Thread: Beadlock install write up with pictures
Results 1 to 10 of 10
  1. #1 Beadlock install write up with pictures
    Member skrracing's Avatar
    Snowflake AZ
    For all the guys that might have an interest in installing real beadlocks... Here is a write up.
    I placed an order from All J Products for a set of 5 High-Impact Rock 8 Beadlocks. These are going on the ZJ but the write up will work for any vehicle. I ordered 15 X 8 X 32bolt beadlocks. They come in all different sizes and they even have true DOT wheels if you think you might need them. I did not have concerns about it so it was not an issue to me to just use their standard beadlock.
    I went with these because of the rim ring. It is not just a cut flat plate but has a lip that really fits the tire bead just like a normal wheel. I am also a black wheel kind of guy but you can get these in chrome if you like. I went for the steel wheels as well.
    I am also using BFG Mud Terrain 33 X 12.5 X 15 tires at 30 psi
    Let me say you HAVE TO have a torque wrench to do this. This is not something you can let slide or you are going to have major problems. You have to also have a lot of patience.. it took right at 12 hours to do 5 wheels and tires. Keep in mind I did not rush through it and you have to torque and torque and torque many times to pull the right down right.
    I had the 5 tires broken down at good old Mikes Tires.
    Lay one of the wheels with the beadlock side facing up. Use some soapy water on the back of the tire bead and slide it over the wheel. It goes on very easy and drops all the way down so that the top bead is resting against the beadlock rim.
    When you first look at the distance you will think, “There is no way that rim is going to work right”. But use some longer bolts with washer in 4 places to start pulling down the rim. Keep the bolts run down at the same distance as you work around just enough to use the provided bolts. I picked up the longer grade 8 bolts from the hardware store. They were 5/16 x 1.5 x 18. Be sure to replace the longer bolts once you have the others started.
    Be sure that the tire is centered on the lock rim. Use a cross pattern and start pulling down all the bolts the same amount. I used some different color makers on the bolt heads to help keep track. I marked every fourth bolt so that I could do a cross pattern on one color then the next and so on until they are all torqued down. I went 3 steps to do this.
    It takes a lot of time but they will get to a point where they do not turn any more as they are torqued.
    Then take the wheel and stand it on another wheel with the beadlock facing up. Use soapy water again on the back side of the rim. Push down on the top of the tire so that the back side starts on the rim. Remove the core of the air valve and add air. The abck side will pop on with no problems. Fill the tires and add the core back in. Top off the pressure if needed. Have them balanced and install them back on your vehicle.
    Remember these are new wheels so check the lug nut torque after 100 miles or so and check an eye on the beadlock rim torque as well.
    I can now air way down without problems of the tire popping a bead. These wheels are very solid and I am sure they will stand up to a lot of abuse and believe me they will see a lot. Later…Clint
    LOST ZJ
    www.lostzj.com
    KE7JLP
  2. #2
    Great writeup, and good idea on the colors!
  3. #3
    Louisiana
    price?
  4. #4 Hope this helps
    Snowflake AZ
    I bought a lot of other stuff for the XJ at the same time but I think they were like 170 each. Later...Clint
    LOST ZJ
    www.lostzj.com
    KE7JLP
  5. #5
    Sep 2005
    Texas
    A buddy just sent me a link to this so I figured I'd throw a few of my pics in here as well. I just mounted a set of 35 x 13.5 Krawlers on some similar 15" Allied beadlocks. The rings have been painted after being hit with a grinder to clean them up and I also used black bead sealer on both beads to add a little more protection. My pictures aren't in any real order but I'm sure you can figure it out. I can't wait to try them out.
  6. #6
    Quote Originally Posted by The Mean Fish
    Looks like this newb will fit in rather well around here!!
  7. #7
    x2
  8. #8
    Louisiana
    mmmm krawlers
    just whish they were not $$$$$$$$$$$$$, $$$$$$$$$$$$$$ BS BFG pricing
  9. #9
    Sep 2005
    Texas
    Quote Originally Posted by LouisianaZJ
    mmmm krawlers
    I actually bought them used from a guy in Florida and was able to get free shipping to Houston through a buddy in our local club who does logistics and freight... I would have never paid full price for them new, the lowest I could find was ~$295 a piece shipped. I got all 4 for $900 and they still have the little nipples on the tread.
  10. #10
    Omaha, NE
    Isn't that the international Mallcrawlin sign?
    Hunter
    04 4.7 HO limited
    04 4.7 HO Overland
