1998 AW4 breather ?
Thread: 1998 AW4 breather ?
Results 1 to 5 of 5
  1. #1 1998 AW4 breather ?
    Calgary Alberta Canada
    Where is the breather for a 1998 AW4 tranny ?
    I have looked just about everywhere I can on the tranny and can't find it.
    The tranny started puking fluid from the torque seal and the tranny output seal all of a sudden. Before pulling it, I wanted to check to make sure the breather was not plugged.
    Is it in the bell housing like my 46RH? ...... I hope not. I found out about that breather the hard way. Sucked in a lot of water in a deep water crossing a while back.
    These are from my 46RH.... Is the AW4 the same?
    [/img]
    Life is 10%circumstance and 90% reaction....
    Even nice people get hit by trains
    Lawrence, Ks
    Mine's on top of the tranny zip tied to the TV cable, but it's a 93. I couldn't immagine a 98 being much different.
    ZJ: 6.5" LA's... 33's and stuff.
    Senior Member nate's Avatar
    Palmer, AK
    Did you put an AW4 in your Jeep? Stock 4.0 tranny for a 98 is 42RE.... and it's in the same spot. Same deal with all Dodge trannies.
    Guess I've been lucky, no water in the tranny from doing a bunch of water crossings like this:
    03 Subaru WRX
    98 Dodge Ram 2500 CTD
    98 Jeep ZJ
    95 Dodge Ram 3500 CTD
    I posted its a 98, Its actually a 97. I think it's a AW4 but I could be wrong.
    I found the tranny breather line. One of the zip ties was to tight crimping the hose closed.
    The picture above is pretty much how I screwed 2 trannys. The first time I stalled in water that deep and the second I miss judged how deep the hole was I was going into. It was a very soft bottom and I sunk. I don't think the breather hole is a huge issue as long as you keep moving. Once you stop though Your tranny takes a drink.
    The last tranny I put in, I modified the breather. It now goes up as high as I can get it under the hood.
    I have no clue why I did not do that after the first tranny.
    Cheers
    Louisiana
    you have a 42re or something like that
    the aw4 vent is ontop of the trans
