Powertrain... Dropping a 5.9 in the ZJ OH YEAH - Page 3
Thread: Powertrain... Dropping a 5.9 in the ZJ OH YEAH
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 99
  1. #51
    lookin good jerod! a cammed 5.9 is going to be SWEET
    Very nice, this is going to be WICKED when your done.
    Jun 2005
    Fort Collins, CO
    what cam did you go with?
    Livermore CA
    Comp Cam 262... sounds killer.
    One prob arose.... BRAND NEW thermostat did not open, and I didnt let it over heat but the Rad BURST anyway... Ill have a new Rad tonight and new T stat and should be all done...
    I did drive it and I gotta say... its just RIPS.
    AW
    i'm jeliouse.
    now get it ready for GSW
    Jun 2005
    Fort Collins, CO
    im jealous too. ive still got a stock station wagon with a 185,000 mile 5.2
    id really like to see a video of this when your done 5.9
    Livermore CA
    There is some video... on a camera phone... waiting for that to get to me yet.
    I installed a New Napa Tstat (stainless) and new Radiator. Runs perfect, although Im still taking to a shop to get it fine tuned, ie Timing.
    Here are the rest of the pics...
    All the goodies painted...
    Checking for leaks, keeping a fan on it while its running, It was a HOT sunday.
    Some bling bling on the oil pan...
    5.9 Badge... which is now on the rear hatch.
    Done.
    Thanks for reading all my crap.
    AW
    Livermore CA
    Lost link...
    sorry.
    2nd floor Yuma, AZ motel
    looking good. i bet i know from whom you got that amsoil.
    Yea baby
    Jun 2005
    Albany, NY
    damn... looking good. It all looks way too familiar (with the exception of the cams, etc). I just got done doing the 5.9 swap into my 94. Glad to hear it started up first try. I only have a factory 5.9, nothing special, and I love the amount of torque I have... I cant imagine what it would be like with better cams, etc.
    Congratulations.
    Kenny
    Louisiana
    still got the pImP grill on that thing?
    what kinda front axle you running now?? looks like a hp44 or somethin?? might just be a wierd diff cover though
    Livermore CA
    Quote Originally Posted by LouisianaZJ
    8.8 rear... and 30 front, w/home brew rock ring... Im still babying that thing. Saving for a Rock Crusher.
    NC
    Sweet.
    Looks awesome!!!!
    I have a couple of questions:
    Did you get the 5.9 from a 5.9 Grand or just a Ram truck?
    Did you have to do anything special with the balancer? I heard the 5.2 is different than the 5.9 in that respect.
    Any other problems you ran into?
    Very good job!
    Jerod!
    Kicks ass!!!!
    Gui
    Jan 2005
    Wherever the Navy needs me
    Quote Originally Posted by AprilzWarrior
    your 5.2 valve locks should have worked. the 4.0 and the 5.9 valve locks are even the same.
    Im going from a 5.2 to a 5.9.
    BUT there is no way in hell that the 5.2 lock will work. Reason being that Im running the mopar performance springs which are larger than stock, so I needed larger retainers. Hence needing larger locks... I tried the stock ones and they slip right through the retainers.
    AW
    That's strange... I'm using 5.9 performance springs too, with the larger retainers... maybe my 4.0 locks are superior
    Livermore CA
    AW
    Um not... keep reading... Summit sent the wrong retainers (Comp Cams), thats why they slipped through... NOW that I have the MOPAR retainers, all is good.
    Livin La Vida 5.9
    Livermore CA
    Quote Originally Posted by Grandsrus
    Looks awesome!!!!
    Very good job!
    Good question... The Harmonic Balancer came with the 5.9 motor... use it only, the pulleys from the 5.2 were a direct swap. Also, the Flex Plate must be used from the 5.9 since the 5.9s are externally balanced.
    I scored the motor from a 2000 Durango with 40K on it. Its almost all the same as any 5.2/5.9 ZJ. Exceptions are Obvious (EGR on some years) Oil pump has a longer pick up tube than the Jeeps and oil pan has a bulge at the front and thin in the center to clear the IFS Dodge front ends. SO swaping oil pump/pan is a must. The accesory brackets are the Exact same mounting, as well as timing cover etc. I used the 5.9 Distributor only cuz it was covered in oil like my 5.2 version, other wise the same exact part.
    As for harness' the ZJ sensors did not match the sensors on the Durango. ie Crank Position sensor (I think) had 2 wires, where dodge has 3. But thats how many of the sensors were, including the Oil Pressure Sending unit, and Temp sending unit.
    Its a pretty easy swap for a 5.2 to 5.9 but otherwise I imagine it being a BEAR going from anything else.
    AW
    Senior Member Jim311's Avatar
    Gainesville, FL
    Looks awesome!!!!
    Very good job!
    AW
    So how did you connect it to the harness? Splice the wires in? Splice in the correct connectors? What year is your Jeep, and what year engine did you get? I think there was a change in connectors between 96 and 98. I had to swap a few things when I put a 98 5.2 in my 96 ZJ. It was easy to transfer almost everything over.. most of the stuff that didn't work was on the throttle body and whatnot.
    Livermore CA
    AW
    Quote Originally Posted by Jim311
    Connect the harness ? I used my Existing Sensors, rather than the ones on the 5.9 already. My ZJ is a 95 OBD 1
    I tried to keep it simple for me in the future as well... by doing it this way. So ALL the sensors are stock 95 5.2. No bigge.
    Louisiana
    the 5.9l sensors are faster
    Maybe a dumb question but mine has the EGR port. Did you just block off yours? Will it still pass emissions?
    I see you beefed up your tranny as well. How about your T-case? Or do you already have a 231?
    Also, I wonder if the tranny behind that Durango 360 would swap right into our jeeps???
    Cool, thanks for answering all my questions.
    I have been wanting to do this to mine for about 3 years. My 93 is beat.
    Livermore CA
    Ok... here we go...
    I did state all about the EGR stuff... BUT I used my EGR Kegger from my 1995 V8 5.2ltr.
    I still have the 5.9 intake without EGR in my shop w/TB.
    I have an APS Tranz, bulletproof.
    Behind that is a 5 or 6plantary (I forget which now)
    The Dodge tranz are Driver Starter... good luck fitting the exhaust with that setup. Jeeps are passenger starter.
    Im actually glad this helps someone.
    AW
    Gainesville, FL
    AW
    Ah... I wasn't aware all the sensors would simply go right into place. Looks like the 5.2 and 5.9 are virtually identical motors then. I ended up doing the same fucking thing on the 5.2 that I swapped in. Fuck.. I might as well have put in a 5.9 if I'd know it would have been this easy.
