Project "MONEY PIT" - Page 10
Thread: Project "MONEY PIT"
Page 10 of 37 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 226 to 250 of 911
  1. #226 Re: Project "MONEY PIT"
    Jan 2006
    Northern CA
    Glad to hear it. I think you were actually there while I was talking to Donnie one day this week.
    Yep. They asked if you wanted your vent done like mine. I said I bet you do, but you better ask!
    These guys are really awesome! I asked Todd if they had anymore decals. There out, but when they get more, my rig will be sporting one of their badges.
    I might add here, Donnie talked me out of turning up the pressures on mine (more) at this time. He said I was already running substantially higher pressures, and that it would steal pressure from the cooling circuits. He took it for a test drive before the service work and said, "Jerry, it's still pulling the front end up on the 1-2 shift. It really doesn't need anymore." So I relented. Cooling on mine will be more important, since I will be towing a camp trailer. And he agreed that once my stroker and lift (tires) are in, we could still bump it up a little more "if it really needs it".
    Again, these guys are awesome.
    Jerry
    95 ZJ, 4.0, ML Header, Magnaflow, K&N, Beefed 42RE
  2. #227 Re: Project "MONEY PIT"
    Yea I will adjust that as I see fit when i take it down in a few weeks.
    The stroker will be in by the time I take it back to get checked and tuned, so we may bump up the pressure at that time. We will just have to see.
  3. #228 Re: Project "MONEY PIT"
    Trans is in!!!!!!!!!!!!!!!!!!!!
    Will pull some pix off the camera tonight and post them tomorrow fomr work (dial-up sucks)
  4. #229 Re: Project "MONEY PIT"
    Everyones crap is coming together but mine, BLAH!
  5. #230 Re: Project "MONEY PIT"
    Yea some of my stuff is ccoming together, just NOT the stuff I have been collecting parts on for like 2 years
  6. #231 Re: Project "MONEY PIT"
    Jan 2006
    Northern CA
    Well, do ya like it?
    Any ideas what was causing the leak on your original?
  7. #232 Re: Project "MONEY PIT"
    Yes I like it. They said it does not shift as firm as yours in the 1-2 shift, remember that I have the 249 so the full time four wheel drive is working against me there.
    When I go back in a few weeks (after the stroker) then we will tweak it to shift firmer, if needed.
    No word on the original leak, spent most of the day swapping in the new one, no time to deal with the old one.
  8. #233 Re: Project "MONEY PIT"
    Senior Member violatedppl's Avatar
    Aug 2005
    Danville CA
    nice to see somthing is getting done, what was the PITA factor on the tranny swap. and Ill try to make it on sat morn and see whats goin on.
    08 tundra double cab 5.7 4x4
    I am jeepless at the moment.
    Sold- Stock 03 WJ, 4.7HO. lift coming soon.
    Sold-97 ZJ laredo 4.0, 242 RE BB, 31" BFG MTs, custom rear storage boxs, magnaflow hi flow cat, flow 70 series, 2.5 inch exhaust, jks quicker discos and some other crap
    http://www.cardomain.com/ride/2221028
  9. #234 Re: Project "MONEY PIT"
    THere was nothing a PITA really on the swap it was pretty straight forward.
    Yes I too am glad things are moving along.
  10. #235 Re: Project "MONEY PIT"
    Okay, here are some pix of the trans install and parts.
    Some of the pix are a little blurry and it is hard to tell how much bigger the V8 parts are in the pix, but they are considerably bigger.
    The V8 stuff is on the left and the stock stuff on the right, the pix are in no particular order.
    The torque converter is an awesome piece it has a full billet cover and a larger clutch the factory one is a stamped steel piece with the mounting hole tabs welded on. This one uses a much bigger bearing and better clutches for better lock up.
    Here are some more specs on it:
    billet cover
    hardened center pump hub and turbine spines
    larger clutch for t/c lock up
    clutch made of carbon fiber / kevlar
    heavier springs for the clutch
    fully rollerized bearings (no bushings)
    Stay tuned for the stroker install on April 8th!!!!!!
  11. #236 Re: Project "MONEY PIT"
    Just ordered my header, I went with the new Edelbrock one, was a little cheaper than the Banks but honestly when I saw them at Truckfest they looked almost the same, except the Edelbrock has a heat treatment where the Banks doesn't.
    James over at Jeepers & Creepers hooked me up.
  12. #237 Re: Project "MONEY PIT"
    That looks good.
  13. #238 Re: Project "MONEY PIT"
    As to be expected with my Jeep the engine swap did not go completely as planned.
    We got the stocker out but noticed an oil leak in the stroker so we dropped the pan and found a bad main bearing. Since no one carried the main bearings we have to order some up so we will hit it again next weekend.
    Here are some pix of the progress.
  14. #239 Re: Project "MONEY PIT"
    Aug 2005
    Danville CA
    So the plan is for next sat? damn easter weekend, not sure if Ill be able to make it by for the swap. Im havin easter at my house this year so it mean the day before if the lets spend all day cleaning the fkn house.
    how much was the header by the way?
  15. #240 Re: Project "MONEY PIT"
    I'd say there's some serious projects going on with forum members lately! Sweet.
  16. #241 Re: Project "MONEY PIT"
    Yea right now we don't have a set time, I need to get all the parts ordered, and with Easter it might totally screw the weekend.
    Yea for me this is a MAJOR project.
  17. #242 Re: Project "MONEY PIT"
    Quote Originally Posted by violatedppl
    I got a hook up with the local Kragens manager (napajeep) here on the boards, might be able to pick one up for you.
  18. #243 Re: Project "MONEY PIT"
    Aug 2005
    Danville CA
    thanks I just got my stuff from nick put on today and it sounds like a wet dream.
  19. #244 Re: Project "MONEY PIT"
    What did you get from Nick?
  20. #245 Re: Project "MONEY PIT"
    Aug 2005
    Danville CA
    just the usualy high flow cat, series 70 flow. it purs like a fkn kitten I love it.
  21. #246 Re: Project "MONEY PIT"
    Very cool, can't wait to meet up one of these days.
    Dirk
  22. #247 Re: Project "MONEY PIT"
    Aug 2005
    Danville CA
    Im thinking about going up to lake pillsbury(sp) in medicino on either the 30 or 31, theirs some decent trails up their and a really good place to shoot. it has to be one of my fav. places to go camping. and theirs a pet semitart I am still trying to get pics of. its still in the planning stages but if you want to come I drive right by napa on the way up thier....
  23. #248 Re: Project "MONEY PIT"
    Member ZachJ's Avatar
    Sep 2005
    Richmond/Chico, California
    that is close to where i will be going to school next year maybe i will have to check it out sometime.
  24. #249 Re: Project "MONEY PIT"
    Aug 2005
    Danville CA
    where you going sanoma(sp) my freinds gf goes their and we are prob going to try and teach her out to shhot the right way. she has never handled a gun before and shes 19. what kind of country is this??
  25. #250 Re: Project "MONEY PIT"
    Sep 2005
    Im going to chico not that close but close enough.
