Well, I had a Hard arm kit installed back a couple months ago. I am at 5.5" of lift. Not very happy with the coils I installed.. Way to soft.
Any good suggestions where I can get some heavy duty 6" lift coils? And what shocks are you using? Part #?
Also Anyone over 6" of lift what are you using for a Track Bar? Im thinking about putting some 2" spacers I have on top of 6" coils. But The JKS Track Bar I have is only good up too 6" of lift it said.
Im currently also looking into new driveshafts at the moment So I can Center the rear axle in the wheel well. I am having some rubbing issues.
However jeep rides very well, no vibration issues..
Thanks
I have claytons LA kit with 7" RK springs with acos on top, I have an upgraded front driveshaft about the same length as stock and for the rear its a stock rear shaft just with a double crden joint at the tranny side, I have a 242 no SYE. no vibes at any speed. but I have cut the hell out of all my fenders and running 36" iroks, with claytons arms extended out as far as possible, and for my trackbar I have the jks one I just cut it and extended it out abouit 1.5" and sleved it inside and out
based on screen name, i would say he has a wj. don't go over 6-7" of lift. it is pointless and raises the COG. Are the springs you have the ones that came with the lift? If not, you might find out what springs Clayton could sell you.
I run RK's 6.5" springs on my WJ now. I am pretty happy with them so far. They have given me significantly more than the advertised lift height up front, and are about as advertised in the rear. That is running steel bumpers/winch, tire carrier, etc. The ride is a touch cushy, but stiff shocks would be better.
I run 26.5" RE monotubes up front, and 29 or 30" Bilstein 5150's with 255/70 valving in the rear. I have been happy with both, but adjustables may be better with the soft feel of the springs.
At this height, the JKS trackbar has served me well.
I do run a double cardon jointed d-shaft front and rear, with a SYE on the 242. I did have significant speed-dependant vibes before finishing up the SYE project last week.
I previously ran Tera 4" springs with a 2.5" spacer and find the RK springs superior in every way. I just can't speak to their longevity yet. If you want a truly "heavy duty" coil, contact Valley Spring works and they can custom make them to your specs.
I have 6" RK springs/shocks with my Clayton LA's. Got rid of the rear RK shocks and used MX6 set on highest setting since I ditched the rear sway bar and it works great. Driveshafts are from Eric at Six States-awesome work.
I know my build is far more mild than yours, but what do the 5150s ride like in the back? looking for a stiff ride here (stock lift/UC coils, planning on throwing in a .75" BB up front to level it all out) , and i was thinking about using the 255/70 valving on all 4 corners.Originally Posted by Pitch
I'd go for it. They should be stiff, yet forgiving for you... comfortable, yet a good performer.Originally Posted by Firestarter
I have the RK 6" springs and a 1" spacer on the front. I sit higher then Teraflex 4" springs + 2" BB, but a little lower then Pitch now. RK keeps changing their springs, so it's hard to compare them to older ones, like what I have.
The springs are soft and I run the Bilstein 5125 with the 255/70 settings. 26" in the front, 30" in the rear.
The JKS track bar works just fine. Get the uber-stiff track bar bushings from Kevin to make it better.
Yes, the ride is soft and the Jeep does sway a bit on the road, but I like the soft ride. Makes wheeling nicer, the rocks smoother and I can really flex! I have a center limiting strap on the front to keep it from unloading too much.
I do have the factory sway bars, just disco the front for wheeling.
Adjustable shocks might be your ticket. Stiff for the road, soft for wheeling.
You guys are great, thanks for all the good and helpful information, to help me make up my mind.. Think I may just keep the springs I have for now, try some 2-inch spacers, new adjustable shocks, and a new rear driveshaft for the right length..
