OGDAK's ZJ moving 12/04/2022 - Page 13
Page 13 of 19 FirstFirst ... 345678910111213141516171819 LastLast
Results 301 to 325 of 462
  1. #301 Re: OGDAK's Cracked 9" 11/19/2007
    Fresno, CA
    Just read this entire thread in the past couple days. All I have to say is AWESOME! Can't wait to see the HP44 and 9 under the rig (and hopefully the 'mogs sometime in the near future).
  2. #302 Re: OGDAK's Cracked 9" 11/19/2007
    Quote Originally Posted by ZJ Pappy View Post
    Thanks, may take a while to complete
  3. #303 Re: OGDAK's Cracked 9" 11/19/2007
    Nov 2007
    Alaska
    I just read this entire thread> It took a bit but was worth the read. I cannot believe the amount in detail and work you put into this ZJ. You have pretty much completely disassembled your ZJ twice in this thread.
  4. #304 Re: OGDAK's Cracked 9" 11/19/2007
    Senior Member adam99wj's Avatar
    newfoundland canada
    nice build !!!!, i like that attention to detail, keep up the good work
    99 WJ, D60/14B, 5.38s, 203/D300, 39.5"s, H1s
    It was a jeep thing, but that shit broke
  5. #305 Re: OGDAK's Cracked 9" 11/19/2007
    Thanks guys, things will continue as soon as I have a decent steel cut off saw.
  6. #306 Re: OGDAK's Cracked 9" 11/19/2007
    Fresno, CA
    Well you better get one soon, because I want to see some updates.
  7. #307 Re: OGDAK's Cracked 9" 11/19/2007
    So on with this build, somebody got to do it.
    Some raw material I'll try to make my 9" brackets out off.
    Box steel 120*60*6
    Also started on the rockers.
    Made some kind off rail, to get a somehow straight cut.
    Straight enough.
    Part below the rear door is out.
    Up front
    Still a challenge to work around these to maintain/improve some uni-body strenght.
    So finally made a start with cutting up the Zj , whats to come?
  8. #308 Re: OGDAK's Cracked 9" 11/19/2007
    Fresno, CA
    Quote Originally Posted by ogdak View Post
    I love when sheet metal comes off. Can't wait to see where this goes.
  9. #309 Re: OGDAK's Cracked 9" 11/19/2007
    On with the side bars.
    The B-pillar goes on to the bottm off the original rocker panel.
    Need to cut off a piece cause I want to run a piece of boxsteel underneath.
    Also on the front a piece needs to be trimmed.
    Enough clearance on the bottom
    Piece af flat bar to create a nice 90 degree base and a good welding undergound for the boxsteel.
    This is how I want it to be.
    Another trimline at the top to make some more room.
    Support bar on the front.
    and fixed.
    On the bottom cuf off most off the pinch seem to run a corner piece from the inside
    to sandwich the original side panel.
    Got myself a 14" cutoff saw, excellent tool for this job. Earplugs are a must though.
    The outer box will attach like this.
    I'll be runing a piece off flat from the leftlowercorner on the inner box
    to the leftlowercorner on the outer box.
    from the top
    finally from up front.
    SU next year.
  10. #310 Re: OGDAK's Side bars 12/31/2007
    Looking good man.
  11. #311 Re: OGDAK's Side bars 12/31/2007
    Nov 2004
    Sweet man! Did you make any decisions about beefing up the unibody at all, like sleeving the b-pillar?
    Poetry in commotion.
  12. #312 Re: OGDAK's Side bars 12/31/2007
    Fresno, CA
    Nice setup! Great detail too...it helps me get an idea of what I want to do when I finally do mine!
  13. #313 Re: OGDAK's Side bars 12/31/2007
    Virginia, Hburg
    So your going to box those two together? sounds like a bad idea, at lease leave a few points for a hi-lift.
    WJ-OME-JKS-KEVINS-32' BFGS-SOLD
    WK-DayStar-Spidertrax-BFGS-whoohoo
    Search, helping dumbasses everywhere.
  14. #314 Re: OGDAK's Side bars 12/31/2007
    Thanks,
    @suicidetirezj, don't have a fixed plan yet to deal with unibody strenght.
    @derekl, the two boxes together are 4" so I still can stick a hi-lift underneath.
    Boxing them together will give a lot off extra strenght.
  15. #315 Re: OGDAK's New tool 09/06/2008
    I know it has been a while, but not forgotten.
    Got my latest toy this week, about time to start on the family car again.
    specs:
    Eingangsspannung: 230V 1PHASE Schneide-Strom regelbar: 20-50A
    Sicherung bei MAX 50 A: 25A Zündung: HF Zündung
    Stromverbrauch bei MAX 50 A: 5,5 KVA Druckluft-Anschlusskompressor: 4,5 Bar 200 Ltr./minute
    Netz Frequenz: 50/60 HZ Max. Schneideleistung: 14 mm
    Einschaltdauer bei 50A: 60%
    Netto Gewicht:11 kg
    Leerlauf-Spannung: 210V Abmessungen: 327X250X155 mm
    Need to practice with this, so I'll start to try to fab up some brackets for the 9"
    Made a template out off 6mm(1/4") plyboard
    6mm is to thick, tip doesn't thouch the plate, new template out off 3mm(1/8").
    First result.
    So after some mild grinding and sanding, not to bad.
    On to the next one, but things go bad here.
    Bad picture, I know. Looks like the ceramic cap broke, so air is going averywhere except where I want it.
    Don't know why it broke, but w'll keep trying.
  16. #316 Re: OGDAK's New tool 09/06/2008
    On with the cutting practise, complete failure
    Made a new template, and put a new ceramic nozzle on the torch.
    That made a difference
    After some grinding and drilling
    Took a standard bushing from an oem lca for fitment.
    Should be come somthing like this on the 9".
    reinforcements
    Time to start cleaning up on the 9"
    Found this weld, need to look into how bad this one is.
  17. #317 Re: OGDAK's preparing the 9" 09/08/2008
    Aug 2007
    SLC, UT
    looks good
    welding up the back of that 9" should be no problem
  18. #318 Re: OGDAK's preparing the 9" 09/08/2008
    Thanks,
    Started grinding out the bad piece off the weld, isn't that bad afterall.
  19. #319 Re: OGDAK's preparing the 9" 09/08/2008
    Got the new wheels today at Schiphol airport(Amsterdam)
    Next step is to design some beadlocks
    SU next year.
  20. #320 Re: OGDAK's New Wheels 12/31/2008
    You always seem motivated at the end of the year. Did you finish the slidders? I would like to see how they turned out.
  21. #321 Re: OGDAK's New Wheels 12/31/2008
    Quote Originally Posted by jsteves View Post
    Need to be welded in, that will be one off the first things to be done next year.
    Need them for the jackstands so I can pull some axles.
  22. #322 Re: OGDAK's bead_lock design 01/25/2009
    So finally started to clean out the shop to create workspace.
    Finished with my bead-lock design
    5 off each are ordered
    to be continued.
  23. #323 Re: OGDAK's 9" truss 02/01/2009
    This weekends progress, still needed to make a truss for the 9".
    Started with a 9mm(0.36") piece off MDF to make a template.
    Then take over on a 5mm(0.20") thick steel plate.
    With the plasma cutter the sinuous part,
    with a 1mm(0.038") cutoffwheel the straight pieces.
    Finished part 1
    Made a second, nice fit
    Drilled 2 holes 30mm(1.25") for mutual firmness and fixation.
    Then a tube 30mm wall 6mm(1,25"/0.25") through
    Have been experimenting with some lenghtwise cut tube 60mm wall 5mm (2.25"/0.20") for the sides,
    but I don't know yet wether there will be enough room for it.
    Time to weld the truss
    However the truss exactly sists over de breather hole,
    seems familar also happened to me on the 8.8 a couple off years ago
    plumbed.
    Truss tacked.
    Then a very time-consuming job to weld the inside, bits of 6 a 7 cm(2.5"/3" to "prevent warp.
    1 piece left
    On to the outside
    Checked the axle tubes for straightness, seems to be okay.
  24. #324 Re: OGDAK's 9" truss 02/01/2009
    Member KDUB's Avatar
    San Antonio TX
    That looks sweet. Keep us posted with the progress.
    96 ZJ, 5.2L, 231
  25. #325 Re: OGDAK's 9" truss 02/01/2009
    Senior Member jborushko's Avatar
    Mar 2008
    stationed at tacoma wa
    great job on that truss!!, i should get you to do mine! lol
    96 ZJ swapped in 5.2, 242, 14bolt rear, big ugly home brew bumper, 7.5" of lift in the front 9" in the rear, long arms, hummer wheels with 37s... (dont worry front axle is next)
    It should be heavy. Weight is a sign of reliability. If it doesn't work, you can always hit him with it.
    -e-boner
There are currently 14 users browsing this thread. (0 members and 14 guests)
