Thread: Project 7/8 Ton ZJ *Buggy time*
Page 10 of 19 FirstFirst 12345678910111213141516171819 LastLast
Results 226 to 250 of 464
  1. #226 Re: Project Roose ZJ
    That is pretty bold statement. I understand building one yourself. And I understand copying a design but admitting you are going to copy it on a public forum is pretty lame.
    i was just joking, i ended up not building it anyways cause my friend with the welder is going to be in arizona for the summer and we ran out of time after we built my sliders.
    but i was just going to make a rear crossmember and a tie a piece of sheet from it to the stock front crossmember...i got that idea from puma...but its also pretty much what claytons belly skid is as well.
    97 V8 zj.
    03 Cobra with horsepowers
  2. #227 Re: Project Roose ZJ
    Dec 2005
    Central Mass.
    Quote Originally Posted by zj95 View Post
    My spool treats me like a $2 hooker... and i LOVE it...
    does it make it hard to drive? rock back and forth like a bad VC on a 249, or does it just cause some spinning of the tires on tight turns.
  3. #228 Re: Project Roose ZJ
    pm sent
    97 V8 zj.
  4. #229 Re: Project Roose ZJ
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    chad, no it isnt removable without a sawzall...
    Derek it acts just like anyother vehical with a spool.... the tires slip in corners, not hard to drive... very predictable, hardly noticable if you make your turns wide.
  5. #230 Re: Project Roose ZJ
    Dec 2005
    Central Mass.
    the only traction control ive been used to was my old mans f250 with locking front hubs in 4lo. that sucked.
    thanks for the help, though. ill be sure to order a mini spool soon. found some for around 85 bucks.
  6. #231 Re: Project Roose ZJ
    keep in mind that they dont last very long, 1-2 seasons...
    They mushshrom
  7. #232 Re: Project Roose ZJ
    Dec 2005
    Central Mass.
    what happens after they mushroom? no longer provide a locked differential, or cant be driven?
  8. #233 Re: Project Roose ZJ
    just cause alot of play.... clanglin and prolly will screw something up if it gets to bad....
    This is true for the 8.8, im just guessing your spoolin the 8.8... right?
  9. #234 Re: Project Roose ZJ
    Dec 2005
    Central Mass.
    yeah the 8.8. im just getting all my parts ordered to get this sucker on the jeep.
    mini spools seem to be easy to find, and pretty cheap. heck, id pay the 85 bucks im looking at just not to have to line those spider gears back up and make sure everythings in place. and havin to replace these every couple years isnt too big a deal.
  10. #235 Re: Project Roose ZJ
    Jun 2005
    Paradise, Newfoundland Canada
    What about if you take a corner fast?
    A spool is a shit load cheaper then a Detroit but I don't want to fly around a corner one day and slide into another vehicle or do a 360.
    Anthony
  11. #236 Re: Project Roose ZJ
    well how fast are u gonna drive in a built ZJ?
  12. #237 Re: Project Roose ZJ
    Jun 2005
    No fast but I do take the odd corner at 20-30kph, no fucking clue what that is in mph but it's not that fast imo.
    I'd adjust my driving of course but I'm sure I'd still take the odd corner at 20.
    Anthony
  13. #238 Re: Project Roose ZJ
    Pics are with front wheel drv only
    Think i need stiffer rear springs, the RE 3.5 fronts flex way to much.. the front has no chance to flex at all
    Rear coil buckets are done... need to clean up the punch seem and paint them
    Still need to order SYE and rear DS but it was put on hold becuase i bought a new DD
    Its a 1994 ZJ with the 5.2 and...
    102,000 miles
    Cold ac
    Stock
    Clean interior (besides theft damage that will be fixed next week)
    The guy was tryin to sell it for 2500 but the night before I went to look at it someone tried to steal it.
    They broke the ignition switch all to hell, broke the clear gauge cover, and Fucked up every door lock cylinder on the thing
    I ended up talkin the guy down to $1,800
    Today I put new ignition switch ($30) and replaced a fuse and it fired right up, the rest of the broken stuff Im gettin off goose2125 on here.. super cool guy.
    Also today i had a chance to look it over better.. I have no clue how i looked over it but it has no front DS.. WTF..
    We all know about the 249 and no front shaft.....
    It drives fine without it but im thinkin thats because the 249 is prolly shot already and someone took out the shaft to stop the bucking in the corners. No biggy as i planned on gettin rid of the 249 anyway
    Plans for the dd are to keep it simple
    2"bb
    235/75R15's
    Swap 249 for 242 hopefully or 231
    Lock the d35 and once the tcase is swaped lock the 30
    Tune up
    CCC Treatment
    It will be used for camping and whatnot
    Im hoping to get atleast 16mpg on the highway
  14. #239 Re: Project Roose ZJ
    Member CanadaDry's Avatar
    Canada
    The only thing better than 1 ZJ is 2 ZJ's. The build looks good nice find on the DD.
    5 Niner with, RE 3.5 SuperFlex kit, 1" spacers, RE front adj track bar, Rancho RS 5000's, 32'BFG AT's on AR Mojave Teflon coated rims, Kevins LP-1 Sliders, Uniden CB .
    "60% of the time it works Every Time"
  15. #240 Re: Project Roose ZJ
    Member floridaZJ's Avatar
    Aug 2007
    Clemson, from FL
    How thick of steel did clayton make that belly skid out of? Can you get any measurements off of it?
  16. #241 Re: Project Roose ZJ
    http://www.mallcrawlin.com/forum/sho...ons+belly+skid
    Im not giving you measurements so you can make your own... look at the pics to see how it fits.
  17. #242 Re: Project Roose ZJ
    Aug 2007
    Clemson, from FL
    thanks. it's pretty basic for how much $$ it costs.
  18. #243 Re: Project Roose ZJ
    Sooo Ive been putting this thing off for a few months because of the new dd but I did alittle tonight
    But no pics... lol
    I reinstalled driveshafts, and lowered it down to 5.5" for now.
    I still plan on ordering the sye and goin 7" but dont need the 7" for my 34's
    I drove it up and down my street and the rear ds seems to work fine at 5.5 so thats good. Ill take it on the highway tomarrow.
    Ill get pics tomarrow
    I need to order longer brake lines, and make some temparary limit straps before I do any "real" wheelin.
  19. #244 Re: Project Roose ZJ
    Oh and i did a bunch of work on the dd zj.
    new water pump
    3core rad
    trans cooler
    new wheels
    235/75R15 firestone a/ts
    2" bb and my old rs9000's
    new front driveshaft
    new cap and rotor
    new plugs
    new 02 sensor
    seafoam
    procomp lca's
    new front uca's
    new axle side bushings
    procrap adj. trackbar
    tookout front d30, cleaned 1/2" of grease off it, painted it and reinstalled
    YEAHHH.... fuckin jeeps....
    so thats why i havent ordered a SYE.... haha
  20. #245 Re: Project Roose ZJ
    Canada
    We need pics of the 2 jeeps together.
  21. #246 Re: Project Roose ZJ
    Well my camera got crushed on my last vacation so no pics of jeep...
    heres some cell phone pics of my new motor goin in within the next few weeks hopefully
    its hemi orange... looks kinda pink in the pics haha
  22. #247 Re: Project Roose ZJ
    Austin, TX
    Shoulda painted it pink. And you forgot to flip off the camera.
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  23. #248 Re: Project Roose ZJ
    its gonna get...
    double roller timing chain
    new sensors
    new seals
    new gaskets
    new pulleys
    new valve covers
    new hoses
    firepower ignition (hopefully)
    High volume oil pump
    new water pump
    maybe new motor mounts (current ones are pretty new but might be shot now)
  24. #249 Re: Project Roose ZJ
    Austin, TX
    Mopar Performance Computer.
    Jon
    95 ZJ, it gone.
  25. #250 Re: Project Roose ZJ
    I heard that killing yourself has the same effect...
