WOW
I just spent 2 hours reading this thread, IMO great
Keep it up.
why not weld that spacer to the "frame"
Why? it doesn't cost all that much to hack off the back of the zj, build a frame and the quarter elip was economical. just gotta have the base to start off ofOriginally Posted by TrojanMan
Ditto...
Spring mount looks awesome.. Looks like it will be very sturdy...
http://www.mallcrawlin.com/phpBB/viewtopic.php?t=2048Originally Posted by TrojanMan
ok i'l post pics tonight i started the cage yesterday got 3 hours in yesterday 2 of wich were setting everything up and i put in about 6 hours today
i'm uploading the pics right now and i'l post em later tonight.
ok the post you'v all been waiting for
Fist off i never claimed to be a experty at bending nore will i ever become one. so if you do things the way i did it and fuck up alot of tube dont' come bitching. Everything i learned is from bendign 101 on POR.
First of all this is what your going to need to do this right
mark your measurement on the floor with soapstoned like so.
then bend up a 90* and mark where the bend starts and stops. also mark where the bend starts on your bending dye.
you will be able to tell where the bend starts and stops by feeling the inside of the tube for a small indent.
then use this to mark where the bend starts and stops on you tube from the outline on the floor.
one side of the bend
then the other
measure the total length of tube your going to need frm your outline. then cut it and mark center of the length. from the center out mark your first bend.
then insert in the bend and line up the two marks( the one on the tube and then one on the dye) then start bending.
that wasn't detailed btu if you want more tech i'l post the link to the bending 101
so here is what it loosk like.
now for the truck pics
the main hoop took me about 3 houirs to do and it is 6" to wide at the top. in total i'm 10 hours into this cage. 3 hours yesterday and 7 hours today. it is not done yet obviously.
Lookin bad ass. I like how you tied in the tube on the front into the bumper to protect the fenders. I was thinking about doing something similar to protect my fenders as well and tying it into my rocker protection. Off to a damn good start I must say.
thnx. i still need ALOT fo bracing and gussets. some nodes and a few X's but the major bending is almost done
Just some things I would have suggested:
- Your b to c kickers should have come to the same node as your a pilars.
- I would have had your a pilars hug the body more.
- Run fenders. Looks better. Besides your tires stick out beyond them.
- Your windshield bar deserves more bends. Get it closer to the wind shield.
One thing I have been dreaming of is how I am going to one use the stock fuel tank for the fuel cell. I will proably build a basket some how into the new frame rails I am buiding. Secondly I am wondering how I am going to inclose the passenger compartment behind the rear seats. In your case the front seats. You going to run doors? Take them off and make some door bars. Looking good.
Chad
Lookin' sweet! Is it just me or is that b-pillar to b-pillar bar behind the front seats a bit too high up? Looks like its about head height...I always thought you wanted that below the shoulders, assuming you are using it to mount shoulder harnesses off of.
the shoulder bar is high i read that if the bar is below your shoulders then in a forad impast it suckes you down to the ground. above your shoulders and you spine stays straight. i will be mounting suspension seats higher up off the floor at a later date. for now i'm useing stock seat belts so that mont matter.
There are so many ways he could build a hiding spot and never get caught.Originally Posted by OverkillZJ
Read again. He's flying in if the rig doesn't make it. If you try bringing drugs into the US on a plane from Canada, YOU'RE A FUCKING DUMBSASS, EH?Originally Posted by TrojanMan
I was saying if he could get his ZJ to GSW he could build a stash in there, hence no plane.. unless he's talking about cargoOriginally Posted by OverkillZJ
i fly from seattle
