Thread: Anyone want to rebuild their tranny???
Results 26 to 50 of 53
  1. #26 Re: Anyone want to rebuild their tranny???
    Rob,
    I am dealing with a major problem right now that maybe you might know the answer too.
    I have a 42RE and it leaks like a stuck pig. I have had it apart about 7 times and no one can fix it.
    I am going down again this Sat. to pull the OD housing (again). I have not been present the last few times it has been torn apart, so I am told that the gasket between the trans and OH housing seals everything except a little piston that is sealed by 2 small o-rings, the guy I am dealing with thinks that maybe some silicone needs to be put on the area around the piston BEFORE the OD housing goes in to hold it all together.
    Does this make any sense to you? I am not sure if I am explaining it correctly or not.
    If you are looking at the back of the tranny I think the piston is in the bottom right corner somewhere but not really sure.
    I guess the question is should ANY silicone sealer be used when reassembling the tranny?
  2. #27 Re: Anyone want to rebuild their tranny???
    Senior Member rob92xj's Avatar
    May 2005
    Fayetteville, North Carolina
    Silcone to fix a leak on an RE is just putting a band aid on it. There is a gasket between the OD housing and main case inorder to replace this gasket you need to disassemble the trans remove the over running clutch retainer/OD piston retainer, there used to be a gasket that was cut out around the retainer and you would have to cut the old gasket around the retainer but DC stopped making them a few years ago, make sure the gasket area is very clean and do not use anything but a plastic scraper to remove anything from the old gasket as a razor blade can knick the case deep enought to create another leak in the area and sanding disks and stuff like that remove too much material unless its a white 3M roloc used at the proper speed of less than 12000 RPM, there are 2 seals in between the OD and trans case they are for the OD piston silicone on the piston will guarantee the OD and possably 3rd gear will no longer work.
    Hope that helps.
    The Fleet:
    92 XJ 4.7L AW4 NP 242 Dana 30 with lock right 2000 XJ brakes and stub shafts, Chrysler 8.25 with 29 spline shafts and trac lock 4.56s, 35 12.5 BFG MTs on Soft 8 steelies
    2003 Dodge Ram 1500 4x4 Off Road
    2005 KJ(Wifes Jeep)
    96 ZJ Project Creampuff because it is insanely clean
  3. #28 Re: Anyone want to rebuild their tranny???
    Rob,
    That helps I guess.
    I am sorry to hi-jack this thread guys, I will start a new one for my problem.
  4. #29 Re: Anyone want to rebuild their tranny???
    Oct 2004
    any updates?
  5. #30 Re: Anyone want to rebuild their tranny???
    Jan 2006
    Raleigh, NC
    I've rebuilt an engine, and this doesn't look to hard. Is it really this easy?
  6. #31 Re: Anyone want to rebuild their tranny???
    Raleigh, NC
    nope... there is a boss you have to defeat at the end of the rebuild... i think swamp boy forgot to mention him.. his name is bowser
  7. #32 Re: Anyone want to rebuild their tranny???
    Jan 2006
    Raleigh, NC
    Quote Originally Posted by dell30rb
    Dang, not sure if I can do that....This seems like the cheapest route to rebuilding a 42re though.
  8. #33 Re: Anyone want to rebuild their tranny???
    Louisiana
    he finished the trans/torque converter. still has to bolt up the t-case.
    he will probably post up the details
  9. #34 Re: Anyone want to rebuild their tranny???
    New Orleans La.
    Waiting on the guy to come over and finish up my cooling lines... They are custom braided steel and he has to put the ends on them ..He is on vacation but is due back Thursday.. Hopeing to get her finished very soon...
    Then its off to the shop to get long arms....
  10. #35 Re: Anyone want to rebuild their tranny???
    Senior Member dasVettemeister's Avatar
    Mar 2005
    Oak Forest, IL
    Quote Originally Posted by Swamp boy
    I talked to a few tranny guys and they told me the most common problem with rebuilds going south is that they dont take the check valve out of the cooler... And they new tranny over heats
    Where is this located?
    PS...to my knowledge i was not anally raped...but i did have some strange shits the next day.
    I pay taxes so the government can pay for a bunch of white trash and shitbag illegals to have free medical care/welfare. Lovely.
  11. #36 Re: Anyone want to rebuild their tranny???
    Houston, TX
    I think only the v8's have a check ball in the cooler line, right? or is it like you said inside the stock cooler? if so I'm replacing mine ASAP, my first transmission died bc of a overheat in the cooler lines, so I cleaned just the lines and cooler out with transmission fluch junk in a spray can
  12. #37 Re: Anyone want to rebuild their tranny???
    Louisiana
    check valve in cooler line around the front of the engine. it is at one of the rubber/metal line connections in a brass fitting with an arrow etched on it.
  13. #38 Re: Anyone want to rebuild their tranny???
    Senior Member death-mobile's Avatar
    Jun 2005
    NJ
    How did this rebuild hold up so far?
    Balltastic.
  14. #39 Re: Anyone want to rebuild their tranny???
    New Orleans La.
    Well I am the slowest turd in the fucking world ... I put the tranny and t case in ... And I either crushed the crank position sensor or fucked up something else.. It wont start... I have changed the neutral safety switch and the coil and I have a buddy coming over (he is a mechanic) he is going to help me diagnose..
    He also has a wiring manual and if we cant figure it out we are going to install a toggle switch and a push button.. (I like the one that says "GO BABY GO" on it...
    He is coming over this week so I will let you know soon..
  15. #40 Re: Anyone want to rebuild their tranny???
    Jun 2005
    NJ
    So....did it ever hot the road?
    Balltastic.
  16. #41 Re: Anyone want to rebuild their tranny???
    Louisiana
    not yet i dont think
  17. #42 Re: Anyone want to rebuild their tranny???
    New Orleans La.
    It hasnt hit the road yet but I did put it on Jackstands and run it .. It shifted thru all the gears I am having trouble with the wireing so its not road ready yet..
  18. #43 Re: Anyone want to rebuild their tranny???
    Senior Member Sudz's Avatar
    Pennsy
    7 1/2 months later and still on jackstands? DAMN!
    i guess the rebuild didn't go so good after all...
  19. #44 Re: Anyone want to rebuild their tranny???
    Louisiana
    lol
    I think he fixed it the other day, it was a messed up neutral safety switch
  20. #45 Re: Anyone want to rebuild their tranny???
    New Orleans La.
    Terrorized my neighbors the other day for about an hour. . rebuild went good... I changed the NSS and the CPS and it fired right up..
    Just took some time cause Ive been working on my Rental house..
    Its in the final stages so I did some work on the Jeep.. I wont be starting it up again til I am completely done with the repairs..
    Wood floors and cabinets are all thats left..
  21. #46 Re: Anyone want to rebuild their tranny???
    Jun 2005
    NJ
    Quote Originally Posted by Swamp boy View Post
    I talked to a few tranny guys and they told me the most common problem with rebuilds going south is that they dont take the check valve out of the cooler... And they new tranny over heats... I tossed my factory cooler and the lines... Now I have new cooling lines and a new cooler... So I am not worried about my tranny.. I honestly cant wait to take it for the first spin... To finally have a tranny that shifts good and feels strong...
    I have the utmost trust in my tranny guy...He is the coolest dude I know...
    Can you explain removing the check valve for someone who is a lil slow
    Balltastic.
  22. #47 Re: Anyone want to rebuild their tranny???
    Senior Member SOLITUDE's Avatar
    Brunswick, GA 31523
    Can we get a little host'age of the el picturo's?
    1993 Jeep ZJ V8 5.2
    HP44/9", 4.88's, Detroit, OX, Clayton's, ALL IN PROGRESS
    LINK TO MY PAGE
  23. #48 Re: Anyone want to rebuild their tranny???
    Looks like i might need to try this whole... rebuild thing... on a 3/4 diesel suburban soon... It's slipping.
  24. #49 Re: Anyone want to rebuild their tranny???
    Jun 2005
    NJ
    Quote Originally Posted by SOLITUDE View Post
    MAS PICTUROS!!!
    VIVA LA REVOLUTION!
    Balltastic.
  25. #50 Re: Anyone want to rebuild their tranny???
    Jun 2005
    NJ
    I have my trans out and started reading the manual. Did you use any of the special tools? I see they want you to use an alignment tool to stick in the overdrive section when you pull it off. Do you really need it? Also the spring compressor dealie, do you need that or can you make do with something else? I'm getting a little nervous now because those tools are expensive.
    Balltastic.
