"Fabricated" updated 8/26/08 new paint/wheelin pics - Page 7
Thread: "Fabricated" updated 8/26/08 new paint/wheelin pics
Page 7 of 7 FirstFirst 1234567
Results 151 to 172 of 172
  1. #151 Re: "Fabricated" updated 7-17-08
    Charlotte, Nc
    I have JKS quick disco's, ARB front bumper, custom rear bumper with tire carrier I made, sliders still being finished I made, a HP30 front axle swap with detroit EZ- locker, a 242 Transfer Case, KOR's roof rack, 100 Watt aircraft landing lights, custom made LED rear tail lights, black rockcrawler rims, stripped interior and rhino lined, custom rear storage box for recovery gear, 4" utility lights cut into ARB instead of amber turn lights, LED running lights on the side of the ARB bumper, ARB bumper trimmed for 35's, inner fender well up front all excess metal cut out and beaten over so it doesn't rub on my tires. if I forgot anything I will update soon, also some off road pics will be added as I got only poser shots for now, all others are on my other comuter.
  2. #152 Re: "Fabricated" updated 7-17-08
    Jan 2008
    Wichita, KS
    Quote Originally Posted by 19onebadzj96 View Post
    Congratulations, start your own thread!
  3. #153 Re: "Fabricated" updated 7-17-08
    Charlotte, Nc
    IF YOU READ THE FIRST PAGE YOU WOULD HAVE FOUND:
    "I have JKS quick disco's, ARB front bumper, custom rear bumper with tire carrier I made, sliders still being finished I made, a HP30 front axle swap with detroit EZ- locker, a 242 Transfer Case, KOR's roof rack, 100 Watt aircraft landing lights, custom made LED rear tail lights, black rockcrawler rims, stripped interior and rhino lined, custom rear storage box for recovery gear, 4" utility lights cut into ARB instead of amber turn lights, LED running lights on the side of the ARB bumper, ARB bumper trimmed for 35's, inner fender well up front all excess metal cut out and beaten over so it doesn't rub on my tires. if I forgot anything I will update soon, also some off road pics will be added as I got only poser shots for now, all others are on my other comuter."
  4. #154 Re: "Fabricated" updated 7-17-08
    Member Rangerwj's Avatar
    May 2008
    Golden, Colorado, United States
    my bad 1996 i read the whole thread but must have totally spaced it out.
    2000 WJ. some lift and mods. deathwobble.
    CSM How High Off Road Club
  5. #155 Re: "Fabricated" updated 7-17-08
    Charlotte, Nc
    im just messin haha just makin a point to read before askin
  6. #156 Re: "Fabricated" updated 7-17-08
    Senior Member zj95's Avatar
    Albuquerque nm/ Tucson Az
    what all is needed convert a waggy to 8 lug?
    95 ZJ/ 5.2 / HD Dana 44 front / 14b rear / 5.5" CLAYTONS / 38'' Grooved TSL's / CLAYTONS belly skid / NP231 w/sye
  7. #157 Re: "Fabricated" updated 7-17-08
    Jan 2005
    Renton, WA
    new spindles, hubs/rotors, 3/4 ton chevy 10 bolt or d44 brake backing plates, bearings and seals. The waggy uses 1 5/8" inner and outer bearings, the 3/4-1 ton chevy stuff is 2" inner and 1 5/8" outter. but no need to change stub shaft, brakes, lock out hubs anything else. Stock waggy calipers bolt right on.
    8" RK/ Acos lift, rancho rs9000x shocks 32" extended, Claytons Longarms, with 38X12.5 TSLs, Custom Rear bumper, custom front bumper, Waggy D44 front 4.56's and Detroit locker with warn premium hubs and yukon alloys and 8 lug conversion, D70 out back with 4.56's and Welded, 242 transfer case, 1 Ton steering setup. Rhino lined interior, olive drab exterior, and PSC 1.75" hydro assist ram.
  8. #158 Re: "Fabricated" updated 7-17-08
    nice thx... might be getting a waggy 44, and i have a chevy 44 sitting out back so ill be doin the conversion
  9. #159 Re: "Fabricated" updated 7-17-08
    Jan 2005
    Renton, WA
    I have recently painted my jeep woodland camo, and sold my 38 tsl's for 38x12.5 tsl/sx. Here are some wheeling shots from evans creek 8/23/08:
    My buddies bronco totally died. Starter F'd up, and the clutch was full of mud and slipping. so I had to winch him the rest of the trail which sucked as he is a 6k anchor. with no PS.
    After our 12hr day, on one single trail that should have taken us 15-20min. All because of one nasty mud hole. I broke a Yukon Alloy Drivers Side stub shaft. The yukon super joint held up though just needs new caps,seals,snap rings, and zerks.
  10. #160 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Dec 2005
    Central Mass.
    I may be wrong, but isnt a d70 a full width and a waggy 44 the same width as stock zj axles?
    Did you shorten the 70 or ad spacers to the 44?
    Looks great.
  11. #161 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Jan 2005
    Renton, WA
    my dana 70 is a dodge dually so its 65.75" wms-wms stock waggy is 61" wms-wms then I added 2" spacers per side. So 65" front 66" rear
  12. #162 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Senior Member SuicideTireZJ's Avatar
    Nov 2004
    The drinking town with a college problem
    Meh, looked better before the Camo
    Poetry in commotion.
  13. #163 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Senior Member dp96zj's Avatar
    Texas
    bad ass rig, whatever color you paint it
  14. #164 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    i liek the camo dude.
    not to hot on the fender tubes. the front ones look liek they are just hangin there.
  15. #165 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    i'c also drive the stinger into a wall to bend it up.
    i never understood why people point them so far out. they are to stop you form an endo not help you slid up stuff.
  16. #166 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Senior Member Goosed76's Avatar
    Mar 2008
    Saint Helens, OR
    love the camo. My cousn just did a Realtree APG-HD camo wrap job on his Nissan truck, looks sweet, was considering something similar, also like the alive drab/military look.... mine needs paint, or something.....
    93' ZJ, 4.0L, 3" lift, 31's.. SOLD.
    New Ride- 1998 Ford Ranger 4x4, 4.0L, 5-Speed, 4x4.
    NEW JOB!!!!! NEW BABY!!!!
    Now considering another XJ/WJ/ZJ purchase as a baby mover- No room in the Ranger.
    Leaning towards XJ, 99-01.....
  17. #167 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Jan 2005
    Renton, WA
    Thanks for the compliments.
    Kraqa: the stinger is up about as far as I could before toucing the winch.
    The tube fenders are the start of my soon to be exo cage/ internal
    Suprisingly the front tube fenders have taken a beating, between the tight trees here Ive watched them slide across, instead of catching and ripping off my fenders. Sane with the rears, I would have lost the right side side window twice if it wasn;t for the rear tubes.
    I am going to weld some 1/8" plate between the fenderes and the tubes, then start on some cross bars over hood and cowl for support on the front brs. Also on from the inside tube under headlight to the unibody, where my bumper sheeve is.
  18. #168 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Texas
    Any progress with this thing? This build was the shit!
  19. #169 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Mar 2008
    Mukilteo, WA
    Sorry to say he parted out this rig.
    I have the suspension, front bumper, winch, lights, and some other parts sitting in my garage waiting to go on my ZJ.
    '98 ZJ 5.9 soon to have 5" Clayton LA's and 33" BFG KM2
  20. #170 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Quote Originally Posted by NIK5.9 View Post
    Who cares?
  21. #171 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Mar 2008
    Mukilteo, WA
    dp96zj was wondering what happened to this ZJ, just letting him know. Whats wrong with that?
  22. #172 Re: "Fabricated" updated 8/26/08 new paint/wheelin pics
    Texas
