ok i went to the junk yard the other day to get a lid for my center consle .... i saw this under an exploder and just asked how much they wanted .... the girl said she didnt know and asked what i would pay... i told her (lieing) that i could get it at a junk yard in pheonix for $175 and she said that she would take that...
Sooo.. instead of getting a $5 center consel lid i got an 8.8... haha
It is out of a 1996 ford exploder with 109,000 miles and has 4.10 gears and limited slip.
heres what it looked like when i bought it.. (sway bar and ebrake cables came with it.. anyone need them?)
i took off all the unnessesary crap
then took off the cover and drained the sludge (no metal shavings so im happy
heres a picture of the limited slip carrier
took out the shafts and brakes
and here is how it sits now.
Plans....
i will be installing it with the factory limited slip for now but will prolly get a locker in a few months
i will be wireing it to keep ABS but putting a toggle on the ABS to turn it off when off road
using brackets off of an old d35
regearing front d30 to 4.10s
More to come
If you knew any better you would reinstall the ebrake cables because they work with the jeep brackets.
what brackets do they work with?
i still got everything just took it off for mobility and painting
The ebrake handle brackets.
my stock cables work tho... right? and i wont have to screw with the handle side just the axle
got every other gear ground off the ABS tone ring ...
got some new ebakes....
and i ordered the wheelspacers..... should be here next wednesday.
then ill start on the real work
and i picked these up today... 33" BFg A/T KO's ... got all four with wheels that have 4 inch BS... all for $195
looks good so far. are you doing your front gear install on your own? also, who did you get your spacers through?
the owner of the local jeep club is going to help me do the gears and bracket mock up so i do have someone with more experience helping me but ill be doing atleast half the work... it will be a good learning experience
and the wheel spacers i got were from ebay... not the best but they will work
http://cgi.ebay.com/ebaymotors/FORD-...QQcmdZViewItem
yeah... it sure helps to have someone with past experience to help you out
Loose the ABS and don't waste your time messing with the tone ring.
I need the ABS because of insurance and because I tow trailers alot....
it will have a toggle on it tho..
plus everything is done except the super technicle wiring... only took a hour and 1/2
How does ABS relate to insurance?
And get a tow rig if you tow trailers alot.
if u get in an accident and the insurance finds out that u screwed with the ABS they will not cover you...
and there is no need for a tow rig... jeep does fine.... why would i pay for another vehical, maintaince, insurance.. if theres no need?....
it pulls trailers every weekend... (18' boat, 20 ' quad trailer) but it does fine...
if the ABS dummy light comes on and it quits working that is not your fault... it is an accident... just like if a brake line burst and u hit someone... not your fault.. the burst is just what caused it..
but if the insurance finds out that YOU disconected it they now have an argument to not cover u..... if its so easy to keep it and and advoid messing around with insurance then just do it!
and same goes for cars that do not have ABS from the factory.... it's not your fault that it didn't come factory...
Has the "grind every other tooth method" even been proven to work? The Chrysler ABS has two rear signals and the Ford has one center.
And have you even posed the lack of ABS question to your insurance agent? Generally there are other extunating circumstances around an accident other than ABS failure like the lack of the ability to drive a lifted and high center of gravity vehicle.
haha dave...
the ABS on the 8.8 swap has worked before.. http://www.mallcrawlin.com/forum//sh...?t=2880&page=2
having the ABS doesnt mean the insurance WILL cover you just means they have one less thing to whine about..
