Chivo falls, Tucson Arizona 13 May
Thread: Chivo falls, Tucson Arizona 13 May
Results 1 to 2 of 2
  1. #1 Chivo falls, Tucson Arizona 13 May
    Member Airmanwoody's Avatar
    Eielson AFB, North Pole AK
    These were taken in May, but I haven't had my computer with the picture resizer to modify the pictures I've taken since April. So cut me just a little slack. I bent both my rock sliders (thanks to the fact I installed them without cutting the pinch seam) and hit the crossmember once. Oh yeah, I broke the steering stabilizer bolt on this run too.
    In case you were wondering I just drove the Jeep to Alaska so that's why I've been a little slack as well.
    Here's where I bent the sliders, if it weren't for them, I would've lost my mirror, and lots of other driver's side parts.
    I wasn't really getting traction well thanks to the off camber issue there.
    And I'm finally out of that mess.
    Showing the crossmember it's not left out.
    Finally a flex off between a Rubicon and a ZJ. You can decide for yourself who won.
    And for our funny pic of the trip. It was this 16 yr old's first time in a Jeep, and first time in a vehicle that was using 4x4.
    I found it funny that I went through that spot without a wheel coming off the ground and his was rockin'. If it weren't for the lockers we would've pushed it out of that spot.
    I wheeled a little hard seeing that I left AZ only two days after these pics were taken.
    Woody
    1985 K1500 Burb, 6.2 Detroit, 1 tons and 38's in the works.
    94ZJ, AX-15, 5.5" Heinz 57 lift, Cladding removed, sliders, herc, rear mount tire carrier, thule basket with spots. 33" M/T's, 4.10's and a Detroit EZ locker SOLD
  2. #2 Re: Chivo falls, Tucson Arizona 13 May
    Member Jsk8r1's Avatar
    Oct 2006
    Tucson AZ
    Hey, dont know if you ever check this anymore but i used to see you driving around DM and we practically had the same jeep i was wondering where you went, hows alaska treatin ya? sorry i never got to wheel with you when you were still here... heres a pic of my jeep
    ZJ is no more
    "GO"...
