OGDAK's ZJ moving 12/04/2022 - Page 10
Page 10 of 19 FirstFirst 12345678910111213141516171819 LastLast
Results 226 to 250 of 462
  1. #226 Re: Ogdak's ZJ - Finally!! 10/29/2006
    Quote Originally Posted by TheOtherSide
    Very nice...
    thnx.
  2. #227 Re: Ogdak's ZJ - Finally!! 10/29/2006
    Member ZachJ's Avatar
    Sep 2005
    Richmond/Chico, California
    Looks good, Im sure you are glad to have it out of the garage.
    95 Grand Cherokee V8 RE 3.5" + 2" spacers, Clayton Long Arms, RE front adj. Track Bar, Ford 8.8 w/ Detroit Truetrac, JKS quick discos, 3" FM 40 + Carsound Cat, 33" Maxxis Bighorn Radial, KOR radiator support, KOR LP1 sliderz, Ford E-Fan swap, tranny and gas skidz, more crap...
    overlandgears.com
  3. #228 Re: Ogdak's ZJ - Finally!! 10/29/2006
    Quote Originally Posted by ZachJ
    Thnx, got that right.
    Ready to go.
    Kids too
    Cheking the details
    Technical Jeepcamp check, popped the hood again
    Still friday, after 10 min on the trail the P/S goes out.
    After being towed back by Mav, thnx and a closer observation.
    Turns out that the edge on the P/S pulley has cut through the 90 degree connector
    on the steering gear from the pressure line.
    I knew the distance about ¼" was close, but that close?
    No worries got the tools out and took out the line from P/S pump to the steering gear
    Sjikita knew a shop close by where a new 90 degree connector was pressed on which was "lower" then the original one.
    Wrenching help and audiance enough
    Job done before dark
    Saturday on the same trail all things go well now.
    And get it dirty again.
    Monday to check on further capabilities
    Up on some concrete
    On the one highest level the line lock came to use. Left front wheel slipped,
    Applied brakes, locked left line lock, released brake, got the revs up a little and crawled on to the highest level.
  4. #229 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    Senior Member aresridingflat's Avatar
    Sep 2005
    Alamogordo, NM
    This is a great build thread. Awesome to see it on the trail finally. I bet it feels good after all that work...
    Props.
    Will
    89 4runner, 03 cummins
  5. #230 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    Quote Originally Posted by aresridingflat
    Props.
    Will
    thnx, I'll start uplaoding the pic's from the start again pretty soon.
    More detailted pic's, cause I can not get enough off it.
    The coil won't fall out.
    Limiting strap doing wat it was ment for.
    In another spot, Mudmiep and Jeepee thanx for taking pic's
    Trouble with the whinch, ground was not mounted properly.
    Mudmiep taking it for a spin
    Fun?
    Not according to Dennis, by the looks off his face.
    Eventually problems with the steering again.
    But no oilleak this time
    Fortunatly it is monday and we have had a excelent weekend.
    Meanwhile at home again, checked the steering.
    Broken pump shaft, coloured blue so maybe run a little to long without enough oil.
    For de rest no real issue's except lenghtning bumptops and brakelines.
  6. #231 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    Senior Member RiPPiNiTuP7's Avatar
    Dec 2004
    Ohio
    i'd call that a pretty good turnout after doing so many changes to the jeep and taking it out for the first time. it came out great.
    -04' silver ram 1500. 5.7 hemi. 4x4. a few goodies.
    -98' chargold zj. 4.0/242. stocker.
    -09' black yamaha rhino SE. new offroad play toy.
    -96' black zj. 4.0/242. re 4.5" + 2" BB, 35" bfg at's, 8.8 w/ e-locker, open HP30, 4.56's, TW SYE & F/R driveshafts, currie steering, addco's F/R, ARB'ed, Warn 8k winch, & armor. - SOLD
  7. #232 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    Paradise, Newfoundland Canada
    That's AWESOME man.
    Anthony
  8. #233 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    Senior Member EMTimZJ's Avatar
    Jan 2006
    West Michigan
    Looking great! Awesome to see it moving and wheeling!
    -Tim
  9. #234 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    thnx guys, it was awesome to wheel it again. It came out better then expected.
  10. #235 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    AWESOME Man, totally awesome.
    Dirk
  11. #236 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    Quote Originally Posted by Cue-Ball
    Dirk
    thnx Dirk
  12. #237 Re: Ogdak's ZJ - Testing at DJC!! 10/29/2006
    Hi
    Just recieved an email from Kelvin at http://www.pscmotorsports.com/ telling me the parts for my p/s pump will be shipped tomorrow.
    Upon first contact, He asked me to send in the pump so it good be fixed at no cost to me. Then later on he offerd to send the parts to be replaced by myself, so it would be cheaper concerning shipping cost.
    Excellent customer service, thnx Kelvin.
  13. #238 Re: OGDAK's ZJ, Excellent PSC customer service 11/09/2006
    Sorry for the red X'ses,
    this is why http://www.mallcrawlin.com/forum/sho...700#post118700
  14. #239 Re: OGDAK's ZJ, Excellent PSC customer service 11/09/2006
    I'd like to edit my own posts because off the broken links for the pic's.
    But I do not have an edit button anymore.
    I doubt you want me to quote all my posts.
    I also want to edit the psc topic title cuase there service aint that great afterall,
    have not seen anything yet and the are refusing to answer my emails.
  15. #240 Re: OGDAK's ZJ, Excellent PSC customer service 11/09/2006
    Jan 2006
    West Michigan
    Double click on your thread title in the "Jeep journals and members rides" forum view, you should be able to edit the title using this method...
  16. #241 OGDAK's ZJ
    Quote Originally Posted by EMTimZJ
    Well is does turn bleu, but before I can do anything it opens the thread.
    Doesn't matter wether I use IE or FF
  17. #242 Re: OGDAK's ZJ, Excellent PSC customer service 11/09/2006
    Northern, NJ. Syracuse, NY
    your ZJ amazes me. Ive been following this thread from when i first got my jeep. And honestly, it seems as tho im making the same progress as you! Keep up the great work. this is definately one of the best threads on the site!
    Paolo
    96 ZJ 5.2 L V8 w/ stuff
  18. #243 Re: OGDAK's ZJ, Excellent PSC customer service 11/09/2006
    Thnx Paolo
  19. #244 Re: OGDAK's ZJ, Excellent PSC customer service 11/09/2006
    It did work afterall, being very fast at the keyboard with Cut/Paste and a double "enter"
    Thnx
  20. #245 OGDAK's ZJ spare V8 12/08/2006
    Have not been up to a lot lately, some minor things I did do are,
    A modification for the bracket where the hydro cylinder attach to the tie rod
    Since the stroke of the assist cylinder(8") is bigger than the lateral movement off the tie rod
    approx. 5"(did not take exact meas.) from left full lock to right.
    So the previous bracket slided over the tie rod
    The idea is to fab 2 large rings to put around the tie rod on both sides off the existing bracket.
    The rings would prevent the bracket from sliding, same time I'll still be able to adjust toe-in
    So took some solid axle, drilled a hole in it.
    The bench did the rest.
    result
    Drilled some M10 holes for welding them on to the tie rod.
    So eventualy it will look like this.
    So still hopping from one to another subject.
    The broken P/S pump for which I still did not get the replacement parts.
    So I'll make an attempt to fix it.
    De pump axle is broken at the point where it is splined to fit in the pump rotor.
    So drilled a hole in the axle and through the broken piece, and tapped a M8 thread in it.
    Put it together with an allen bolt,
    already having doubts weather this will hold.
    But how knows, piece off M8 thread and a lot off loc-tite
    The "fixed" result,
    in the rotor.
    pump housing,
    everything back together.
    On to another subject.
    Got myself a spare V8 with a little work.
    It was diagnosed with a stuck or broken oil ring on piston nr 6
    Took the right cylinder head cover off,
    followed by the one on the left.
    Right side exhaust manifold removed
    The difference between cylinders 4 and 6
    Nr: 8 does not look to good either.
    The ones on the left are looking much better.
    rocker-arms and pushrods removed.
    a part dismanteld right cylinder head,
    and left
    Bottom view off the intake manifold, all that black stuff you see in most off these pic's.
    Is caused, I was told by several people now, by random use off both mineral and synthetic engine oil.
    Besides that this engine was treated with Forte Flush, an engine oil additief to clean the engine internally
    This may have caused solid pieces to come loose and travel throuhg the engine and clocking oil ways.
    Conclusion, this engine needs a rebuilt.
    The right cylinder head removed, obvious cylinders 6 and 8 have had the biggest problems
    The left cylinder head removed also.
    Detail on the black stuff, it also smells real bad.
    Finally the gear driven driveshaft which on the top side turns the distributor,
    and on the downside the oil pump.
    Well that covered what has happened lately.
    SU.
  21. #246 Re: OGDAK's ZJ spare V8 12/09/2006
    Senior Member Skyline's Avatar
    Westchester, NY
    Boy that's one nasty looking motor inside! I would think about getting all the larger components commercially cleaned once you get it all apart, otherwise they might have to send the haz-mat team to your house with all the solvent and rags you'd have to use! Any engine machine shop should be able to do that, or send you to someplace that can.
    '96 GC Laredo V8; Tom Woods front U-Joint Shaft; Kevins sliders; 4.5" RE springs; Kevin's track bar conversion; JKS short arms, discos, and track bars; Pro Comp 16x8 mags with 305/70/16 Mud rovers.
    Support Our Troops!!!
  22. #247 Re: OGDAK's ZJ spare V8 12/09/2006
    That sure is an option.
    Right now I already poored several liters off diesel oil into the engine and let it soak for a while. Depending on that I'll see what to do next
  23. #248 Re: OGDAK's ZJ spare V8 12/09/2006
    Jan 2006
    West Michigan
    Yikes, that plenum gasket is probably shot as well. Here is some info on it that may help when it comes time to rebuilding!
    http://www.jeepforum.com/forum/showthread.php?t=233448
    -Tim
  24. #249 Re: OGDAK's ZJ spare V8 12/09/2006
    -Tim
    Thnx, got some reading ahead.
  25. #250 Re: OGDAK's ZJ spare V8 12/09/2006
    So just finished fixing broken links.
    Approx. 750 pic's visible again.
    No jeep update, still waiting on part's
There are currently 17 users browsing this thread. (0 members and 17 guests)
