Project 7/8 Ton ZJ *Buggy time* - Page 18
Page 18 of 19 FirstFirst ... 8910111213141516171819 LastLast
Results 426 to 450 of 464
  1. #426 Re: Project 7/8 Ton ZJ
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    On a 1/4 elliptical the 4 link controls the axle, all the leaf pack is doing is replacing the coil.
    It allows for a progressive spring rate , easily adjustable spring rate by adding and subtracting leafs, as well as ride height adjustment with an adjustable shackle.
  2. #427 Re: Project 7/8 Ton ZJ
    Gotcha wasn't sure what the end game was.
  3. #428 Re: Project 7/8 Ton ZJ
    Just something to play around with really . Also gives me freedom when designing the back half of the cage without having to worry about coil mounts or coil over hoops
  4. #429 Re: Project 7/8 Ton ZJ
    Awesome! Kraqa is the only other on here that's done 1/4" elliptical, right?
  5. #430 Re: Project 7/8 Ton ZJ
    As far as I know. I've been out of the loop here since 2009 lol
  6. #431 Re: Project 7/8 Ton ZJ
    Finished up 1/4 eliptical, and stretched axle back 2"
    Boatsides, Top bar is 38" high
    To0b
    Passenger side to match
    Both sides done
    Front bullbar, You can also see how tight the A-pillars are
    Fender bar
  7. #432 Re: Project 7/8 Ton ZJ
    Sorry for the super shitty pics, Ill try to get better ones in the daylight tomorrow
  8. #433 Re: Project 7/8 Ton ZJ *Buggy time*
    Rear half progress
    Hopefully Ill get some time to make some more progress this week.
    120 feet down, hopefully only 60 feet to go.
  9. #434 Re: Project 7/8 Ton ZJ *Buggy time*
    Lookin good man.
  10. #435 Re: Project 7/8 Ton ZJ *Buggy time*
    Taillights and license plate bezel graphed in
  11. #436 Re: Project 7/8 Ton ZJ *Buggy time*
    looks good.
    not to be a critic, i love the look and the direction this is going. but i have to ask. why do none of the arm bars for the doors line up?
  12. #437 Re: Project 7/8 Ton ZJ *Buggy time*
    Lol no worries. I actually cut the rear door bars out tonight and re aligned them. I wanted the rear door bars to mount at the same height to the b-pillar as the front doors mounted to the a-pillar just to break up the body line.
    How ever ... I fucked up my measurements on where they mounted the c-pillars so they were no where close to aligning with the rear hoop. But after repositioning they align.
  13. #438 Re: Project 7/8 Ton ZJ *Buggy time*
    I was waiting for someone to catch it. They were bugging the hell out of me.
  14. #439 Re: Project 7/8 Ton ZJ *Buggy time*
    sweet. well post up some pics!!!!
  15. #440 Re: Project 7/8 Ton ZJ *Buggy time*
    i loved my 1/4 ellip on my first buggy. it was crazy stable with no sway bar. you can even put short peices of leaf springs under the stack to control the unloading of the rear suspension. its awesome.
  16. #441 Re: Project 7/8 Ton ZJ *Buggy time*
    I'll try to get some tomorrow. The only point that the nodes don't align are at the b-pillar now but it is intentional. I plan to add a gusset behind the body skin to distribute the load.
    Your original buggy was actually my inspiration for mine. When you first chopped yours I was up all night reading your build thread.
    As far as the 1/4 elliptical goes. I'm uber excited to play with it. I was torn between the 1/4 elliptical, hydro Rams like ashman was running on his XJ, or a cantilever using hydro Rams. I just wanted to go with something unique that I could play with before I go coilover.
  17. #442 Re: Project 7/8 Ton ZJ *Buggy time*
    Door bars realigned and support added , harness bar mocked in, and rear "frame rails" that will hold gas tank, rear shocks, batteries, and spare tire
  18. #443 Re: Project 7/8 Ton ZJ *Buggy time*
    looks good.
  19. #444 Re: Project 7/8 Ton ZJ *Buggy time*
    tick tock.....tick tock.....wheres the updates man?
  20. #445 Re: Project 7/8 Ton ZJ *Buggy time*
    I'll try to get some pics in the next few days, I bent up the main roof bars, got everything fully welded, and drove it around the block and onto a trailer for my move to AZ.
    Been caught up in the move since then.
    To do list:
    Skins
    Rear harness bar
    B hoop X
    C hoop X
    Fender bars
    Under hood cage
    Roof needs triangulation
    Boatside skin
    Rear shock mounts
    Permanently mount fuel tank and batteries (ratchet strapped now)
    Rear bench seat
    Spare tire mount
    OBA tank mount
    Rear storage rack
    Window nets
    Light bars
    Mount overhead console
    Paint/vinyl wrap
    Still a long list :-/
  21. #446 Re: Project 7/8 Ton ZJ *Buggy time*
    Jan 2015
    az
    Are you moving back to Tucson? Is love to check this thing out if you are. I really dig the headlight mod and rear windows. Might have to try a similar setup.
    93zj build. 4.0 aw4, 231, 60s, and 37s. Some cutting and some welding.
  22. #447 Re: Project 7/8 Ton ZJ *Buggy time*
    Yeah already moved back. Haven't gotten around to finishing it yet but still hoping for before June at the latest
  23. #448 Re: Project 7/8 Ton ZJ *Buggy time*
    Clemson, SC
    Makes me want to pull out the sawzall and go to town on mine... Looks good man!
    -Ronnie
    98 5.9 on 35s
  24. #449 Re: Project 7/8 Ton ZJ *Buggy time*
    Dinwiddie, VA
    Whoa! Hadn't been on here in a long while and am just getting caught up. Hadn't seen that you had cut it. I love the direction you're heading and even more that you're doing something different than most. Keep it up!
    "Matt"
  25. #450 Re: Project 7/8 Ton ZJ *Buggy time*
    Nov 2011
    tahoe city
    any updates I'm loving this thing!
