center like a dana 60 the main reason why i was askin is because the diff of that 14bolt does look like all the ones ive seen it looks like a front diff i could be wrong ill ask more about at the 4x4 shop in town
  6. #406 Re: Project 7/8 Ton ZJ
    Senior Member MallCrawlin Supporter biggoofy's Avatar
    Jan 2010
    SLC UT
    Is there an english translation to that!
  7. #407 Re: Project 7/8 Ton ZJ
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    Haven't shown my face here for a long while, guess I can update this
    Lets see, the transmission blew 2 years ago and I parked it because I was tired of fixing it. 6 months ago I pulled it out of storage and threw a new trans in it
    First thing I did was threw on some new tires and wheels with a shallower backspace
    After that I started on a few projects
    Rhinolined the tub
    Installed some race craft seats with harnesses (no shoulder bar yet, will be chopping it up in a month or 2 for full buggy)
    Grant steering wheel with quick disconnect hub
    Started on beadlocks today
    One done
    New parts
    5.38 gears F&R
    Install kits
    D44 locker
    sending unit flange for fuel cell (thats for anther post )
    and finally I got a tow rig
    2004 F250 King Ranch with the 6.0 powerstroke
    More to follow tomorrow
  8. #408 Re: Project 7/8 Ton ZJ
    Austin, TX
    Welcome back homo, chits looking good.
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  9. #409 Re: Project 7/8 Ton ZJ
    Jun 2012
    Forsyth County, Georgia
    Just read every page. Love your build up, and that new tow pig looks great!
    2003 WJ|6.5" IRO LA|35 MTs|Uniden CB|K&N Drop-In|Dana 44 Rear End Swap|3.73 Gear Swap|Front Disconnects|Flowmaster 40|SYE|Driveshaft Conversion
  10. #410 Re: Project 7/8 Ton ZJ
    Got the Beadlocks done, time will tell if they leak. Need to throw some airsoft bb's in them when i get a chance
    Had to weld up old valve stem hole and drill a new one ( can see the old hole to the right)
    Extended stems should make servicing easy
    Installed
    Also snapped some pics of my New stubby front bumper and lower radiator support. I raised the radiator an inch (along with fenders and hood)
    I will be adding a winch and fairlead in the future and tucking it behind the bumper
  11. #411 Re: Project 7/8 Ton ZJ
    San Diego
    Glad to see you're still alive dude. Rig is looking great!
  12. #412 Re: Project 7/8 Ton ZJ
    Yep looking good!!
  13. #413 Re: Project 7/8 Ton ZJ
    Oct 2012
    Lexington, NC
    to me this is one of the best rigs on here.....may just be cause it looks just like mine tho lol
    Coles Auto your one stop shop for all used Grand Cherokee parts
    97 ZJ 5.2L 4.5" 33bfgs
    99 WJ 4.0L 6.5" full width ford axles and 38's (in the works)
  14. #414 Re: Project 7/8 Ton ZJ
    http://woobox.com/oknmma/vote/for/864796
    gotta get some motivation to work on this thing, Vote for the Heep plz? Haha
  15. #415 Re: Project 7/8 Ton ZJ
    Junior Member eshindi's Avatar
    Jun 2009
    NY long island
    I love the bumper you have in post 407.
    Gives me ideas for mine.
    Love the Rig.
    99' WJ, I6, Claytons 6.5", HP44, Ford 9", 35" Cooper STTs
  16. #416 Re: Project 7/8 Ton ZJ
    Yearly update haha
    broke a front shaft
    Got alloys for pass side and got rid of the cheap joints and went with spicer 760's
    Did some more frame plating, cut out inner fenders, relocated batteries, tore out all the shit I don't need and stripped wiring harness, pics speak for themselves
  17. #417 Re: Project 7/8 Ton ZJ
    San Diego
    ^This guy.
  18. #418 Re: Project 7/8 Ton ZJ
    Austin, TX
    Dude, come to Texas and help me finish mine. You're only 1 state over...
    Jon
    95 ZJ, it gone.
  19. #419 Project 7/8 Ton ZJ
    Alittle update...
    [URL=http://s5.photobucket.com/user/zj95/media/ZJuggy/IMG_2749_zps1172210e.jpg.html][/URL
    Stay tuned!
  20. #420 Re: Project 7/8 Ton ZJ
    Mar 2008
    westerville, ohio
    I'll be keeping a eye on this for ideas if I decide to no keep mine full bodied
  21. #421 Re: Project 7/8 Ton ZJ
    The last post by the OP has made my day!
  22. #422 Project 7/8 Ton ZJ
    start of 1/4 elliptical rear
    4x4x1/4" slid into original rails
    end will be capped
    axle end shackle will have adjustable heim to adjust ride height
  23. #423 Re: Project 7/8 Ton ZJ
    JohnBoulderCO's Avatar
    What's wrong with your 4-Link?
  24. #424 Re: Project 7/8 Ton ZJ
    Nothing is wrong with the 4 link, it's staying as is. Besides some stretching
  25. #425 Re: Project 7/8 Ton ZJ
    1/4 elliptical rear?
