ThnxOriginally Posted by Firestarter
All correct, as for the muffler it is home made by Mav ©
There are a few pic's here in this thread.
and some more
What have we done lately, well not much.
After all it is my vacation
Earlier this month I "lifted" the hood
Used squarre tube for this 40*40*2 220 long, all millimetrs
Also started on a pair off mini ramps, to help fine-tuning the "flex" later on.
Used corner 30*30*3 and bar 40*5(all millimeters again)
Tested by Beest, watch the Mallcrawlin.com sticker.
After some minor adjustments, the final result.
Because there will be some extra switches and warning lights, I´m gonna adjust the center console a little.
First in wood, to get some idea´s
Something like this.
The passenger side out off 1mm stainless steel.
In place including the top side.
After ´bending´ the top piece it will be something like this.
in the "project".
That´s right it was hot in the garage today, just a little over 100 Fahrenheit.
First attribute in place, winch control lock.
You never know with small and big children in a jeep toy.
Have a nice vacation.
Sorry Dirk, but I don't understand what you mean to say.Originally Posted by Cue-Ball
He means it looks bad ass!
Might I add, your whole ZJ progression looks "trick".
Nice work.
thanks, learning slang every day.
Very nice center console, I like it.
I want a update.......
Ja ja,Originally Posted by Beest
nice avatar btw.
So it has been a while, but have done some minor things.
A month ago I was working on the center console, let's proceed.
Made 2 incab whinch control switches
Major thing however this week was, DS's are done.
I couldn't resist so last night I drove it on it's own engine power.
4 feet backwards and 2 feet up.
In 2 wheel drive, since the front pumpkin is still empty.
Don't mind my big smile.
Next update will be quicker, I think.
Awesome man.
Close and Closer to being finished.
I need to built some ramps like that so I can sit under low cars when I'm working on them... wonder if I would built 4... it'd be like a homebuilt lift kinda sorta
I've got some 8" high plastic ones I got at Pep Boys. They work fine when trying to get a drive axle up, but not so hot on non-drive axles. I was trying to pull the ZJ up onto them once after blowing up the front d-shaft and part of the t-case, only had RWD. The fronts kept pushing the ramps, they wouldnt stay put, so I was trying to really ease the ZJ up them. Somehow or another I ended up shooting the rear ramps out from underneath the Jeep, out of the garage (door was open), and into the street. It was pretty badass.Originally Posted by nate
Why didn't you just block them with a cinder block or something that was somewhat heavy. I would hope that you figured that out soon there afterOriginally Posted by BigDaveZJ
Or jack it up and set them under the wheels?Originally Posted by BigDaveZJ
They won't work well for low cars since the ramp is 38 degrees up.Originally Posted by nate
They are only 4 ft long and 2 ft high approx.
Made just a pair for fine tuning on the suspension, seems to work out pretty wel.
Quick enough?
Obvious had to try the front on the ramp also.
Got the ramp fixed too the ground to avoid it shooting away, so still in 2 wheel drive.
By the way, I'm a little over 6 ft, standing eye to eye with my left headlamp
Enough travel on the rear shocks
Coils are doing better then exspected
Little dusty
Detail
The hydro assist still fit
All for now
Jup, it's about time.Originally Posted by ILikeMud
It is almost about two years since I drove it on/off - road.
this is about the sickest BUILD EVER I WANT MORE
Wow, bet you can`t wait till it`s finished.Originally Posted by ogdak
Guess one off the biggests lessons on this project is, to have all(or a lot) off the needed parts in storage before taking things a part.Originally Posted by ILikeMud
So the actual build time will be a lot shorter.
I hear you but at the same time, gather parts can be a pain too. I've been gathering parts for my trans swap since Feb of this year.
Did you buy most your parts from the US or a mix?
I still think that is the most badass rear bumper Ive seen on a ZJ.
steel, tires, e-fan and the Xj D30 are bought local.Originally Posted by ILikeMud
probably forgetting som small parts.
x2Originally Posted by violatedppl
Thanx, Sjikita did the drawing and manufacturing off it.
What tires are those anyhow? Maxxis?
Users Browsing this ThreadThere are currently 24 users browsing this thread. (0 members and 24 guests) |
