Clayton Off Road Hard Arm 4-Link Long Arm Suspension - Page 5
Thread: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
Page 5 of 5 FirstFirst 12345
Results 101 to 123 of 123
  1. #101 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Apr 2006
    Canada, somewhere
    can you fit the rear truss on with the upper control arm brackets?
  2. #102 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Fair Oaks, CA
    thanks guys. You rock!
  3. #103 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Feb 2008
    Exeter, RI
    Quote Originally Posted by canadian_driver View Post
    No.
  4. #104 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Apr 2006
    Canada, somewhere
    i didn't think so, but i couldn't remember
  5. #105 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Jan 2010
    Ive got the same kit and love it!
  6. #106 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Member 97limitedzj's Avatar
    Mar 2010
    OR
    Hey guys what can be done to prevent or install the kit so it doesnt mangle your floor pan?
    97 5.2
    still building
  7. #107 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Bumpstops.
  8. #108 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Cut out the part of the floor pan that gets hit...
  9. #109 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Feb 2008
    Exeter, RI
    It only mangles them once.
    But seriously, I dropped my bumpstops 3" (more like 2 3/4") and at full compression the upper arms are not quite touching the floor pan. I suppose actual results also depend on your rear axle. For example, with a 14 bolt . . .
  10. #110 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Mar 2010
    OR
    okay cool ill just have to get my bumpstops the correct length then!
    97 5.2
    still building
  11. #111 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    It's in need of new bushings in a couple spots, but other than that the kit has been awesome.
  12. #112 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    jsteves's Avatar
    Fort Fun
    I think I have yet to hear someone unhappy with claytons
  13. #113 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Mar 2008
    WI & AZ
    The Clayton kit in our ZJ rides and works so well that next winter when we come back down to AZ, we're leaving our well built JKU Rubicon in the garage and bringing the ZJ. People can't believe what it can do. The ride and comfort are also better.
    97 ZJ 5 1/2" lift, Claytons, 488 gears locked F&R, ARB front, Proto-Fab rear
    2010 JKU Rubicon, lifted, alloys, RCVs, sleeved, gusseted, PSC, 513s, 35s, bumpers, winch, Superchip. SOLD
  14. #114 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Quote Originally Posted by 97limitedzj View Post
    I just let it "self clear"
    It mangled up what's under the rear seats, but what's it matter? Was a noisy process but when it was done, no more banging. On the next build I'm using the same Calyt's kit on, I'm going to bang the floor up first with a BFH.
  15. #115 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Member dyn0mitemat's Avatar
    Jun 2011
    ↑↑ This side up ↑↑
    Sorry for bumping an old thread, but I figured it'd be better than making a new one.
    I've searched around and couldn't find anything.
    Does anyone know what angle the upper arms in the claytons rear come off of the frame brackets?
    I'm copying this kit, and have the axle all about done minus the upper link mounts needing welded on the truss and frame brackets. I mocked it up, and found they're right around 22.5*, which is about half of what I need according to what I read. I know the claytons kit doesn't fall under the 'perfect' conditions as far as link geometry, but that it does work well. So I was wondering if I was in an accecptable range or if I needed to push the frame mount for them towards the axle some.
    My lowers will be 38-40"ish, depending on where the axle ends up in the wheel well, and the uppers I'm currently figuring out.
    Thanks in advance for any help.
    And a BIG THANKS for the writeup, as I used A TON of it for fabbing up what I have.
    Build thread
  16. #116
    Good luck getting exact info like that to blatantly copy a kit.
    Sent from my T-Mobile G2 using Tapatalk
  17. #117 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Jun 2011
    ↑↑ This side up ↑↑
    Guess I better just quit while I'm ahead and sell the jeep then seeing as I'm copying everyone else lifting it and throwing bigger tires under it
    I'm just asking for a few specs man, chill out. It's not like I'm doing this to sell kits. If I had the cash I would buy it, but I don't, so I do the next best thing.
    Build thread
  18. #118 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Then do the next best thing and search out a link calculator and figure it out.
  19. #119 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Jun 2011
    ↑↑ This side up ↑↑
    Thats what I'm working on, like I said everyone's saying to aim for 40*ish but I don't see how the hell thats possible with the uppers mounted right above the lowers (frameside)
    Build thread
  20. #120 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Quote Originally Posted by dyn0mitemat View Post
    This really isn't that difficult if you are competent enough to be designing and building your vehicle's suspension. It's not going to happen with single-triangulated long arms on a ZJ. That means significantly higher loads on the joints/ mounts, but it apparently works well enough for the kit. You'll have much better results overall with a double triangulated setup like your future sig suggests you intended to do anyway. Search for more info rather than cluttering up a thread.
  21. #121 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Nov 2010
    hanover, pa
    Quick question im in the middle of installing the shock conversion now how much weld is run around it?
  22. #122 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Nov 2010
    hanover, pa
    we decided to weld it in the corners and one along the center
  23. #123 Re: Clayton Off Road Hard Arm 4-Link Long Arm Suspension
    Aug 2007
    Paris IL,
    Geez whats up with all these hackers!
    98 slate 5.9
    Rolled-rebuilding/upgrading.
