super easy 4.0L transmission cooler upgrade! - Page 2
Thread: super easy 4.0L transmission cooler upgrade!
Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 102
  1. #26 Re: super easy 4.0L transmission cooler upgrade!
    Sep 2006
    State of confusion
  2. #27 Re: super easy 4.0L transmission cooler upgrade!
    Apr 2006
    Canada, somewhere
    is everything plumbed already to stick a tranny cooler in or would i need to do all that
  3. #28 Re: super easy 4.0L transmission cooler upgrade!
    Senior Member Sudz's Avatar
    Pennsy
    Quote Originally Posted by ZJ Limited
    Here's mine installed!
  4. #29 Re: super easy 4.0L transmission cooler upgrade!
    Houston, TX
    Quote Originally Posted by canadian_driver
    I can't remember what your runnin but if you have a ZJ 4.0L the plumbing is already there and should be a straight swap like my pics
  5. #30 Re: super easy 4.0L transmission cooler upgrade!
    Apr 2006
    Canada, somewhere
    any pictures of all the lines?
  6. #31 Re: super easy 4.0L transmission cooler upgrade!
    Houston, TX
    that last pic in my first post is the best one I have right now of the lines but you can take a look behind the grill and see yours commin off of the stock cooler. the 4.0L has the input and output on the same side, the v8 has them one on the side and one pointed down
  7. #32 Re: super easy 4.0L transmission cooler upgrade!
    Aug 2005
    New Kensington, PA
    I converted my stock trans cooler to a P/S cooler & installed a larger tranny cooler beside it & it worked sweet
    alot of people have no idea how hot a powersteering system gets especially when cranking a locked set of big tires back & forth
    Quick note, always run the output line from the tranny to the rad first, then from the rad to the aux cooler (i believe the output line from the tranny goes into the bottom of the rad, then the top tranny line would go to the cooler, but i always just have someone start the engine with the trans in nuetral to check which line spits fluid)
    That way the 200 degree rad cools the fluid some then the aux cooler cools it down further before sending it back to the trans
    Since our chrysler trannys take ATF +3 / +4 can you run straight amsoil ATF without any issue?
    Or are you putting additives in?
  8. #33 Re: super easy 4.0L transmission cooler upgrade!
    Quote Originally Posted by gonecheenin
    Straight Amsoil works great, that is what I am using my my Hybrid 42/46RE trans.
  9. #34 Re: super easy 4.0L transmission cooler upgrade!
    Junior Member Marcelo Carvalhal's Avatar
    BRASIL
    Hi JEEPS, escuse me about the ask in this tread, but i target experts here
    Somebody know wath is the part number off the SOLENOIDS FROM 44RE TRANSMISSION, i think is this mine..... ZJ 93/93 4.0 WITH NP 231
    thanks a lot!!
    93 ZJ LAREDO 4.0 / NP231 / - WITH 3,5" PROCOMP /SHORT ARMS /PRO COMP SHOKS / BF MUD 32" /SIDE GUARD ALUMINIUM / MOPAR LIGHTS /LEATHER SEATS /08"WHEELS ETC.....FOR LIGHT TRAILS
    http://www.4x4brasil.com.br/forum/sh...ad.php?t=11183
  10. #35 Re: super easy 4.0L transmission cooler upgrade!
    Houston, TX
    I don't know about ones in BRASIL but only 93 ZJ maybe AW4 but mostly 42RE NOT 44RE
    look at transmission handle
    if it is P,R,N,D,3,2-1 ==== AW4
    if it is P,R,N,D,2,1 ==== 42RE
    let us know which one and maybe help you find parts
  11. #36 Re: super easy 4.0L transmission cooler upgrade!
    Aug 2005
    New Kensington, PA
    Sweet, gonna have to flush mine with the good stuff then!
  12. #37 Re: super easy 4.0L transmission cooler upgrade!
    Well when the time comes hit me up I can hook you up with a great price.
    Dirk
  13. #38 Re: super easy 4.0L transmission cooler upgrade!
    Aug 2005
    New Kensington, PA
    Can't imagine that stuff is cheap to ship and i can get it locally
    But gimme a quote anyway, i'm all about keeping the small buisness up & running
  14. #39 Re: super easy 4.0L transmission cooler upgrade!
    I do not ship from my house. It is drop shipped from one of 3 distribution centers. Trust me the shipping is super cheap actually.
    I will PM you some pricing. No need to buy it locally I can hook you up with a better price even WITH the shipping.
    Trust me. The MC crowd gets GREAT pricing from me.
    Dirk
  15. #40 Re: super easy 4.0L transmission cooler upgrade!
    Just checked and shipping on a case of ATF is only about $8.50 depending on exact location.
    Dirk
  16. #41 Re: super easy 4.0L transmission cooler upgrade!
    BRASIL
    Quote Originally Posted by DJJordache
    ..i wrong just one number
    You are completly right!!!!! is the 42RE..
    I work in a JEEP dealer since 1994 at 2003, salesman and service, and make some shit at my cars
    But now i do not have every information to do everything, and this problem with my transmission is completly strange, it's start ocasionaly, but now, do not work any more on th right way, only like be at LIMP MODE, and that way to see whats is the code off defect is not work, the light off OVERDRIVE buton do not blinks
  17. #42 Re: super easy 4.0L transmission cooler upgrade!
    BRASIL
    SR.. DJJ....stil waiting for your suportt SR.
    part numbes
  18. #43 Re: super easy 4.0L transmission cooler upgrade!
    Houston, TX
    sorry about that! I guess I forgot, or busy...
    the ones I found with their description for the 93 42re are
    4617463 SOLENOID with wiring and 8 prong connector, with overdrive and lock up valve
    4617210 SOLENOID, Transmission, Governor Pressure 2 prong connector
    those are the only 2 I saw in the parts list, hope that helps
  19. #44 Re: super easy 4.0L transmission cooler upgrade!
    BRASIL
    THANKS A LOT...
  20. #45 Re: super easy 4.0L transmission cooler upgrade!
    BRASIL
    Hi every......BAD NEWS from my TRANSMISSION, remenber whem i saied about the noise...TRECK..TRECK, e some times the transmission works good..i find de son of......
    Is the TMC or TCM, the nois come from it, i think have to be replaced, will try remanufactere it.......
    Any sugstions.really have to be replace, is better???
  21. #46 Re: super easy 4.0L transmission cooler upgrade!
    BRASIL
    Quote Originally Posted by Marcelo Carvalhal
    http://www.4x4brasil.com.br/forum/at...6&d=1164907594
    http://www.4x4brasil.com.br/forum/at...7&d=1164907711
    http://www.4x4brasil.com.br/forum/at...8&d=1164907758
    WHY NOBODY ANSWERS ME???
    Hei mista DJJ...
  22. #47 Re: super easy 4.0L transmission cooler upgrade!
    Houston, TX
    Hei mista DJJ...
    well for one I have no idea what is wrong, sorry. and second this thread is SUPPOSED to be about transmission coolers, you should make a new thread so more people can see it and make a comment on it if they know how to help, good luck!
    ps: I like that picture
  23. #48 Re: super easy 4.0L transmission cooler upgrade!
    Louisiana
    i was not aware the 42re had a seperate TCU. i though only the AW4 does??
  24. #49 Re: super easy 4.0L transmission cooler upgrade!
    Houston, TX
    Quote Originally Posted by LouisianaZJ
    I didn't think it did either but I never looked into it..... BUT if it does then I'm gonna get BrettM so make one of his electrical shifter kits for it
  25. #50 Re: super easy 4.0L transmission cooler upgrade!
    Member Lifetime Supporter AQHACowboy's Avatar
    Oct 2005
    Stedman NC
    DJ,
    Did you ever find the part number for the filter mount?
    Danny
    2000 WJ Laredo (Daily Driver)
    4.0 I-6 4x4 186,000+ miles and still going strong.
    2007 Tahoe (Wife's truck)
    Fully loaded
