OGDAK's ZJ moving 12/04/2022 - Page 7
Page 7 of 19 FirstFirst 1234567891011121314151617 ... LastLast
Results 151 to 175 of 462
  1. #151 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    Quote Originally Posted by Cue-Ball
    I am going to need to take the wife on a little vacation to the Netherlands to see it.
    You're welcome, good oppurtunity to get me some missing parts(ha ha).
  2. #152 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    Maybe in 2008 we will be ready for a big vacation, she has always wanted to go to Australia though, I just don't want to take a 3 week trip so I have been reluctant to go there.
  3. #153 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    In 3 weeks you can cover the whole off Europe.
    That is like 20 to 1 countries to visit.
    I would know what to do.
  4. #154 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    When the time comes I will hit you up for sure.
  5. #155 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    Member ZJARCHER's Avatar
    Glendale, AZ
    Man! Great job as usual... Youve covered so much in this build..Im surprised youre not designing your own ECU haha, beautiful work...
  6. #156 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    Quote Originally Posted by ZJARCHER
    LOL, that would come closer to my day to day job, then al that other stuff I did on the ZJ so far.
    Thanx.
  7. #157 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    what do u do for a living?
  8. #158 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    Quote Originally Posted by steves88vb
    It is listed in my profile info "software tester"
  9. #159 Re: Ogdak's ZJ - Steering & Cooling 06/09/2006
    Continuation
    Finally got the airintake done
    Cause the lack off space in the engine bay, the stock airbox and intake had to go.
    So I put a "Dual air tube intake" in.
    With filter,
    and pre-filter.
    Looks like this.
    Made some progress on the steering with some 90 degree connector's.
    tubing.
    An used trannycooler which from now on will be a steeringoilcooler
    Next to the stock tranny cooler
    Trying to fit everything together in a limited space.
    Well it doesn't fit. Not enough "height" between steering gear and powersteerpump.
    So had to cut that nice and shinny do.ge du.angry bracket from the bottom, but still not enough.
    Thankfully over a year ago I made an adjustable tranny traverse.
    So mounted the tranny traverse in the "low" position.
    This gave me like little less off an " between the multibelt and steering gear.
    Tubing cut to the right lenght, only need to press the connector's on.
    Cooler mounted and hooked on
    Tubing pressed and mounted
    Some regular maintenance stuff
    the old,
    the new one.
    Need to replace this seal.
    Also adjusted the tranny bracket for the t-case lever's
    Poored the first fresh oil(powersteer) tonight. This thing is starting to get in it's final stage.
    Only ?? nights off sweet dreams
  10. #160 Re: Ogdak's ZJ - More Steering & Tranny 06/20/2006
    Member KansasCrawlin's Avatar
    Jan 2006
    Kansas
    Glad to see your progress, your project is about to come alive! Congrads
  11. #161 Re: Ogdak's ZJ - More Steering & Tranny 06/20/2006
    Paradise, Newfoundland Canada
    Awesome as usual.
    Getting closer to having it running huh?
    Anthony
  12. #162 Re: Ogdak's ZJ - More Steering & Tranny 06/20/2006
    Thnx,
    Hope to have the engine running again within the next 2 weeks.
  13. #163 Re: Ogdak's ZJ - More Steering & Tranny 06/20/2006
    Engine upgrade.
    Changing the stock thermos for an 160 unit.
    What a (^&(^)(* job to do, eventually took the whole top mounting bracket(generator A/C pump) off to get some clearence.
    Here the 160.
    With a fresh gasket.
    Pipe on and installed the rest of the parts involved.
    Some electric parts, new distributor cap with rotor.
    Doesn't lool like a waste
    Time consuming job, wrenching in a very small area.
    Got it done thanks to a "Wrenching Platform"
    Also new plugs, ignition wires and a HO coil.
    Started on installing some small parts to be able to crank it again.
    New rear tranny seal and trannyoil pan with new gasket
    Unfortunatly a damaged thread in the tranny, damn
    Tried to get a heli-coil, but no luck. So tappped it with M8 thread
    Very carefully an allenbolt M8 in, not to tight only 17Nm required.
    Filling up several fluid level's, checking, double check and re-check.
    Started to be in doubt after all.
    Left the engine oil and filter because I added a portion off Forte Motor Flush.
    To get this chemical to do its job, the engine needs to be running for 20 to 25 minutes, then do the oil change.
    Also a good test for the modified cooling system.
    Fabbed up some sort of waste duct.
    Result, Big smile (let me translate this for you "It runs again") doesn't need more explaining I guess
    The girls are ready to roll.
    E-fan and steering working perfect, cooling temp just stayed below 176
    Oil pressure just below 3
    Earlier this year when testing the custom muffler I heard thicking from the engine, probably a valve rod or something.
    Have not heard it anymore.
    Finaly changed the engine oil and filter.
    An final(for now) underhood view
    Saturday with new engine oil had it running again and shot a video
    TESTRUN 1.1Mb
    Updated my checklist
    Got to say this last weekend definatly was a mile stone................
  14. #164 Re: Ogdak's ZJ - More Steering & Tranny 06/20/2006
    right on!!!
    looks/sounds freeking awsome
  15. #165 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Thnx, sounds a lot better when standing next to it.
  16. #166 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Awesome, I know that getting it fired is HUGE and CONGRATS!!!!!!!!!!
  17. #167 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Senior Member 2jeepsforus's Avatar
    Sep 2005
    Smethport, PA
    did you fabricate the duel intake setup, or buy it somewhere. I was thinking of running a second battery setup, but I would have to ditch the K&N I have now.
    Thanks,
    Dave
    1998 5.9, 5.5" Front/ 4.5" Rear (RE), 33/12.50's Trxus MT's, ARB Bumper w/Warn 9500HS, 231HD...SOLD...Stupid Divorce!!
    Quote Originally Posted by canadian_driver View Post
    start giving teachers guns... or tazers.... or clubs or just a 2x4 with a nail in it
  18. #168 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Junior Member Beest's Avatar
    Apr 2005
    The netherlands
  19. #169 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Congrats on getting it fired up man.
    Bet you can't wait for the shake down.
    Anthony
  20. #170 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Thnx Beest
  21. #171 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Member Grand Slam West Planner dads5.9's Avatar
    Broomfield, CO
    What a fabulous thread. I set here most of the evening looking through all the pictures and comments.
    I don't know how you take all the pictures. At the end of a long day in the garage the last thing I'm looking to do is a photo documentary of all the work.
    Great job!
    '98 5.9L, Clayton LA on 35s
  22. #172 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Thnx,
    Most off the time I take the pic's while wrenching, unless my hands get to dirty. Needless to say my camera is pretty greased up. haha
  23. #173 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Senior Member Skyline's Avatar
    Westchester, NY
    Great thread. Your girls are really cute. Looks like they were preparing for the match against Portugal, (sorry about the result...I was rooting for you!)
    '96 GC Laredo V8; Tom Woods front U-Joint Shaft; Kevins sliders; 4.5" RE springs; Kevin's track bar conversion; JKS short arms, discos, and track bars; Pro Comp 16x8 mags with 305/70/16 Mud rovers.
    Support Our Troops!!!
  24. #174 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Thnx,
    But that wasn't because off the worldcup football.
    It was because off the 4th and last night off the evening marches which my oldest 2 attended this year.
  25. #175 Re: Ogdak's ZJ - V8 testing 07/01/2006
    Jackson NJ/ Daytona Beach FL
    great build mate. looks like it's all coming together.
    whats your exhaust setup like? i saw that you used a random tech cat and stock manifolds (i think), but didn't see the muffler. sounds like either a small magnaflow, a bullet muffler, or maybe a glasspack. regardless, sounds great.
