Got A Real Grinder!-Gold Dust Build - Page 5
Thread: Got A Real Grinder!-Gold Dust Build
Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 176
  1. #101 Re: Got A Real Grinder!-Gold Dust Build
    I have left foot braked and throttled up, but didn't notice much of a difference in the anti-squat, seems neutral, but the increase in ground clearance is very obvious.
    Having the LCA's triangulated, for a true double triangulated rear suspension, is noticeable when driving around town. You don't get the "tail wag" as you go around corners, it feels very solid and stable.
  2. #102 Re: Got A Real Grinder!-Gold Dust Build
    Highlands Ranch, Colorado
    I got a peek at John's and Tyler's projects on Sunday. Damn, good stuff. Tyler's bumper is pretty sweet and I like the integrated rock sliders on John's.
    I agree on the double triangulation of the rear and how great it drives. I also think that is why John is not getting any additional squat because the upper arms are keeping the axle from rotating.
    Nice work.
  3. #103 Re: Got A Real Grinder!-Gold Dust Build
    Mar 2011
    Lakewood, CO
    Axle and frame end of LCA'S were raised a similar amount and are 7" longer.
    Sent from my SCH-I605 using Tapatalk
    01 WJ
  4. #104 Re: Got A Real Grinder!-Gold Dust Build
    Skid plate fabricated and installed.
  5. #105 Re: Got A Real Grinder!-Gold Dust Build
    Mar 2010
    Knoxville, TN
    Looks great John. Did you have to change anything with the lower link brackets on the axle?
  6. #106 Re: Got A Real Grinder!-Gold Dust Build
    Thanks! Yes, new tabs were installed on the rear axle.
    The tabs are flush with the bottom of the axle and angle "in" to match the body side LCA tab angles, on the new cross member. The new LCAs are full width on the axle side and 8" apart (inside measurement) on the cross member to clear the drive-shaft. Gives it some nice triangulation.
  7. #107 Re: Got A Real Grinder!-Gold Dust Build
    Rear bumper needed a little work to keep the hatch from hitting it.
  8. #108 Re: Got A Real Grinder!-Gold Dust Build
    I have been driving it around a little more and it feels really tight and solid. Hopefully this will cure my Lambo door syndrome. If not it's Interior cage time!
  9. #109 Re: Got A Real Grinder!-Gold Dust Build
    Sac
    wow, nice work! looks real clean. how are the upper arms attached to the unibody side, the old claytons brackets?
    the rear ds wont hit the rear cross member at all?
  10. #110 Got A Real Grinder!-Gold Dust Build
    Yes upper arms attach to Clayton's original UCA mounts on body . Drive shaft does not hit cross member tested at full drop and verified on first run at GSW today
  11. #111 Re: Got A Real Grinder!-Gold Dust Build
    Exit of Pritchett Canyon everything worked great!
  12. #112 Re: Got A Real Grinder!-Gold Dust Build
    Radiator support got pushed up a good 1" and I couldn't close the hood.
  13. #113 Re: Got A Real Grinder!-Gold Dust Build
    Doing some fixing.
  14. #114 Got A Real Grinder!-Gold Dust Build
    All fixed up, much more stout.
  15. #115 Re: Got A Real Grinder!-Gold Dust Build
    2nd floor Yuma, AZ motel
    Looking good John!
  16. #116 Re: Got A Real Grinder!-Gold Dust Build
    Mar 2010
    Knoxville, TN
    Nice work. I'm probably due for this repair myself
  17. #117 Re: Got A Real Grinder!-Gold Dust Build
    Thanks guys, this should keep the front straight.
  18. #118 Re: Got A Real Grinder!-Gold Dust Build
    Now if you could just plate your B-pillars with radiator supports you'd have something!
  19. #119 Got A Real Grinder!-Gold Dust Build
    That's part of the upcoming winter project, some internal supports!
  20. #120 Re: Got A Real Grinder!-Gold Dust Build
    Jul 2014
    Saint Louis, MO
    Bump, any new progress?
  21. #121 Re: Got A Real Grinder!-Gold Dust Build
    My Lambo doors keep getting worse. When shut, the top of the doors have more than an inch gap between the weather stripping in places. It's time to once again straighten the B-pillars and build a cage to keep them in place.
    First thing, remove the headliner and all the plastic trim pieces from the A-pillar to the D-pillar. It's pretty easy, just be patient with all the little clips and screws.
    I wasn't surprised to see that both of the B-pillars and C-pillars are twisted and the metal is cracked in several places.
    Name:  B-pillar twist.jpg
Size:  16.1 KBName:  C-pillar twist.jpg
    Straightened up the B-pillars, using Tyler's winch.
  22. #122 Re: Got A Real Grinder!-Gold Dust Build
    jsteves's Avatar
    Fort Fun
    So that's what a winch is for...
  23. #123 Re: Got A Real Grinder!-Gold Dust Build
    Holy cow, I thought my unibody was jacked, nowhere close to that bad!
  24. #124 Re: Got A Real Grinder!-Gold Dust Build
    Wow. that thing is tweaked!
  25. #125 Re: Got A Real Grinder!-Gold Dust Build
    Quote Originally Posted by JohnBoulderCO on 06-30-2014
    well 17 months later...
    Glad to see the cage going in. Are you still planning the exo/internal hybrid?
