Thread: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
Results 1 to 25 of 29
  1. #1 KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    A little over 2 and a half years ago I installed Kevin's Front Trackbar conversion and had been totally stoked. But I was finding out quickly that with larger tires and harder wheeling, the regular bushings weren't lasting very long at all, and quickly giving way to play in the steering caused by the loose bushings.
    I was dinking around Kevin's site one day contemplating ordering another set of the regular bushings when I saw that he had something new out, the Super Hard Durometer bushings. This peaked my interest, so I shot Kevin an email asking him what the scoop on these was. And from what Kevin said, it was exactly what I was looking for. A much harder bushing that would put up the rigors of heavy off-road use for longer periods of time than the soft squishy bushings. So I ordered up a set just before GSW.
    The install was, umm, easy. It's trackbar bushings, you take the old ones out and stick the new ones in! It is a bit trickier getting the new ones in this time around though since they are so hard. I found a vise VERY helpful. Also, be sure to lube the new bushings before they go in.
    Driving with the new bushings was definitely an improvement. The dead spot that I had in the steering got considerably smaller, and the steering just felt "tight" again. And the bushings have held up great to wheeling so far too.
    I think the Super Hard Durometer bushings are a definite worthwhile upgrade to Kevin's Trackbar Conversion (or to one of the of the bars that they will fit). And frankly, I think Kevin should just up the price of the trackbar conversion and include the new Super Hard Durometer bushings.
    The bushings, as well as Kevin's Trackbar Conversion, are available here: http://www.kevinsjeepparts.com/tbconversion.html
  2. #2 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Senior Member SCAMPER ZJ's Avatar
    Broomfield, CO
    Sweet Dave, I'll give Kevin a call. I've loved Kevin's track bar, but the steering has definitely gotten squishier over the last year or so, despite checking multiple times to ensure that everything is tight (track bar, steering box and brace, all the castles on the steering), so that may be why. I'll post up when I get them.
    '98 ZJ 5.2L with 7" KOR lift, 35x12.5 MT/R's
    D30HP 760 axles/u-joints with Ox in front, 8.8 with Detroit in rear
    Build and offroad pics at jeepsite.net
  3. #3 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Senior Member Jim311's Avatar
    Gainesville, FL
    I have them in my rig too.
    it's a hobby that rarely makes good financial sense.
    Quote Originally Posted by Alaska ZJ
    I can proudly say that I am one of the "OG's" of mutilating a perfectly good luxury SUV.
    1996 V8, Claytons, HP30/D44a locked, ARB, winch, WJ brakes and high steer, 33s, some body damage.
  4. #4 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    I put them in my WJ's track bar. Made a huge difference. The steering is much tighter. The JKS black poly bushings, which I replaced with Kevin's, felt soft in comparison.
  5. #5 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Oct 2005
    Raleigh, NC
    Sounds like I made a good purchase with these...hopefully installing them in a couple days.
  6. #6 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Aug 2005
    New Kensington, PA
    We installed the KOR trackbar conversion on my girls street queen 93' ZJ
    (3.5" RE based lift)
    And we found it is also notable that with the much tighter steering, death wobble resistance & all around tougher bushings you get very little increase in road noise/harshness
    Absolutely fantastic product all around
  7. #7 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Gainesville, FL
    I'd like to report that my front "super hard" bushings are officially worn out. I go through trackbar bushings pretty quick, though.
  8. #8 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Aug 2005
    New Kensington, PA
    How long did they last
    You grease them good when installed? (i actually put grease between the two pcs so it would squeeze out when tightened)
  9. #9 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Gainesville, FL
    What is there to grease? They've got a metal sleeve inside of them that the bolt runs through? I actually don't think they lasted as long as the stock ones that came with my JKS track bar strangely enough.
  10. #10 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Aug 2005
    New Kensington, PA
    theres no provision for greasing after installation
    So you need to get as much in as possible when your inserting them
    Wouldn't be hard to add a grease fitting where the two halfs meet though, if mine wear out prematurely thats what i'll be doing with the next set.
  11. #11 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Supporting Vendor GSSW Planner
    MallCrawlin Vendor
    KevinF's Avatar
    Phoenix, AZ
    Quote Originally Posted by Jim311 View Post
    Jim:
    I'm happy to send you (and anyone else who purchased them) a replacement set if they wear out. Though I've had a customer or two need another pair, this is a rarity that they are needing to be replaced at all. Just shoot me an e-mail.
    kevin@kevinsoffroad.com
    Thanks,
    Kevin
    Kevin's Offroad, The Grand Cherokee Specialists
    602-841-3355
    Phoenix, AZ
    www.KevinsOffroad.com
  12. #12 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Senior Member MUDDTRACKS's Avatar
    Warwick Rhode Island
    hey Kevin a little behind that was 2 years ago lol
    but always nice to see a vendor who stands behind there work
    I actualy broke your steering gear brace but i know that was from the way i wheel. So i modified a bit and works great now.
  13. #13 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Boulder, CO
    I had some a while ago that I bought through Kolak. They worked great when my axle wasn't centered (about 1-1.5" to the drivers side). It was like that for probably 6-8 months. When I finally got around to centering my axle, the bushing failed 2 weeks later. Kolak sent me a freee replacement. It too failed about 1 month later (after a trip to Moab). Replaced with the JKS ones and they have held up better. Something about my set up doesn't like them, which is too bad because they were much nicer then the JKS ones other then the durability for me
    -Ryan
  14. #14 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    MallCrawlin Vendor
    KevinF's Avatar
    Phoenix, AZ
    Quote Originally Posted by MUDDTRACKS View Post
    No problem, my friend. I didn't even notice the date when I posted.
    602-841-3355
    Phoenix, AZ
  15. #15 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    MallCrawlin Vendor
    KevinF's Avatar
    Phoenix, AZ
    Quote Originally Posted by ArloGuthroJeep View Post
    Now that's odd. Why do you think re-centering the axle would have anything to do with it...? Shouldn't matter at all. Strange.
    Kevin
    602-841-3355
    Phoenix, AZ
  16. #16 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Boulder, CO
    Quote Originally Posted by KevinF View Post
    Kevin
    No idea, I am considering trying it again now that I am running Claytons. Only thing I could think of is that the trackbar was centering the axle, but something else wanted to push it to the side causing stress to constantly be put on the bushing.
    -Ryan
  17. #17 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Senior Member 93ZeeJ's Avatar
    Oct 2007
    Littleton
    i was contemplating ordering these for the KOR track bar conversion im getting and after reading this i think im going to give them a try ( the KOR conversion is used and needs new bushings anyways)
    hopefully i dont have the same problem that you did Ryan... i dont think i will though.
    Matt
    December '09 ROTM
    93 ZJ 5.2 242J
    HP30-truetrac/D44a-Aussie 4.56
    6.5" Long Arms, 35"s
  18. #18 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    FWIW, we run the Super Hard Durometers now in my ZJ, Pam's ZJ, and my dad's ZJ, and all 3 have held up fine for a few years now. Pam's is the only one that gets DD'd, but they have held up very well in the year or so they've been in. They've been in my dad's ZJ for almost 2 years now, and it sees somewhat regular use, and then in my ZJ for a little over 3 years now.
  19. #19 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Dec 2006
    I believe the conversion I got from JSteves has the duro bushings, but not positive. Mine looked great when I installed the trackbar. No telling how long Justin had it in use.
    Jim Karlin
    Project Big Red Jeep
    A bunch of KOR stuff
    GSW 2010 Pics
  20. #20 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Boulder, CO
    Quote Originally Posted by 93ZeeJ View Post
    I wouldn't worry about that. I think I was the exception, not the rule. I am the only one I have heard of to have problems with them.
    -Ryan
  21. #21 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Dec 2006
    Ryan, duro bushings weren't the only ones you were eating like candy - I seem to remember you going through CA bushings like water too.
    Jim Karlin
    GSW 2010 Pics
  22. #22 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Boulder, CO
    Steep control arm angles do that
    -Ryan
  23. #23 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Mountain View, California, United States
    I've had mine for a few months now. I went to 5" springs and the DW came back. (I've ordered LA's to correct, just waiting for them to ship)
    I had the other style Kolak sells for over a year before that and these are way stiffer and have calmed the beast.
    Just an fyi, if your rocking the other bushing from Kolak which require replacing the JKS sleeves and are going to swap back your going to need your original JKS sleves for these bushings. I stuipdly tossed mine when I did the swap over a year ago and had to order a new set as these dont come with sleeves. (For WJ owners, dont know if that is the same for ZJers)
    Will
    99 4.0 DubJ 35"MTRs/ Custom IRO LA's/ Currie 9" housing/ Yukon 4.88 Gears 35 spline Grizzly Rear Lockers and ARB Front.
    The Hookup Build http://www.mallcrawlin.com/forum/showthread.php?t=12701
  24. #24 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    MallCrawlin Vendor
    KevinF's Avatar
    Phoenix, AZ
    Quote Originally Posted by WJJEEPIN View Post
    Did you have the toe-in readjusted? If not, that's probably the cause more so than bushings. Also, did you replace tire/wheel combos at the same time. Sometimes that is enough to set it off as well, particularly if the size of the contact patch has changed.
    Also, unless you know about some SUPER-SUPER-DUPER durometer bushings that Nick sells that I don't know of, our SD bushings would be the stiffest on the market. If you compared a set of the SD bushings next to the Energy Suspension (that Nick sells) and the Daystar bushings (that come in most aftermarket track bars), you'd notice a HUGE difference. The Daystars are around 43D, the ESP around 48D if memory serves, and the SDs around 61D. Here is a link to the Rockwell scale of hardness if you're curious how these are rated: http://www.calce.umd.edu/general/Fac...ss_ad_.htm#3.1
    Kevin
    602-841-3355
    Phoenix, AZ
  25. #25 Re: KevinsOffRoad.com Super Hard Durometer Trackbar Bushings
    Napa, CA
    Kevin
    I think if you re-read his post you would see that he was stating that your bushings are harder than the ones Nick sells.
    98 ZJ 5.2, 4.5" RE LA, HP30 w/tru-trac, U-Turn steering, ARB Front, Kevin's rear bumper, 35" KM2's
There are currently 5 users browsing this thread. (0 members and 5 guests)
