looks good.
@Kraga thnx
So August 2005, only 1 month till 2nd Dutch Jeep Camp.
Last item on the La's, is radius arms
Stock, the FUCA is between axle and unibody.
But since that will not work on a LA setup, we make 1 or 2 radius arms.
So my radius arm runs from the UCA bracket(HP30) down to the FLCA and is also lenghtwise adj.
To set, in the first place pinion angle and caster.
So that's just about it for August, happy holidays
September 2005, JEEPCAMP, went there as a Marshall without my ZJ.
Had fun though for all 4 days, Will be there again in 2006 WITH my ZJ
So the rest of september will be a little off everything, just looking through
So with a paint burner, lots off terpentine and sander cleared the area for the unibody sleeves.
Just plain tiles, always handy
So time to start painting things. I used RX5 as a ground layer on all untreated parts.
Started with the 8.8
The Sleeves
The CA's
And the 8.8 again
Fabed up some endlinks out off 50*50*5(metric)"corner line"(I know, you tell me.) for my teraflex disco's.
Time to do some unibody welding
When I started, Kraga's Unibody Welding Bible was not posted yet. but I have faith that things won't tear off.
Got the sleeves set-up and lined out with 4 bolts.
I only welded the sleeves to the unibody where there was 2 layers off sheetmetal.
And besides that a bunch off plug welds.
So here comes October 2005.
That's pretty much how I welded my subframe on as well.
I wanted to mention... that pass side UCA on the D30, you should box it in. I'll bet $20 that it will fold up after a summer of wheeling. I've run 3 D30s under my Jeep and they all have done it.
Nice work.
Wow, thought I had everything covered.Originally Posted by nate
Never heard about them folding up, but I like to prevent it.
So how should I box it.
@Nate or anybody, A pic off a boxed pass. side UCA.
Would be a big help.
Thnx Nate
I already looked at Kevin's LA setup, but that would mean redoing the whole front, there must be an easier way.
I also looked at Clayton's setup, They don't seem to be doing anything for it.
Open for option's
put a plat on the back side to make the bracket a box instead of a u-channel.
So I fixed my weak link, D30 pass side UCA mount.![]()
Thnx Nate & Kraga![]()
Found some pieces off metal laying around.
top is ¼" and base is even thicker like 8mm![]()
Thanks![]()
So what do you think, will this hold up.![]()
This is great. It's exciting seeing all the big build threads goign on right now. It's needed, because everytime I see someone else go make progress, I'm like "Ya, I need to go get something done on my rig."
So what are you waiting for?Originally Posted by OverkillZJ
LOL, just came from there, now heading for a beer.
October 2005
So if JEEPCAMP 2005 was good for anything, then it sure was my motivation.
So on with the paintjob, after the untreated parts being done with RX5.
It is now time for some layers of RX10.
First the 8.8, obvious the first layer
"the" unibody.
"the" Long Arm's
WJ knuckles
HP D30
Just a forum![]()
Does not need explaining I guess
Modified front U-beam back in place
Drilled out the oem prop weld's
And "stuffed" them again.
And painted
Part 1 off October 2005
October 2005 part 2
Where did I left of, that's right got some more detailed tire-carier close-up's with 35"
Because off the fact that the mounting plate is adjustable,
The spare is very close to the rear of the ZJ
The "lock"
The "hing"
Open
And on with the paintbrush.
So finally on with some stuff for the endresult.
I am usualy not in to "bling bling" but a litlle accent here and there would not hurt.
So, assembling and installation of the LONG ARM's
JJ's installed
Parts needed for a set of radius arm's
A set of FLCA's
Almost in place
In place
And that is the end of October 2005, only 3 months and 200 pic's behind reality.
Very Sweet!
Wow,
Awesome man.
Wow! very nice. Keep up the great work.
Just have to make sure to keep my "grease" on level.Originally Posted by 2jeepsforus
Looks great, the passenger UCA looks nice.
One thing ot consider is that alot of people claim having that much round bar comming off yoru JJ's will cause bending problems. I run just as much as you on my joints and have had ZERO problems. but i get alot of greef from people.
on your tranny cross member did you trim the pinch weld off the frame so you could run the U channel further to the front of the vehicle?
Yup I did trim the pinch weld, something like 5 or 6".Originally Posted by Kraqa
Total lenght of the U-channel is approx. 41".
As for as the round bar near the JJ's and a lot of other stuff.
Time will tell if things will hold, but there will always be something called
"the weakest link"
I do not wonder what that will be.
November 2005
Something different,
What is missing in this pic.
That's right visco fan.
Will be replaced with this fod tauus 3.8 90-95 e-fan, does not need further explaining.
Made some hardware.
In place
Another issue, rear shocks.
I am gonna go XJ style
Near the BS on the in/downside of the unibody.
With som rivnuts
installed
some pieces of square tube and a u-beam.
Multiple shock mounting points for adjustment.
Almost the final looks, just some paint missing
8.8 install time
How nice, stock 15" * 7J ZJ rim's
UCA and LCA in place.
What is in the box "More bling bling"
Eagle Alloys
SERIES 186, Super Finish, 16x10, Offset -24mm, BSM 4,5" en load 2100lbs
Good for now.
Those are some 'blingy' rims.
Can't wait to see it all finished man.
There is a very good chance I'm going to copy at least some of the elements of your rear bumper. All of your work looks to be of very high quality.. What tools do you use for cutting your steel? It all appears to be laser cut..?
Once again, it's coming along nicely.
Cam
Me tooOriginally Posted by ILikeMud
You are welcome.Originally Posted by ATL ZJ
Thanks, Yes most is lasercut.Originally Posted by ATL ZJ
But would not want to go without a 125mmų 1mm thick cut-off wheel
