OGDAK's ZJ moving 12/04/2022 - Page 4
Page 4 of 19 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 462
  1. #76 Re: Ogdak's ZJ - LA's in place 01/23/2006
    looks good.
  2. #77 Re: Ogdak's ZJ - LA's in place 01/23/2006
    @Kraga thnx
    So August 2005, only 1 month till 2nd Dutch Jeep Camp.
    Last item on the La's, is radius arms
    Stock, the FUCA is between axle and unibody.
    But since that will not work on a LA setup, we make 1 or 2 radius arms.
    So my radius arm runs from the UCA bracket(HP30) down to the FLCA and is also lenghtwise adj.
    To set, in the first place pinion angle and caster.
    So that's just about it for August, happy holidays
    September 2005, JEEPCAMP, went there as a Marshall without my ZJ.
    Had fun though for all 4 days, Will be there again in 2006 WITH my ZJ
    So the rest of september will be a little off everything, just looking through
    So with a paint burner, lots off terpentine and sander cleared the area for the unibody sleeves.
    Just plain tiles, always handy
    So time to start painting things. I used RX5 as a ground layer on all untreated parts.
    Started with the 8.8
    The Sleeves
    The CA's
    And the 8.8 again
    Fabed up some endlinks out off 50*50*5(metric)"corner line"(I know, you tell me.) for my teraflex disco's.
    Time to do some unibody welding
    When I started, Kraga's Unibody Welding Bible was not posted yet. but I have faith that things won't tear off.
    Got the sleeves set-up and lined out with 4 bolts.
    I only welded the sleeves to the unibody where there was 2 layers off sheetmetal.
    And besides that a bunch off plug welds.
    So here comes October 2005.
  3. #78 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    Senior Member norton's Avatar
    Mar 2005
    About 5 miles north of nowhere in Kansas
    looking good.
    nice way to hold up the body of that thang. tiles?
    93 5.2 2" 31's
  4. #79 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    Senior Member nate's Avatar
    Palmer, AK
    That's pretty much how I welded my subframe on as well.
    I wanted to mention... that pass side UCA on the D30, you should box it in. I'll bet $20 that it will fold up after a summer of wheeling. I've run 3 D30s under my Jeep and they all have done it.
    03 Subaru WRX
    98 Dodge Ram 2500 CTD
    98 Jeep ZJ
    95 Dodge Ram 3500 CTD
  5. #80 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    Jan 2006
    Edmonton, AB. Canada
    Nice work.
    99WJ...9" Custom Stainless Longarmed, Full W HiP D44 front, Custom Stainless Full W HiP 9" rear, BoldDesign Front/Rear Bumpers, 36" Bias IROK's
  6. #81 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    Wow, thought I had everything covered.
    Never heard about them folding up, but I like to prevent it.
    So how should I box it.
    @Nate or anybody, A pic off a boxed pass. side UCA.
    Would be a big help.
    Thnx Nate
    I already looked at Kevin's LA setup, but that would mean redoing the whole front, there must be an easier way.
    I also looked at Clayton's setup, They don't seem to be doing anything for it.
    Open for option's
  7. #82 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    put a plat on the back side to make the bracket a box instead of a u-channel.
  8. #83 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    So I fixed my weak link, D30 pass side UCA mount.
    Thnx Nate & Kraga
    Found some pieces off metal laying around.
    top is ¼" and base is even thicker like 8mm
    Thanks
    So what do you think, will this hold up.
  9. #84 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    This is great. It's exciting seeing all the big build threads goign on right now. It's needed, because everytime I see someone else go make progress, I'm like "Ya, I need to go get something done on my rig."
  10. #85 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    So what are you waiting for?
  11. #86 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    Well I have the inspiration, now I just need the energy
    LOL I'm heading out to the garage now.
  12. #87 Re: Ogdak's ZJ - Sleeves welded in 01/25/2006
    LOL, just came from there, now heading for a beer.
    October 2005
    So if JEEPCAMP 2005 was good for anything, then it sure was my motivation.
    So on with the paintjob, after the untreated parts being done with RX5.
    It is now time for some layers of RX10.
    First the 8.8, obvious the first layer
    "the" unibody.
    "the" Long Arm's
    WJ knuckles
    HP D30
    Just a forum
    Does not need explaining I guess
    Modified front U-beam back in place
    Drilled out the oem prop weld's
    And "stuffed" them again.
    And painted
    Part 1 off October 2005
  13. #88 Re: Ogdak's ZJ - Paintjob 01/29/2006
    October 2005 part 2
    Where did I left of, that's right got some more detailed tire-carier close-up's with 35"
    Because off the fact that the mounting plate is adjustable,
    The spare is very close to the rear of the ZJ
    The "lock"
    The "hing"
    Open
    And on with the paintbrush.
    So finally on with some stuff for the endresult.
    I am usualy not in to "bling bling" but a litlle accent here and there would not hurt.
    So, assembling and installation of the LONG ARM's
    JJ's installed
    Parts needed for a set of radius arm's
    A set of FLCA's
    Almost in place
    In place
    And that is the end of October 2005, only 3 months and 200 pic's behind reality.
  14. #89 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    Senior Member grnd93's Avatar
    New Boston, MI
    Very Sweet!
    I'll be hardcore when I can afford it.
  15. #90 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    Jun 2005
    Paradise, Newfoundland Canada
    Wow,
    Awesome man.
    Anthony
  16. #91 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    Senior Member 2jeepsforus's Avatar
    Sep 2005
    Smethport, PA
    Smart guy.... zerk fittings on everything possible even the tire carrier
    1998 5.9, 5.5" Front/ 4.5" Rear (RE), 33/12.50's Trxus MT's, ARB Bumper w/Warn 9500HS, 231HD...SOLD...Stupid Divorce!!
    Quote Originally Posted by canadian_driver View Post
    start giving teachers guns... or tazers.... or clubs or just a 2x4 with a nail in it
  17. #92 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    Member 8WR_ZJ's Avatar
    Lake Charles, LA
    Wow! very nice. Keep up the great work.
    Louisiana Home of some rocks.
    95 5.2 L.A.,hybrid 60/9inch (sold) now back to 44/9 and 40 LTB'S
    Hurricane upgraded 46RH, Hurricane double stak, Hurricane Beadlocks, Hurricane Bumpers, Lots of missing Sheetmetal!
    The only way to be for sure it's her is to stick it in her butt.
  18. #93 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    Quote Originally Posted by 2jeepsforus
    Just have to make sure to keep my "grease" on level.
  19. #94 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    Looks great, the passenger UCA looks nice.
    One thing ot consider is that alot of people claim having that much round bar comming off yoru JJ's will cause bending problems. I run just as much as you on my joints and have had ZERO problems. but i get alot of greef from people.
    on your tranny cross member did you trim the pinch weld off the frame so you could run the U channel further to the front of the vehicle?
  20. #95 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    Yup I did trim the pinch weld, something like 5 or 6".
    Total lenght of the U-channel is approx. 41".
    As for as the round bar near the JJ's and a lot of other stuff.
    Time will tell if things will hold, but there will always be something called
    "the weakest link"
    I do not wonder what that will be.
  21. #96 Re: Ogdak's ZJ - Assembling&Installation LA's 02/02/2006
    November 2005
    Something different,
    What is missing in this pic.
    That's right visco fan.
    Will be replaced with this fod tauus 3.8 90-95 e-fan, does not need further explaining.
    Made some hardware.
    In place
    Another issue, rear shocks.
    I am gonna go XJ style
    Near the BS on the in/downside of the unibody.
    With som rivnuts
    installed
    some pieces of square tube and a u-beam.
    Multiple shock mounting points for adjustment.
    Almost the final looks, just some paint missing
    8.8 install time
    How nice , stock 15" * 7J ZJ rim's
    UCA and LCA in place.
    What is in the box "More bling bling"
    Eagle Alloys
    SERIES 186, Super Finish, 16x10, Offset -24mm, BSM 4,5" en load 2100lbs
    Good for now.
  22. #97 Re: Ogdak's ZJ - e-fan, 8.8 and rear shock mnt. 02/09/2006
    Jun 2005
    Those are some 'blingy' rims.
    Can't wait to see it all finished man.
    Anthony
  23. #98 Re: Ogdak's ZJ - e-fan, 8.8 and rear shock mnt. 02/09/2006
    Yea coming along nicely.
  24. #99 Re: Ogdak's ZJ - e-fan, 8.8 and rear shock mnt. 02/09/2006
    There is a very good chance I'm going to copy at least some of the elements of your rear bumper. All of your work looks to be of very high quality.. What tools do you use for cutting your steel? It all appears to be laser cut..?
    Once again, it's coming along nicely.
    Cam
  25. #100 Re: Ogdak's ZJ - e-fan, 8.8 and rear shock mnt. 02/09/2006
    Quote Originally Posted by ILikeMud
    Me too
    Cam
    You are welcome.
    Cam
    Thanks, Yes most is lasercut.
    But would not want to go without a 125mmų 1mm thick cut-off wheel
There are currently 6 users browsing this thread. (0 members and 6 guests)
