thnx.Originally Posted by TheOtherSide
Looks good, Im sure you are glad to have it out of the garage.
Thnx, got that right.Originally Posted by ZachJ
Ready to go.
Kids too
Cheking the details
Technical Jeepcamp check, popped the hood again
Still friday, after 10 min on the trail the P/S goes out.
After being towed back by Mav, thnx and a closer observation.
Turns out that the edge on the P/S pulley has cut through the 90 degree connector
on the steering gear from the pressure line.
I knew the distance about ¼" was close, but that close?
No worries got the tools out and took out the line from P/S pump to the steering gear
Sjikita knew a shop close by where a new 90 degree connector was pressed on which was "lower" then the original one.
Wrenching help and audiance enough
Job done before dark
Saturday on the same trail all things go well now.
And get it dirty again.
Monday to check on further capabilities
Up on some concrete
On the one highest level the line lock came to use. Left front wheel slipped,
Applied brakes, locked left line lock, released brake, got the revs up a little and crawled on to the highest level.
This is a great build thread. Awesome to see it on the trail finally. I bet it feels good after all that work...
Props.
Will
thnx, I'll start uplaoding the pic's from the start again pretty soon.Originally Posted by aresridingflat
More detailted pic's, cause I can not get enough off it.
The coil won't fall out.
Limiting strap doing wat it was ment for.
In another spot, Mudmiep and Jeepee thanx for taking pic's
Trouble with the whinch, ground was not mounted properly.
Mudmiep taking it for a spin
Fun?
Not according to Dennis, by the looks off his face.
Eventually problems with the steering again.
But no oilleak this time
Fortunatly it is monday and we have had a excelent weekend.
Meanwhile at home again, checked the steering.
Broken pump shaft, coloured blue so maybe run a little to long without enough oil.
For de rest no real issue's except lenghtning bumptops and brakelines.
i'd call that a pretty good turnout after doing so many changes to the jeep and taking it out for the first time. it came out great.
That's AWESOME man.
Looking great! Awesome to see it moving and wheeling!
-Tim
thnx guys, it was awesome to wheel it again. It came out better then expected.
thnx DirkOriginally Posted by Cue-Ball
Hi
Just recieved an email from Kelvin at http://www.pscmotorsports.com/ telling me the parts for my p/s pump will be shipped tomorrow.
Upon first contact, He asked me to send in the pump so it good be fixed at no cost to me. Then later on he offerd to send the parts to be replaced by myself, so it would be cheaper concerning shipping cost.
Excellent customer service, thnx Kelvin.
Sorry for the red X'ses,
this is why http://www.mallcrawlin.com/forum/sho...700#post118700
I'd like to edit my own posts because off the broken links for the pic's.
But I do not have an edit button anymore.
I doubt you want me to quote all my posts.
I also want to edit the psc topic title cuase there service aint that great afterall,
have not seen anything yet and the are refusing to answer my emails.
Double click on your thread title in the "Jeep journals and members rides" forum view, you should be able to edit the title using this method...
Well is does turn bleu, but before I can do anything it opens the thread.Originally Posted by EMTimZJ
Doesn't matter wether I use IE or FF
your ZJ amazes me. Ive been following this thread from when i first got my jeep. And honestly, it seems as tho im making the same progress as you! Keep up the great work. this is definately one of the best threads on the site!
Thnx Paolo
It did work afterall, being very fast at the keyboard with Cut/Paste and a double "enter"Originally Posted by EMTimZJ
Thnx
Have not been up to a lot lately, some minor things I did do are,
A modification for the bracket where the hydro cylinder attach to the tie rod
Since the stroke of the assist cylinder(8") is bigger than the lateral movement off the tie rod
approx. 5"(did not take exact meas.) from left full lock to right.
So the previous bracket slided over the tie rod
The idea is to fab 2 large rings to put around the tie rod on both sides off the existing bracket.
The rings would prevent the bracket from sliding, same time I'll still be able to adjust toe-in
So took some solid axle, drilled a hole in it.
The bench did the rest.
result
Drilled some M10 holes for welding them on to the tie rod.
So eventualy it will look like this.
So still hopping from one to another subject.
The broken P/S pump for which I still did not get the replacement parts.
So I'll make an attempt to fix it.
De pump axle is broken at the point where it is splined to fit in the pump rotor.
So drilled a hole in the axle and through the broken piece, and tapped a M8 thread in it.
Put it together with an allen bolt,
already having doubts weather this will hold.
But how knows, piece off M8 thread and a lot off loc-tite
The "fixed" result,
in the rotor.
pump housing,
everything back together.
On to another subject.
Got myself a spare V8 with a little work.
It was diagnosed with a stuck or broken oil ring on piston nr 6
Took the right cylinder head cover off,
followed by the one on the left.
Right side exhaust manifold removed
The difference between cylinders 4 and 6
Nr: 8 does not look to good either.
The ones on the left are looking much better.
rocker-arms and pushrods removed.
a part dismanteld right cylinder head,
and left
Bottom view off the intake manifold, all that black stuff you see in most off these pic's.
Is caused, I was told by several people now, by random use off both mineral and synthetic engine oil.
Besides that this engine was treated with Forte Flush, an engine oil additief to clean the engine internally
This may have caused solid pieces to come loose and travel throuhg the engine and clocking oil ways.
Conclusion, this engine needs a rebuilt.
The right cylinder head removed, obvious cylinders 6 and 8 have had the biggest problems
The left cylinder head removed also.
Detail on the black stuff, it also smells real bad.
Finally the gear driven driveshaft which on the top side turns the distributor,
and on the downside the oil pump.
Well that covered what has happened lately.
SU.
Boy that's one nasty looking motor inside! I would think about getting all the larger components commercially cleaned once you get it all apart, otherwise they might have to send the haz-mat team to your house with all the solvent and rags you'd have to use! Any engine machine shop should be able to do that, or send you to someplace that can.
That sure is an option.
Right now I already poored several liters off diesel oil into the engine and let it soak for a while. Depending on that I'll see what to do next
Yikes, that plenum gasket is probably shot as well. Here is some info on it that may help when it comes time to rebuilding!
http://www.jeepforum.com/forum/showthread.php?t=233448
-Tim
Thnx, got some reading ahead.Originally Posted by EMTimZJ
So just finished fixing broken links.
Approx. 750 pic's visible again.
No jeep update, still waiting on part's
Users Browsing this ThreadThere are currently 12 users browsing this thread. (0 members and 12 guests) |
