Project "Tortoise" NP435 + 249 + D20 - Page 3
Thread: Project "Tortoise" NP435 + 249 + D20
Page 3 of 7 FirstFirst 1234567 LastLast
Results 51 to 75 of 156
  1. #51 Re: Project "Tortoise" NP435 + 249 + D20
    damn...lookin awesome man!
  2. #52 Re: Project "Tortoise" NP435 + 249 + D20
    Member ZachJ's Avatar
    Sep 2005
    Richmond/Chico, California
    Quote Originally Posted by AgitatedPancake
    What he said.
    95 Grand Cherokee V8 RE 3.5" + 2" spacers, Clayton Long Arms, RE front adj. Track Bar, Ford 8.8 w/ Detroit Truetrac, JKS quick discos, 3" FM 40 + Carsound Cat, 33" Maxxis Bighorn Radial, KOR radiator support, KOR LP1 sliderz, Ford E-Fan swap, tranny and gas skidz, more crap...
    overlandgears.com
  3. #53 Re: Project "Tortoise" NP435 + 249 + D20
    Houston, TX
    Thanks for the thanks! just helping out a fellow Jeeper Keep up the good work!
  4. #54 Re: Project "Tortoise" NP435 + 249 + D20
    Senior Member EMTimZJ's Avatar
    Jan 2006
    West Michigan
    I did not have much time to work on the rig the past weekend. Since I had to flip my 249 reduction box, I had to re-drill my transmission adapter. (or get a clocking ring and mess around with seal engagement) This method was faster and easier to do.
    I cleaned off the previously messy basement work bench and went to work. It turned out fine and was not nearly as painful as I originally thought.
    I kinda had to mentally prepare before I took a blade and grinder to such a pretty adapter ... but it just had to be done, I'm sure you understand!
    -Tim
  5. #55 Re: Project "Tortoise" NP435 + 249 + D20
    Jun 2005
    Paradise, Newfoundland Canada
    Nothing like chopping up something purdy
    So I must ask Tim, aren't Toyota axles 6 lug? Are you still using a d30 front? How are you getting around the different bolt patterns.
    Anthony
  6. #56 Re: Project "Tortoise" NP435 + 249 + D20
    Jan 2006
    West Michigan
    Quote Originally Posted by ILikeMud
    Yeah, I think I measured about 15 times before I marked it, then about 15 times after I marked it
    See post #31, second picture from the bottom. My toy-8 came from a 4wd version, which means 6x5.5 lug pattern. The V6/turbo 2wd versions have a 5x4.5 lug pattern, however they are a harder to find. The non V6/turbo 2wd axles are the Toy 7.5" diff with 27 spline axles and weaker housing.
    -Tim
  7. #57 Re: Project "Tortoise" NP435 + 249 + D20
    Junior Member monkeyevil's Avatar
    Kalamazoo, MI
    Love the pretty steering box
  8. #58 Re: Project "Tortoise" NP435 + 249 + D20
    Jan 2006
    West Michigan
    Quote Originally Posted by monkeyevil
    Hey Daryl, nice to see you made it over here!
  9. #59 Re: Project "Tortoise" NP435 + 249 + D20
    Jan 2006
    West Michigan
    NP435 internals:
    Shift assembly:
    Installed the correct bearing retainer, Dodge style on the left, Ford style on the right.
    OD of the Dodge = 1.236"
    OD of the Ford = 1.430"
    The two throwout bearings have different ID's and there attaching methods to the clutch release arm are different, just get your hands on the right retainer and life is good!
    Also, there are two different finger lengths for the NP435 shifters; the one I am using is on top:
    Big thanks to my buddy Aron for loaning me the kerosene heater!
    Notice the notch for the CPS (crankshaft position sensor) on the stock 46RH bellhousing, there is no notch on the 435 bellhousing...yet...
    marked:
    1/4 way through...
    CPS notch cut, bearing retainer on, throwout bearing, release arm, and slave cylinder installed:
  10. #60 Re: Project "Tortoise" NP435 + 249 + D20
    Looking good man.
    Keep up the good work.
    Dirk
  11. #61 Re: Project "Tortoise" NP435 + 249 + D20
    Jun 2005
    Looks good Tim.
    Anthony
  12. #62 Re: Project "Tortoise" NP435 + 249 + D20
    Jan 2006
    West Michigan
    The trans was too tall to set on the ATV jack and then be slid under the ZJ, so I put it on the creeper to get it under the ZJ and then hoisted it onto the ATV jack.
    Keep in mind I am trying to do this by myself, lifting that 435 around under the vehicle is a pain!
    I rigged some rope to the trans from inside the ZJ down through the hole:
    On the inside were two jack stands with a piece of DOM running between:
    This way I was able to go back and forth raising it one notch at a time until I could slide the ATV jack underneath:
    Much easier to manuver this thing now!
    Had to cut a bit to get enough room for the top cover to clear:
  13. #63 Re: Project "Tortoise" NP435 + 249 + D20
    Northern, NJ. Syracuse, NY
    absolutely amazing..
    Paolo
    96 ZJ 5.2 L V8 w/ stuff
  14. #64 Re: Project "Tortoise" NP435 + 249 + D20
    Member PhilZJ's Avatar
    Aug 2005
    NJ
    Tim,
    This is a project and a half!!! Can't wait to hear it's up and running!
    Hope to see ya soon!
    If I lived about 500 miles closer, I'd be your gofer.
    Phil
    95ZJ 249>242; RE 4.5+2.5"ACOS & BB;Lost in Short Arm Land; 4.56; Superior; ARB lockers & Bull Bar;33"TruxusMT; ADDCOs F&R; Bilsteins; JKS sliders,rear TB n Discos;Kevins TB conversion;
    http://raskull.com/misc/golub.gif
  15. #65 Re: Project "Tortoise" NP435 + 249 + D20
    Jan 2006
    West Michigan
    Thanks for the encouragement! Phil, we’ll get out on the trail soon!
    Tunnel cut shot from the top:
    So this was a little red-neck, but I could not find the reciprocating saw (sawzall) ANYWHERE. I have not seen it around in years, but I had a brand new package of blades from who knows where so go figure. I rigged a recip blade to fit the jig saw and it actually worked great. The “proper” jig saw blades were too short for these cuts:
    The result:
    Getting the trans to mate to the engine was pretty tough. I’m by no means master mechanic so for some I am sure this is a breeze. Anyway, laugh at me if you must, but they are now mounted together! I got an engine hoist (Aron, thanks again!) and pulled the engine forward and dropped it down a little. This allowed more room to get at the bellhousing bolts (five of them) across the top, and actually get the angles right for the input shaft to slide in. Huge thanks to my buddy John for helping me get this accomplished, what a night and day difference it makes with two people! Oh yeah, and John’s wrenching skills >>> my wrenching skills
    With the engine mounted back in place, this is where the shifter column comes up through the floor.
    Center console pieces back in place… just like stock right?
    I’m pretty sure I will lose the VIC, but I’m not too concerned.
    Shot from underneath:
    Here are some good pictures showing where the starter will end up, the drivers side down pipe will have to get modified. It is after the flange for the manifold and I should have enough room for re-routing.
    -Tim
  16. #66 Re: Project "Tortoise" NP435 + 249 + D20
    Member Airmanwoody's Avatar
    Eielson AFB, North Pole AK
    Wow Tim.
    You sure the shifter will work in that location? I think you have an issue there. Even with a severe bend, I think it will be a challenge.
    I'm starting to think a NV3500, 3550, or 4500 would've been easier.
    I don't know how much you've got into this install, but a local guy up here got a brand new NV4500 with all required components to install in his YJ for around $1750, shipping was a bear up here, but it was only a few bucks more than getting the necessary adapters, bellhousing and stuff and buying a used 4500 from a junkyard.
    Glad to see parts going in the Jeep. I'm sure she's complaining about how long it's been since it's been rolling on it's own wheels.
    Woody
    1985 K1500 Burb, 6.2 Detroit, 1 tons and 38's in the works.
    94ZJ, AX-15, 5.5" Heinz 57 lift, Cladding removed, sliders, herc, rear mount tire carrier, thule basket with spots. 33" M/T's, 4.10's and a Detroit EZ locker SOLD
  17. #67 Re: Project "Tortoise" NP435 + 249 + D20
    :Maine:
    sweet build.
    great to see someone finally swap in a Toy rear.
  18. #68 Re: Project "Tortoise" NP435 + 249 + D20
    Senior Member Skyline's Avatar
    Jun 2006
    Westchester, NY
    Definately an "outside the box" type build.
    '96 GC Laredo V8; Tom Woods front U-Joint Shaft; Kevins sliders; 4.5" RE springs; Kevin's track bar conversion; JKS short arms, discos, and track bars; Pro Comp 16x8 mags with 305/70/16 Mud rovers.
    Support Our Troops!!!
  19. #69 Re: Project "Tortoise" NP435 + 249 + D20
    Senior Member BlaineWasHere's Avatar
    Michigan
    Tim I am glad you FINALY got the tranny bolted up. Good thing we have ONE friend (john) who knows what he is doing... becuase aron and I were not much help the night before.
    Give me a call on tuesday and let me know how things are going!
    Grand Valley State University
  20. #70 Re: Project "Tortoise" NP435 + 249 + D20
    Houston, TX
    NICE WORK! reminds me of some of the work I did on my 4wd swap, I think I really enjoy the build/fabrication the most on our Jeep addiction projects
  21. #71 Re: Project "Tortoise" NP435 + 249 + D20
    Anything since getting it bolted?
    Woody
  22. #72 Re: Project "Tortoise" NP435 + 249 + D20
    Livermore CA
    I like the old school way of installing the tranny, I have the same device for model T
    AW
    5.9
  23. #73 Re: Project "Tortoise" NP435 + 249 + D20
    Jan 2006
    West Michigan
    Thanks for the comments guys, she should be rolling soon!
    Woody, yeah the shifter is pretty far forward, but I’ll make it work somehow.
    So the mid-shaft joining the D20 and 249 was 3/8” of an inch too long. Yes, I need a real lathe, but this worked just fine! Powered by the drill, I was able to get a square cut while it was spinning.
    All finished!
    Yes, I went pretty slow and I’m sure it did not get above 900 degF to alter the heat treatment.
    Before, the D20 input bottomed out on the mid shaft and could not seat fully in the intermediate housing.
    After the cut, it seats perfectly!
    Spline engagement just perfect after the cut:
  24. #74 Re: Project "Tortoise" NP435 + 249 + D20
    Jan 2006
    West Michigan
    I started on the new cross member and transmission support. At first I tried to use the old ZJ rubber mount and bracket just because it was sitting there, but it ended up being too tall.
    It would just hang down too low:
    I ran to Napa and purchased a different mount (PN 620-1091) and this will work much better:
    This will make more sense when I have the finished support and cross member, but basically it is hard mounting to the rear of the transmission (on the Novak adapter) and the intermediate housing of the D20. This way that long combo will be supported nicely instead of just at one end.
  25. #75 Re: Project "Tortoise" NP435 + 249 + D20
    Very nice progress
