Thread: Double Cardan Rebuild
Results 1 to 25 of 29
  1. #1 Double Cardan Rebuild
    Senior Member Grand Slam West Planner PassRunnerZJ's Avatar
    Grand Junction, Colorado, United States
    This build or rebuild was brought on by my ZJ having that constant squeek when driving and it has 159k miles, I narrowed it down to the front drive shaft by removing it and the squeek went away I figured it must be time to rebuild the double cardan (DC) since replacing the front u-joint didn’t do anything to solve the squeaks. Here goes...
    Parts needed:
    Three (3) u-joints to fit your application – yea I know you only really need two, but if you mess up it is good to have a spare and you should have a spare u-joint anyway
    One (1) Center yoke support kit with either the one with a dust cover—not recommended by the driveline shop I picked the parts up from OR the needle zerk greasable one w/metal splash ring
    List of tools I used:
    8” or so vice
    Various sockets to push and allow caps to slide out of axle ears (same as you use to change a u-joint)
    Hammer
    Safety glasses
    Small screwdriver
    Medium screwdriver
    High Lift Jack handle – more leverage on the vice
    Needle nose pliers
    Vice Grips
    Penetrating oil
    Grease gun w/needle adapter
    '98 ZJ, 33s and an XJ drivetrain, Iron Rock Offroad 4.5" Critical Path suspension lift, D44i, custom rear bumper w/tire carrier, KOR ZJ Radiator Support
    '95 ZJ - after 208k and the fun gear swapped to the '98, now it gets setup to sell
    '01 WJ, T/C skid, K&N replacement - wife's DD
    '04 Honda Civic - my DD
  2. #2 Re: Double Cardan Rebuild
    • Mark/scribe each end of the driveshaft so you can put it back on in the same way it came off
    • First remove the drive shaft if it isn’t already off the Jeep
    • Apply a wrap or two of blue painters masking tape around the open cap ends of the front u-joint
      • Compress the drive shaft and clean up the grease that comes out of relief hole so that it will be less of a mess later
    • Clean up the loose dirt and mud
    • Soak the caps with some kind of penetrating oil for a day or longer if you have time – this saves a lot of time and frustration during the disassembly process
    • Scribe side of the DC “H” to drive shaft so that you can realign everything when you put it back together
    • Start by removing the u-joint that connects to the transfer case like you would for a normal u-joint on the “H” part of the DC
      • Using a socket a little smaller than the size of the cap apply pressure in the vice or press to break them free
    • You can’t push the cap out as far you normally can on a single u-joint due to the binding that the center yoke causes
    • Use your Vice Grips to turn and pull the cap off the end that is sticking out
  3. #3 Re: Double Cardan Rebuild
    • Once this is off use a smaller socket on the shaft of the u-joint to push it back the other way and out the other side
    • After both caps are off the “H” you can remove the yoke by turning the u-joint so that each end without the caps comes out
  4. #4 Re: Double Cardan Rebuild
    • Put the yoke out of the way
    • Remove the second u-joint from the H” in the same manner that you removed the first one being careful not to drop it or anything else on the center hub of the yoke bearing
    • Now remove the u-joint from the axle part of the DC as you would any other u-joint
    • Remove the old rubber dust cover from the center support bearing part of the H
      • Work a small screw driver around the circumference of the dust cover getting it between the metal on the back of the cover and the metal of the center yoke support with light taps from a hammer, it should pop off as you are working around it
  5. #5 Re: Double Cardan Rebuild
    • Clean the dirt and old grease from the center support bearing including the hole where the spring goes in
    • Press the center yoke splash ring keeping the beveled end towards the center bearing support unit
      • I used a large socket and hammer without any problems with easy blows
  6. #6 Re: Double Cardan Rebuild
    • Clean up the insert area for the u-joint caps and I applied a thin layer of grease
    • Remove the caps to the u-joint and add a healthy amount of grease in the cap to the bearing and pack them in with your finger
    • Push the first cap in on one side of the axle u-joint ear about half way
    • Insert the u-joint to the first cap
      • Make sure that your zerk hole points toward the driveshaft and the axle ear rotates towards the zerk
    This image for reference of zerk hole, don't install the zerk until you are done
    • Seat the cap even with the ear of drive shaft or a little more
    • Start the second cap by hand and if it goes in far enough slide the u-joint part way into the second cap without taking it all the way out of the first one
    • In the press seat the second cap
    • Install snap ring on one side, then push the other side over until you can set the other snapring
      • If you can’t push it over enough to install the opposite side snap ring odds are that a pin dropped. Take the time to push it apart and replace the bearing if you put a lot of pressure on the caps.
    • Once the snap rings are installed check for proper movement, it might be a bit tight but it will loosen up as the centrifugal force pushes the caps out
    • Now the fun starts
    • Work the H around the shafts of the u-joint with banging u-joint’s axle surface
      • Make sure that the support bearing shaft is pointing away from the drive shaft and installed u-joint
    • Start one of the caps into one side of the H and slide the H onto the u-joint
    • While holding the H and cap on the u-joint press the cap into its seat
    • Turn the axle over and insert the other cap in the other end and slide the u-joint and drive shaft into the cap without taking it all the way out of the other cap to avoid dropping a bearing
    • Seat the caps and clips, same as above
  7. #7 Re: Double Cardan Rebuild
    Starkville, MS
    What is the part number of that center yoke support kit? How much did it cost? I broke the ear off of mine when I was replacing a u-joint not long ago. I was dreading replacing it because I thought the dealership wouldn't sell it alone. I figured they would sell it with the whole driveshaft.
    Good article. Wish I used a vice to take the u-joints off. Heavy blows with a ballpeen hammer and sockets work, just not as well. I wish I wasn't a poor college student....
    -RC
    97 ZJ 5.2 V8 with a 231 and a BB.
    "What you do in life echoes in eternity"
    -Gladiator
  8. #8 Re: Double Cardan Rebuild
    • Yoke time
    • Open the needle zerk on the outside of the yoke and pre-grease the bearings while holding the rubber cap over the spring that holds the bearing in
    This image is to reference the needle zerk you should use, you are not at this point yet
    • Note: Make sure the other needle zerk in the center of the yoke is closed as there isn’t any access to this after it is assembled
    • Remove the caps from your second u-joint and pre-grease them like you did earlier or with more grease
  9. #9 Re: Double Cardan Rebuild
    • Remove the rubber cap from the center of the yoke and transfer the spring into the spring hole in center of the H
    • Put two caps on opposite ends of the u-joint and put it into the yoke
      • Make sure that the zerk hole points towards the transfer case end of the DC and that it is offset on the same side as your other zerk (At least this is what I found as to how to do it)
    • Carefully put the yoke on without dislodging any bearings in the center of the yoke
      • Now you have to keep pressure towards the drive shaft as the spring is pushing it away
    • Insert a cap on one end of the H and push it place most of the way to full seat without jarring it
    • Now carefully insert the u-joint into the cap
    • Press the cap in past where the clip goes in to hold this cap on
    • Turn the drive shaft so that the last ear is pointing down and start the last cap
      • If you have to turn it on its side there is a much greater chance of a bearing falling
    • Carefully, really carefully slide the u-joint down keeping it lined up straight into the second/last cap without dislodging a bearing all the while pushing the yoke in to the drive shaft
      • Here is where the extra u-joint comes in, at least for me as I lost bearings on both ends and had to redo them – practice makes perfect, correct?
    • Now seat the final two caps and install the clips the same as you did for the above u-joints
      • Again, if the caps don’t seat far enough without a lot of pressure to insert the clips you have dropped a bearing
      • A tell-tale snap while applying pressure is another sign
    • Now clean up as much grease as you can the came out of the zerk holes when you installed the caps
    • Install the regular zerks and tighten them down
    • Grease each zerk until grease starts leaking from each seal and grease the center yoke needle zerk until a good amount of grease come out the relief hold on the TC side of the DC
    • Tighten the needle zerk and double check each zerk
    • Twist the u-joint in all directions as much as you can to verify full articulation and move the grease around
      • Note: Make sure your fingers are outside of the DC unit before you start turning it
    • Re-grease zerks and check for tightness
    • Install the repaired drive shaft on your rig taking not of alignment marks and aligning it to those marks
    • Double check bolts and nuts
    • Grease the zerk on the drive shaft for the shafts compression, it will take a quite a few pumps as you probably pushed all the grease out earlier when you were working on the DC
    • You should be done now and ready to take it out for a test drive
    • Don’t forget to double check the tightness of your bolts and nuts as well as making sure each u-joint still has cap clips after 50 or so miles.
  10. #10 Re: Double Cardan Rebuild
    Quote Originally Posted by rccolacc
    -RC
    Part numbers for Spicer components (prices are from my local Drive Train Industries):
    Yoke - 211544X ~ $65.00
    Yoke Splash Ring - 231864 ~ $6.00
    U-Joints - 5-153X ~ $12.00
    Yes, being a poor college student is tough, but once you get done it will be worth it. I think that the dealership would sell you the Spicer components, but the price might be higher than a driveline shop or NAPA. -Todd
  11. #11 Re: Double Cardan Rebuild
    nice writeup...but wow, I can't believe they charged you that much for the centering kit. I went into my local driveline shop to buy the same parts, for $60 they gave me all the parts, and installed 'em.
  12. #12 Re: Double Cardan Rebuild
    Quote Originally Posted by jsteves
    Thanks. Sometimes it sucks to be in Grand Junction and with less than four days before a scheduled trip to Denver for my son's soccer match I didn't have time or want to chase parts for a few $$ saved and DTI is a couple of blocks from work.
    On the other hand, I'm only two hours away from Moab, less than two from Gold Metal Flyfishing... Napa wanted $45 for a non-Spicer kit here and I think it was the rubber bushing one that is not greasable, but I didn't want to go down that road with a DC rebuild. -Todd
  13. #13 Re: Double Cardan Rebuild
    mine was rebuilt with spicer parts as well...like you said, the ups and downs of grand junction
  14. #14 Re: Double Cardan Rebuild
    Senior Member nate's Avatar
    Palmer, AK
    Yeah the last centering kit I bought was around $35.
    03 Subaru WRX
    98 Dodge Ram 2500 CTD
    98 Jeep ZJ
    95 Dodge Ram 3500 CTD
  15. #15 Re: Double Cardan Rebuild
    Senior Member zj-monster's Avatar
    Jan 2005
    Topeka, Kansas
    Sweet write-up!!
    In fact, this needs to be moved to the FAQ's and Write-Ups thread.
    Quote Originally Posted by CurtP View Post
    What a fucking concept, eh? How dare you bring logic to this thread. What are you, some kind of asshole?
  16. #16 Re: Double Cardan Rebuild
    Bump for this decade.
    The part # listed for the centering yoke (211544X) is the NON grease-able one, the part number for the grease-able part is 211355X
    Here is a link to the two different parts:
    http://www.northerndrivetrain.com/pr...I-211355X.html
    http://www.northerndrivetrain.com/pr...I-211544X.html
    Now all the dimensions except the dimension for "E" are the same, so will either piece work?
    Neil R.
    Funniest thread on MC
  17. #17 Re: Double Cardan Rebuild
    Umm yea, blast from the past, 37k and four years later. Maybe DTI mixed the boxes or p/n on the invoice... Thanks for the update.
  18. #18 Re: Double Cardan Rebuild
    I just had the parts ordered to Fort Collins, the centering yoke is coming from, you guessed it, Grand Junction, and the slinger ring from Co Springs.
    They told me something like 50-55 bucks for the centering yoke.
    Neil R.
  19. #19 Re: Double Cardan Rebuild
    Apr 2009
    Suring, WI/ Houghton, MI (School-MTU)
    Fort Collins did you get the grease-able centering yoke or the non grease-able? Im redoing mine and was just wondering if it fits okay. Everything looks like it would but just want to make sure. Thanks
  20. #20 Re: Double Cardan Rebuild
    I picked up the grease-able one. I haven't put it on yet though. I may do it this weekend. I'll update this when it gets done.
    Neil R.
  21. #21 Re: Double Cardan Rebuild
    Cedar Rapids Ia
    I attempted mine this weekend and gave up. Sent it to a local place for rebuild.
    I could not get the cap to set properly without destroying something. I broke my vice a while back and tried to use just hammer and socket (which i have done many times before) but for some reason I kept getting them cockeyed in the hole.
    I talked to the guy for the rebuild and he seemed very knowledgeable. I noticed mine had no cover (rubber or metal just the gasket built on the centering yoke). He is going to put a rubber one on since the sheet metal does not stand up to the salt conditions he says rusts fast and makes is worse (rustbelt, no pun). Also he mic'd mine where the centering yoke will sit and he said he will only need to polish it to get rid of the surface irregularities. Something for home rebuilders to think about.
    Also he mentioned that many who rebuild them fail to pump the grease into them which allows for premature failure 6-12 months. Suggest anyone getting one make to sure to get the grease-able one. You also need the fat needle adapter for the grease gun. It is not a zerk fitting. Also mark the way you took it off, he also said it can become imbalanced reducing life.
    “I ask, sir, what is the militia? It is the whole people, except for a few public officials.”- George Mason
    "The beauty of the second amendment is that it will not be needed until they try to take it." -Thomas Jefferson
    “The great object is that every man be armed.” -Patrick Henry
  22. #22 Re: Double Cardan Rebuild
    Apr 2009
    Get it done there FCZJ?
  23. #23 Re: Double Cardan Rebuild
    Cedar Rapids Ia
    I got mine back, i noticed the weights were around 90 degrees around the shaft from when i took it in. You might want to have yours balanced (i think it was $10 for me).
    I will try to get a picture tonight.
  24. #24 Re: Double Cardan Rebuild
    Apr 2009
    ZJ_tins, you did it with the grease-able and it worked just needed rebalanced??
    Sweet think ill order up the parts and do it this weekend once, im home. Get it rebalanced Monday and be all set to go.
  25. #25 Re: Double Cardan Rebuild
    Feb 2009
    Its funny that everyone is talking about Colorado. The only double cardan joint I've rebuilt, we did the night before we hit the road for Wyoming.. Stopped by my grand parents house in Co Springs for the night and put the drive shaft back in because it was supposed to snow the next day.
    And if for nothing else a 3rd ujoint its nice having a source for extra needle bearings. You won't always assemble the u-joints correctly the first time and you're gonna lose a few needle bearings when you have to take it apart and do it again... I've done idk how many u-joints and I always seem to take the new one apart for one reason or another every now and then.
    piece of shit 99 ranger - trail slut
    03 1500 Z71, 5.3 - tow rig/dd
