Thread: super easy 4.0L transmission cooler upgrade!
Page 5 of 5 FirstFirst 12345
Results 101 to 102 of 102
  1. #101 Re: super easy 4.0L transmission cooler upgrade!
    Quote Originally Posted by Coyote View Post
    Do you by chance have the model number to the cooler you got ? I'm prepping for Tucson AZ heat and want to give my transmission all the help it can get.
    The B&M cooler part number of that size is listed in the first post of this thread.
  2. #102 Re: super easy 4.0L transmission cooler upgrade!
    true and I'm still running the same cooler right now.
    BUT I'm going to swap it out for this one: Derale 13503
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    the rated GVW BTU rating is MUCH higher on this Derale unit than the B&M one for about the same size and it should mount up about the same way as I did the B&M one
