WJ Tie Rod Flip and Max Droop for Drag Link - Page 3
Thread: WJ Tie Rod Flip and Max Droop for Drag Link
Page 3 of 3 FirstFirst 123
Results 51 to 72 of 72
  1. #51 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Member theksmith's Avatar
    Sep 2007
    Phoenix, AZ
    Quote Originally Posted by theksmith View Post
    i thought the lift would bring them out of parallel and this would help put them back? are you saying i would be better off not doing anything to the steering then after a 4.5" lift (driveability wise, not clearance wise obviously)??
    oh wait, I'm thinking of the inverted Y on my XJ, on the WJ it stays parallel when you lift, i get it!
    is there a shorter pitman arm that would make up for flipping the trackbar on the knuckle end?
    so if my main goals are driveability and not limiting flex, sounds like i should put beefy bars in, and put the chevy TRE on the pitman end and call it good?
  2. #52 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    May 2010
    Charlotte,NC
    Digging up an old thread.
    Is anyone using the
    WJ Over the Knuckle Tie Rod Kit from Iron Rock?
    http://www.ironrockoffroad.com/Merch..._Code=IR-WTRFK
    2000 WJ Grand Cherokee, Clayton 4.5" Long Arm Lift, Tom Woods Front Driveshaft, Rear Spartan Locker, 33" MT's, 15" Cragar Soft 8's.
  3. #53 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Quote Originally Posted by JakeMate View Post
    Is anyone using the
    Yup for years now. What do you need to know?
    Will
  4. #54 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    May 2010
    Charlotte,NC
    Well it sounds like it's holding up. What about installation? Did you use a pickle fork? I found another technique for removing the tierod ends from a member on Jeepforum:
    "A method that has worked 100% of the time for me and is a ton easier then a pickle fork, is to unbolt the TRE most of the way (leave the castle nut barely on there). Then on the knuckles there is a flat spot next to where the steering ends connect. Wack that with a BFH 6+ times. Depending on how hard you hit, it'll drop out eventually." ArloGuthroJeep
  5. #55 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Boulder, CO
    I would like to think I am a member here too
    -Ryan
  6. #56 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    May 2010
    Charlotte,NC
    At least I quoted you Eat shit.
  7. #57 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    I've done both. Whatever you have will work.
    Yeah I got it in the mail when I got home from the hospital after my son was born and that was July 07. No complaints. Just make sure if you take it to a shop to get aligned that all the bolts are there when u leave. I noticed a month later that the didn put on the locking bolts after they were done.
    Will
  8. #58 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    May 2010
    Charlotte,NC
    Speaking of alignment, I guess the only thing that could change would be the toe setting? That one is pretty easy to set with a tape measure.
  9. #59 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Yup, I went in for caster and they fine tuned everything.
    Will
  10. #60 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    So a heads up. IRO has a drop bracket/cross memeber for the track bar (for their JK axle swap). It will drop the track bar 3-4". ( I will know on Monday)
    I will accompany this with their Pitman arm drop 1" which SHOULD get me back to near parallel. I will follow up with pix and measurements and driving feedback.
    Fingers crossed it corrects the stupid bumpsteer and my wife will be cool driving the rig again....
    Will
  11. #61 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Jan 2009
    Brighton, Colorado
    Is this flip something I should be considering as part of my planned KOR 2.75" lift? I know everything helps usually, but with such a small lift, are the gains worth it?
    Also, if I did do this, I would also working to eliminate the bump steer it causes, so I've contacted IRO about thier drop bracket/cross memeber from thier WJ/JK axle upgrade kit. I would also get thier 1" drop pitman arm if there is still any bump steer.
    Thanks for the input guys.
    - JD
    Rocky Mountain Expedition Club
    "Getting "Lost"..........one trail at a time."
    2004 WJ- Totally stock...for now...
  12. #62
    Mar 2010
    Knoxville, TN
    No to all of the above
  13. #63 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Jan 2009
    Lufkin, TX
    Quote Originally Posted by Backwoods Rambler View Post
    With only 2.75" of lift, the changes in your suspension geomotry (sp?) are so neglageable that yes the mods would help, but would be pointless.
    No longer a JeepTech01 fan.
    Just boobs.
    And biggoofy.
  14. #64 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Jan 2009
    Brighton, Colorado
    Well, I guess I'd have to disagree now that my steering stabilizer is bent and my tie rod has scratches on it from my recent trip through Poison Spider in Moab.
    I just heard back from IRO, here's what they said:
    Quote Originally Posted by Josh @ IRO
    Hi JD,
    We don't have that particular part on the website by itself. If you are interested, it is $129.99 and you would have to call to order it. Please let me know if you have any other questions. I'll be happy to help! you can king of see the backside of the trackbar subframe here: http://www.ironrockoffroad.com/Merchant2/DSC001211.jpg
    Thank You,
    Josh Ruppert
    josh@ironrockoffroad.com
    952-210-7185
    - JD
  15. #65 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    At that lift it wont be worth your money or time. i wouldnt touch that till you get to some adjustable arms and 4" of lift.
    I have the 6" lift and with the flip I got consistant bump steer from 4" of lift and short arms up to 6" and long arms.
    I will know how the kit from IRO corrects it soon.
    I just picked up the TB drop from IRO and a 2" pitman arm drop, it is at the shop getting welded up (rear axle) so I have yet to take it for a spin on the new setup.
    That being said the TB drop from IRO will NOT work if you have their kit and the axle pushed fwd. i have their high clearance long arms and its pushed fwd 3/4 to 1" and it hits their iron y bracket.
    **EDIT** You can do their tie rod flip with out mucking with the Trac-bar so your geometry will be un changed.
    Will
  16. #66 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Jan 2009
    Brighton, Colorado
    I suppose I'll just stick with a SS relocation kit.
    I saw that kit; I don't like heims, so I won't run it.
    - JD
  17. #67 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    They work great but To each their own.
    Just get the JKS HD tube from KOR and call it done cuz At 2" lift with 31 your going to bang the SHIT out of everything.
    Will
  18. #68 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Jan 2009
    Brighton, Colorado
    Just get the JKS HD tube from KOR and call it done.
    Already planned along with a RSS front & rear diff covers.
    Yup, that's why I'm getting a 3" lift (KOR discontinued the 2.75" kit, so now I'm thinking IRO 3")
    - JD
  19. #69 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Boulder, CO
    Won't be getting a RSS diff cover for the D44a - only one that makes one for that axle right now is BTF I believe.
    -Ryan
  20. #70 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Jan 2009
    Brighton, Colorado
    Good to know
    - JD
  21. #71 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Got the IRO TB and PA drop in and running. This is the best it has driven since i flipped the drag link up top. The bumpsteer got worse when I swapped the rubi express for the softer bilsteins. Highly recommend this setup for anyone with bumpsteer.
    Will
  22. #72 Re: WJ Tie Rod Flip and Max Droop for Drag Link
    Los Angeles, Ca
    Has there been any update on the knuckle side TRE on the drag link or is the RHD TRE from the dealer still the only option for this particular mod?
    Clayton's 6", KM2 33s, 242HD Swap, 4.56s
