Thread: Project "MONEY PIT"
Page 8 of 37 FirstFirst 123456789101112131415161718 ... LastLast
Results 176 to 200 of 911
  1. #176
    JOE DIRT? OR jOE dIRK?
    Yea Yea Yea,
    No mullet here, remeber I shave my head every morning.
    you shoudl stop shaving the back for a while and have a wicked skullet for GSW06.
    Yea Yea Yea,
    That would be TOO funny
    philly
    The price was right. $500 and I drove it home. Will end up putting $500-750 into it getting it all mechanically sound, and then use it as my DD until the Jeep is done. Then next summer when my son turns 16 he can buy it from me and fix up all the cosmetic stuff if he wants.
    that's the same 2.8's as amc put in the cherokee right? good luck getting mechanically "sound"
    i think i'd rather have a $500 rice burner, but a DD is so nice. I got a bike i ride regularly, it's hard keeping it stock and reliable though, lol.
    98ZJ
    Not sure if it is the same at the cherokee, but it is the same as the one I had in my 87 S-10 pickup several years ago and that thing was a champ.
    The engine is pretty good, has a little tranny leak I think is just the pan gasket, but other than that the engine is pretty decent.
    There is a little hacker work done on it though so there are some things I need to rectify. But for a dd it works. And the insurace is almost NOTHING and it gets better gas than the Jeep so all in all it is a plus (well it will be once I get all the crap fixed).
    But NO this is NOT Turning into another project. The goal is to put as LITTLE money into the Maro as possible and get the damn Heep DONE!!!!!!!!!!
    (remeber donations are being accepted via paypal at amsoildirk@yahoo.com )
    Senior Member DND's Avatar
    BC, Canada
    Just a pan gasket leak, does this not sound familiar??????
    Slate 5.9...some stuff...more to come
    Quote Originally Posted by DND
    Come on now Dave, that really hurts . I have not been ANYWHERE near this thing with a drill so I know I did not drill a hole in the tranny this time!!
    Infact I should be getting the Jeep back this week and will post up pics of the damaged tail housing when I get it back.
    BC, Canada
    You're right, I guess that wound's still a little fresh to be taking shots, but I couldn't resist. You had to see it coming though.
    Yea I saw it coming and for some reason I am not suprised it was you that brought it up.
    Dirk
  9. #184 Re: Project "MONEY PIT"
    Dave,
    Just wanted to let you know that it is NOT the pan gasket after all.
    It looks like it is the governor housing and the speedo gear housing that are leaking. They are both sealed with o-rings that cost about $.15 each. Of course you have to draing the trans to get them replaced I believe so that just opens up even more potential for problems.
    I tell you one of these days I am going to off all my vehicles and buy a horse. I mean if the horse gets hurt or sick you just shoot them and get another. Would be sooo much less headace I think
  10. #185 Re: Project "MONEY PIT"
    BC, Canada
    Dave,
    Good to hear, those are easy fixes. I'd recommend having a sniff of the fluid as it's a good indicator as to the health of the trans. It should be a nice cherry red and not smell burnt. As it's a GM unit don't be surprised by a significant amount of dusty debris in the pan, both metallic and fiberous, hopefully no chunkies though. Do you know what model it is? Probably a 200R4, if you're lucky it's already been replaced with a 700R4. I'm assuming it's a 4spd O/D unit, 3spd probably a TH350. Why am I rambling, you probably know all this already.
    I don't know about the horse thing, you have to feed them even if they're not taking you anywhere. That and if they're not eating or sleeping, they're shitting.
  11. #186 Re: Project "MONEY PIT"
    Yea it is a 700R4. I plan to change the fluid and filter, install a drain plug and possibly a shift kit and call it done. I have to stay focused and just to the bare minimum to keep it on the road, I need to pay off some bills and then get back on the Jeep.
  12. #187 Re: Project "MONEY PIT"
    BC, Canada
    Sounds like a good plan. I wouldn't go for too harsh of a shift kit though, no need to start barking the tires and breaking expensive bits.
    I know what you mean about this being expensive. We just re-geared my wife's XJ to 4.56s w/ARBs F&R. Plus we're in he middle of building her a rear bumper w/integrated air tank, tire/hi-lift and gas can carriers. Steel is STUPID expensive. I've said it before, I'm in too deep to stop now but building two at once is nuts.
  13. #188 Re: Project "MONEY PIT"
    Good point about breaking stuff Dave.
    I am going to go with the cheapes kit I can get away with.
    I can not even imagine doing 2 Jeeps at once, you all know how long I have been trying to build just this one!!!
  14. #189 Re: Project "MONEY PIT"
    Just a quick update on the Jeep project.
    I finally have the tranny not leaking. Turns out it WAS NOT the holes I drilled in the tailhousing after all, we replaced the tailhousing and upon closer inspection I realized that I did not drill in far enough to even come close to making a hole. There were a multitude of other issue with the tranny leaking and they are all just about sorted out now.
    As for the axle swap and LA's still putting the rest of the money together to get her all done. Hope to get the gears installed in the HP30 around Thanksgiving, then the only thing to get would be brakes for the 8.8, then get all the parts and pieces over to AW's shop and start the install. I know I will need to have some driveshaft work done once the lift is all in so we can get some good measurements, and since I traded my 35's for the tranny work I need to breakdown and get another set of tires.
    I am sure there will be some other items I am forgetting about but I think that covers the big stuff anyway.
    So help me out by placing you AMSOIL orders will ya??
  15. #190 Re: Project "MONEY PIT"
    Livermore, Ca.
    Hows the camaro project going?
    I will not buy cheap Kragen parts I will not buy cheap Kragen parts I will not buy cheap Kragen parts
    FOR ALL YOUR OIL NEEDS CONTACTwww.4x4oil.com
  16. #191 Re: Project "MONEY PIT"
    Don't go being a smartass now Brian.
    I am actually going to dig into the Camaro tranny over Thanksgiving. After that and a set of tires I might off it.
  17. #192 Re: Project "MONEY PIT"
    Livermore, Ca.
    not trying to be a smartass, just wondering if you got anything updated on the tranny, also is the jeep tranny fixed?
  18. #193 Re: Project "MONEY PIT"
    Quote Originally Posted by 87XJ
    Damn dude, you've only been around here like a day or two and your already starting shit about my tranny problems
  19. #194 Re: Project "MONEY PIT"
    And by the way NO IT IS NOT FIXED yet.
  20. #195 Re: Project "MONEY PIT"
    Okay all, quick update:
    I picked up the 231 TC this afternoon, has an SYE installed and looks great.
    AW is done with the welding and stuff on the 8.8.
    The HP30 is at the shop getting the gears installed.
    So just about the only thing I have left to pick up is the DOM tubing for the steering, and then the limit straps and driveshafts after the suspension is in.
    Right now looking like mid to end of Jan. to start the install.
    I know I know, about fucking time, trust me I know!!!!
  21. #196 Re: Project "MONEY PIT"
    Sac
    still think it will be finished this month? then we can finaly go wheeling! i cant wait till is finished....if you couldnt tell by all the pm's i send you ever couple months asking about it...i'll shut the hell up now
  22. #197 Re: Project "MONEY PIT"
    Thanks for asking Danny,
    No worries on all the PM's I hope I am answering some of your questions with my responses.
    It will NOT be completed this month, I was hoping to get it started this month but it is looking like it will not get started till sometime in Feb.
    The goal is to be done on or around 3/12, not sure if that will happen just yet as I have alot going on right now. We just bought a new office building and well the build out is taking almost all of my time managing the general contractor and all that crap, so I really have not had the time to spend much on getting the last few parts and pieces.
    But it looks like I have the Camaro sold should find out tomorrow wich will CERTAINLY help get me close to having the rest of the funds.
    Thanks for asking, I am glad that someone else is still interested.
  23. #198 Re: Project "MONEY PIT"
    Hey there,
    Just wanted to let you all know that I am still working on this thing, and it seems to be getting really close now.
    The 8.8 is all painted and ready to go in.
  24. #199 Re: Project "MONEY PIT"
    nice and shiny
  25. #200 Re: Project "MONEY PIT"
    Yup, I used POR-15 so it should last pretty good.
