Project 7/8 Ton ZJ *Buggy time* - Page 3
Thread: Project 7/8 Ton ZJ *Buggy time*
Page 3 of 19 FirstFirst 12345678910111213 ... LastLast
Results 51 to 75 of 464
  1. #51 Re: Old gold
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    lil update...
    said screw it to regearin the front 30 and just bought this on saturday...
    hp30, detroit truetrac, 4.10s, trussed and lca skids.... completely rebuilt 10k ago (gears and detroit installed the same time)
    got it painted up and ready for install...
    also got all the brackets cut off the 8.8 and an old d35 housin that i will use for brackets
    but one bad thing is i cant use my abs with the hp30
    so all that work for nothin
    95 ZJ/ 5.2 / HD Dana 44 front / 14b rear / 5.5" CLAYTONS / 38'' Grooved TSL's / CLAYTONS belly skid / NP231 w/sye
  2. #52 Re: Old gold
    Senior Member ILikeMud's Avatar
    Jun 2005
    Paradise, Newfoundland Canada
    Very nice.
    That's an interesting looking truss though.
    Anthony
    96 Talon TSI AWD - Hey, at least it has a transfer case.
    03 Chevy Tracker - I hate IFS!
  3. #53 Re: Old gold
    haha thx!
    the guy that had it before me had it in his xj...
    not sure if u can call it a truss... he called it a plate truss...
    hopefully it wont hit my oil pan... we will have to see
  4. #54 Re: Old gold
    Arizona
    I'll sell you a "1 ton" steering setup for cheap for that axle....
  5. #55 Re: Old gold
    haha ill ill have to get back to u on that one... have no money... its all goin to the swaps
    hope to have the swaps done in the next 2 or 3 weeks...
  6. #56 Re: Old gold
    Austin, TX
    Quote Originally Posted by zj95 View Post
    Thats kinda what I said about mine... the 9" has been sitting for about 2 months now and all I've really gotten done is pulling it apart and cutting off the old brackets.
    Looks good though, seems like you have tons of spare parts too.
    Jon
    95 ZJ, it gone.
    76 J-10, 'Heep' Jeep.
    06 Boobicon, it wheel.
  7. #57 Re: Old gold
    yeah the guy set me up....
    he gave me all the parts in the first pic and a set of spare 8.8 parts
    i got everything for $450... which is about what id have to spend on my lp to get it ready... (ball joints are bad and all the brackets are smashed)
  8. #58 Re: Old gold
    got the flange
    ground down the housing and made it purdy
    got the brackets ground to fit the bigger tube ... had trouble with 1 bracket... it has a huge gap.. but we'll make it work
    the rest came out good
    i used 1 wheel ... it took a beating.. lol.. toward the end it worked better because it acted like a cut off wheel
  9. #59 Re: Old gold
    Arizona
    You might want to reconsider your hardware choice on that flange.
  10. #60 Re: Old gold
    yeah... i asked the guy at the driveshaft shop for some bolts and he went on got those.... seems like he uses them alot because he knew the exact size/thread..... but im still not sure...
    they seem like they would be strong enough... the heads on them all are stamped with a 8.8, anyone know what that means?
  11. #61 Re: Old gold
    Arizona
    Yeah they are equalivant to a Grade 4-5. You need a 10.9 or better and consider a 12 point FLANGED head.
  12. #62 Re: Old gold
    cool thx...
    any idea where i can get some?
  13. #63 Re: Old gold
    Senior Member RiPPiNiTuP7's Avatar
    Dec 2004
    Ohio
    cool thx...
    ford dealer. i paid like $8 for all mine. look in the 8.8 write up for the part number in the FAQ section.
    also, why no abs on the HP30? you can't swap your shafts/knuckles?
    -04' silver ram 1500. 5.7 hemi. 4x4. a few goodies.
    -98' chargold zj. 4.0/242. stocker.
    -09' black yamaha rhino SE. new offroad play toy.
    -96' black zj. 4.0/242. re 4.5" + 2" BB, 35" bfg at's, 8.8 w/ e-locker, open HP30, 4.56's, TW SYE & F/R driveshafts, currie steering, addco's F/R, ARB'ed, Warn 8k winch, & armor. - SOLD
  14. #64 Re: Old gold
    i can but.... no thank you... i dont feel like screwin with it...
  15. #65 Re: Old gold
    Jun 2005
    Didn't you want to keep your ABS for insurance reasons?
    Anthony
  16. #66 Re: Old gold
    yeah.. back when i had time to screw with it and it was easy... but oh well now... plans change
  17. #67 Re: Old gold
    Member Jsk8r1's Avatar
    Oct 2006
    Tucson AZ
    axles look good but your still gay buddy
    ZJ is no more
    "GO"...
  18. #68 Re: Old gold
    Tucson
    Nice paint job on that axle. Silver and green. Hmmmmm. I'll bet you a nickel the "truss" whangs on your oil pan.
    light, strong, cheap.... pick two
  19. #69 Re: Old gold
    prolly.. lol we will see
  20. #70 Re: Old gold
    pics from today..
    8.8 in...
    sexy pink Trackbar
    built some custom LCA's for reasons we wont discuss.. new on left.. old on right
    sould be strong enough.... 1/4 inch wall... .
    mocked up
    end result is the rear end is set back!... i like it!... much more room for clearance
    clearance before the swap
    it was acually about 1 inch closer than what u see in the pics because those pics were takin when i had the 3" lift on it, but now i have 5.5"
  21. #71 Re: Old gold
    all that is left on the 8.8 is install the brakes and driveshaft...
    diff cover hits the gas tank skid, but not to bad... nothing a cut off wheel wont fix
    then tomarrow we will swap out the d30 for the hp30..
    overall i think it was a good day
  22. #72 Re: Old gold
    Arizona
    The gas skid is about the same dimension as the gas tank. So if it is hitting the skid it will also hit the tank. You should shorten up your lower arms that you just lengthened. What is your rear pinion angle? Running a double card rear shaft?
  23. #73 Re: Old gold
    it is hitting by about 1/4 inch... it will be fine and should clear the plastic tank
    if i shorten the arms then the pinion angle is way off and i would have to cut off the brackets on the axle.... not fun..
    pinion is at about 8* alittle high but it's alright..
    and no double card rear shaft..
  24. #74 Re: Old gold
    Tucson
    Mine barely rubs the gas tank skid as well. the skid on mine sticks out about 1.5" farther towards the front than the gas tank. Looks good DJ. how long are your rear shocks? nice track bar, princess.
    Kevin
  25. #75 Re: Old gold
    not sure how long these shocks are... james gave them to me to replace the rs9000's i had for my 2" lift.. lol... but at ride hieght if i take off the bottoms and let them hang they are about 2" from the ground
    5.5" lift + shocks for 2" lift=no down travel
There are currently 4 users browsing this thread. (0 members and 4 guests)
