My problem was getting all the fittings hooked up correctly.
Originally Posted by nate
I removed ABS system from a 4.0 ZJ and it too was easy... my V8 compartment is a little more packed, but removing ABS is on my list. Its been disabled for years.
AW
I'm arguing for mear amusment now...
i'm going to coil my control arms so gravel doesn't hurt them!!!!
trolling is not allowed..
To be honest with you, it looks like a huge pain in the ass. I think I will finish yanking the sensors and yank the bulb behind the dash. Thanks for the write up though.
I thought that just removing the fuse would cancel out the entire system... Im going to be putting an 8.8 in real soon and I don't plan on hooking up the ABS. So after removing the fuse, will the light always be on? I dont reall want to rip my dash apart... Im not good with fragile shit.
The light will stay on unless you remove it, or it burns out.
The fuse will disable it but removing the ABS pump gives you a little more room under the hood.
pull fuse + abs pump relay = no light
Nice, there ya go.
i kinda like the light....
I get people that ask what that light is on the dash and i just tell them "It means my Awesome Braking System is working"
those coil help prevert overheating in the koonuter valve, because everyone knows that can lead to the carb belt snapping and ruining your piston return springs.
I always figured the light was a heads up suggesting you to alter your braking system.
LMFAO!!! I swapped a SR5 gauge cluster (adds a tach, lights and other gauges) into my 87 Toy. The cluster was from a 4 runner and it has an awesome light that can be illuminated, it says "back door". It took me 30 min to install the new cluster, and about two hours to figure out what I could use (other than a switch) to illuminate the "back door" light on the cluster. "Back door" now = my swapped in electric fan is on, you love the "back door" light mod, I know you do....
ok, heres my experience with this:
i have a 95 4.0 that has discs front and rear from the factory. and i just swapped axles and still have rear discs.
the problem was i couldnt get a good firm pedal feel with the brakes all hooked up. we bled them many times with no luck. well the abs doesnt/cant work with the new axles anyway. so finally i decided to just bypass it and pull the abs pump.
i did alot of reading and thought it would be realitvely easy. but it wasnt. the abs pump had 2 inlets off the mc, and 3 outlets (one for front left, front right, and rear) all of which had different size/pitch threads, and all had bubble flares, not standard flares. i went to 2 different parts stores trying to find bubble to std. flare adapters and didnt have any luck. so i tried just getting a 't' with the 2 different size threads on them that matched the ones that came out of the abs pump, no luck. all the brake 't's and fittings at the parts stores are for standard 3/16" us thread standard flare fittings.
so..... in order for me to get all the fittings back to the 3/16 like i needed i had to re run all the brake lines, from the front to the back, and across the motor to the pass side. the driver side was short and easy.
the reason i had to do it that way was the premade lengths of brake line at the stores had the 3/16 std. flare on both ends, none had the 3/16 (caliper end) to whatever size and thread the abs pump end had.
and i have zero experience flaring brake lines with a flare tool. so i didnt want to cut it off and put a 3/16 fitting on then flare it to std. flare. the idea of doing that with it still in the vehicle didnt appeal to me.
but i got it done, now the jeep has all new brake lines, and if i ever damage one i can easily replace them with the standard flare 3/16" pre length lines. no adapters and crazy extensions to deal with.
I did this on an explorer.....but it should also be applicable to a Grand (I haven't taken a real close look yet). If you take the ABS pump out you'll have an unused pump relay.....or if you want to go the easy way and pull the relay you can just cut two wires and rewire it for another use. I'm not a big fan of a clucker-fawk of wires and shit mounted everywhere so with a few wire cuts and spices I was able to have the relay for my lights in the factory fuse/relay box. It works nice because at least on the ford, there was a nice beefy power wire already feeding the relay. All you need to do is hook your switch wire to the relay, and change where the power output wire goes. I know on the ford there were 2 relays I could have done this too....if you have a Grand with a security system that you don't care about theres a box under the glovebox with a few relays in there that can be re-used. Just a thought for some of you guys!
OhioZJ,
A big problem with the ABS system is that if air gets into the abs pump or valving it needs to be bleed to get it to work right. So if you take a long time to swap axles and the master cylinder runs dry its a nightmare to bleed.
In my case on my '93 you need and scan tool(not a cheapie either) to put the pump into bleed mode. Before it will do that it does a self diagnostic and checks all the sensors. So I had to hook back up all the sensors and then use the scanner to get the pump to purge itself of the air and then you can bleed the system. I'm guessing this is the problem you ran into on your '95. Without a scanner you couldn't properly bleed the abs system.
When I get the chance I'll be gutting my ABS as well.
