4.6L Stroker write-up - Page 2
Thread: 4.6L Stroker write-up
Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
  1. #26 Re: 4.6L Stroker write-up
    Jun 2008
    Dodge
    Quote Originally Posted by 93_5spd View Post
    Payclose attention to setting the timing. I used a crower cam, and didn't have to grind off the ears of my dist. If it is installed 180* out, you can swap plug wires around, and it'll run, but be hard to start, be low on power, and suck gas. Follow the directions earlier in this thread, it's amazing what doing it right does for power.
    You cannot time this motor. Get it close and it does it all by itself. Mine ran without grinding the ears off the distributor. It was a bit slow to start. I reveresed it (180 degees), same result. I bought a timing light, ground off the ears, and did a 30 degree sweep off number 1. The engine will change pitch...then the computer will take over and do what it wants. If it runs good be happy, but you are not timing it.
    I have a year round cougar permit. Cougars are always in season.
    '93/6"-Custom 3link & Tri-4link Long Arm/4.6L Stroker/AW4/np231/HP30/D44/Detrioted-4.88s/35s/murdered out wood grain playa...
  2. #27 Re: 4.6L Stroker write-up
    Member 93_5spd's Avatar
    Wallburg, NC & Ft. Bragg
    Quote Originally Posted by dirty View Post
    I got it to run at first, but found out i had the rotor 180* out. The I used the 3.0 cm distance spec'd in DIno's writeup, put the oil pump @11, turned the rotor about 20* CCW, and droped it in. Lined up perfectly with the mark i made, and was just past the #1 spot on the cap. If you have the ears ground off, you can make it "out of time" as well as if you have the rotor indexed wrong. Maybe i should have said once you get it indexed instead of in time, either way, the jeep has balls!
    So far I've got 92 miles on it, loving my jeep again after not driving it since May '07
  3. #28 Re: 4.6L Stroker write-up
    Senior Member Lifetime Supporter TrojanMan's Avatar
    Jan 2005
    Wherever the Navy needs me
    I hear you with setting the timing correctly. I set it about 20* out and damn near killed myself for it. Should have just followed directions the first time instead of second guessing myself.
    What branch are you with?
    Quote Originally Posted by ATL ZJ
    This thread proves that wheeling is better than the internet.
    Weavsworld: i dont know shit about MC, i just make it work
  4. #29 Re: 4.6L Stroker write-up
    Jun 2008
    Dodge
    Roger. And x2 on the balls...I've never driven anything with so much low end torque.
  5. #30 Re: 4.6L Stroker write-up
    Sacramento, CA
    just get a 4.7
    4.7 wj 4" front long arm soft 8's destination mt's
    and some stuff. bigger and better shit in progress
  6. #31 Re: 4.6L Stroker write-up
    Quote Originally Posted by Arsonist_Bob View Post
    just get a 4.7
    WTF??? You go through the trouble of putting a late model SMALL V8 into my OBDI Jeep. I've got plenty of power, and still pull ~18-19MPG highway with 35's. SO much power in fact, I snapped the output shaft on my tcase, twisted the slipyoke on the driveshaft, broke my carrier, exploded the spider gears, and chipped the pinion gear. Just from a 3k RPM launch trying to 'showoff' on dry pavement when a Mustang decided he wanted to race the heavy jeep with the stroker badge. (2000 8.8 ford axle)
    Keep your 4.7 and the WJ it's wrapped in. Unless you've driven one, the low end and midrange torque of a stroked I6 can not fully be appreciated. It's already cost me $800 in broken driveline parts. We'll see how the ax15 holds up!
  7. #32 Re: 4.6L Stroker write-up
    Jan 2005
    Sure, but you pay for the pistons and bore at the machine shop.
    I do hope you're talking about a 4.6 variant.
  8. #33 Re: 4.6L Stroker write-up
    Senior Member rob92xj's Avatar
    May 2005
    Fayetteville, North Carolina
    Finally got my 4.7L done this year it is awesome. I just need to get the right injectors for it so I have been taking it easy and running 93 octane. Low end torque is great.
    I used a 96 NVH block, 89 4.2L crank and rods from a friends Wrangler, .060 over Speed Pro pistons and rings Competition Cams Extreme 4x4 cam, ported and polished head, cc'd chambers, 99 WJ intake ported to match the head.
    The old 4.0L next to the 4.7L
    The Fleet:
    92 XJ 4.7L AW4 NP 242 Dana 30 with lock right 2000 XJ brakes and stub shafts, Chrysler 8.25 with 29 spline shafts and trac lock 4.56s, 35 12.5 BFG MTs on Soft 8 steelies
    2003 Dodge Ram 1500 4x4 Off Road
    2005 KJ(Wifes Jeep)
    96 ZJ Project Creampuff because it is insanely clean
