Cam's Unibugly
Thread: Cam's Unibugly
Page 1 of 48 1234567891011 ... LastLast
Results 1 to 25 of 1198
  1. #1 Cam's Unibugly
    Current:
    The History of it:
    I started wheeling my Jeep back when it was 2wd with a 2" BB and a set of 31s. Then I stepped up slightly to a 3" front to rear. Here's a pic at the now-closed Rich Mtn. Trail.
    Then I converted it to 4wd back in the spring of 2002. A lot went wrong, but, after a month, it had a 3.73 geared d35 and d30 under it, along with a 242. A shot of it in the garage:
    I swapped back and forth with the ATs and MTs for a while, wheeling it a little on each. The Jeep got an 8.8 from a 97 Explorer during this time, in January of 2004.
    Then in the summer of 2004, I decided to go a little bigger. A waggy 44 went up front. Longarms allowed me to go up to 6" to run 35s.
    First trip to Tellico:
    Senior Member LouisianaZJ's Avatar
    Louisiana
    looks good
    are you running some sort of 5 lug>6 lug spacer on the 8.8 or did you get custom shafts?
    They're custom alloy shafts from Dutchman. 5 on 4.5" to 6 on 5.5" adapters cannot be made narrower than about 2" per side. So that would gain me 4-5" trackwidth in the rear and essentially make it fullwidth. I had to get the rotors redrilled also.
    2004 Specs:
    Waggy 44 front, raised spring perches 1.5", disc brakes, Aussie Locker, Yukon 4340 shafts with Yukon SuperJoints, 4.88 gears
    Ford 8.8 rear, custom Dutchman alloy 6 lug shafts, disc brakes, custom truss, ARB air locker,
    4.88 gears
    Homemade Inverted T steering using Chevy "1 ton" TREs
    PSC 621MR steering box w/ SurplusCenter 1.5" ram hydro assist
    RE 4.5" coils and .75" spacers up front, RE 3.5" front coils + 1.5" pucks in the rear
    Modified Kevin's Offroad Long Arms
    Rockrails by Tim (timzjatl)
    SYE'd np231 from a 98 TJ. CV rear driveshaft.
    37" Iroks on 2" backspacing ATOR weld-on beadlocks
    York OBA setup, homebrew intake with K&N filter, Optima Red Top in BTF battery box
    custom front and rear bumpers, Milemarker 9k electric winch
    8 point hybrid internal/ external cage constructed from 1.75" .120 wall DOM
    2010 Specs:
    1988 Ford HP Dana 60 Front, 5.38 gears spooled, Yukon 4340 inners and outers, 35 spline Warn drive flanges
    1989 GM 14bolt rear,
    5.38 gears welded
    40" Interco LTBs on 17x9" DIY beadlock wheels, 5" BS.
    double trianglated 4 links. FOA 16" reservoir coilovers front, 14" Fox reservoir coilovers rear, Radflo air bumps
    2006 LQ4 motor, hooker headers, Amsoil filter, AA bell, NP435 transmission, NP205 transfer case
    homebrew 1350/1410 driveshafts, .120 and .188 wall
    PSC/POS hybrid full hydro steering
    Milemarker winch, Corbeau seats, optima yellow top battery
    Nice RIG!!
    Did you already sell the 8.8?
    Huntsville, AL
    Who is Tim Carlton and how do I get him to make me a set of Rock Rails??????
    Chris Depew
    Some people call me a shrink
    77 Cherokee Chief S 401: SOLD
    77 CJ5 Levis Edition 304: SOLD
    84 Grand Waggy: SOLD
    95 ZJ Orvis: SOLD
    Nope, still running the 8.8, just with custom shafts so I can be 6 lug all around.
    Tim is timzjatl on this and other forums. He originally built those sliders for his Jeep. He buggied it this summer though, so he sold them to me. Sorry, but I don't think he's interested in mass-production.
    :Maine:
    um, my buddy has an 8.8 with adapters to match the BP of his front waggy 44- and they are less than 1" thick
    Quote Originally Posted by MaineZJ
    Wow. well I wish I had known that it was possible then. M.O.R.E and Spidertrax both told me that they would have to be 2 piece spacers at least 2" wide to go from 5x4.5" to 6x5.5".
    But I am still confused becuase there is overlap on my 8.8 rotors that were redrilled for 6 lug. Where did he get his? Are you sure he didn't convert the front to 5x5.5" and then get spacers to go from 4x4.5" to 5x5.5"?
    Huntsville, AL
    Quote Originally Posted by ATL ZJ
    Oh, Well that's fine. Kevin's it is I guess.
    Chris Depew
    95 ZJ Orvis: SOLD
    :Maine:
    Oops, my mistake.
    Adapters from performance wheel - 5x4.5 to 5x5.5 to match the front dodge hubs on waggy 44
    Nice rig..................too bad you never wheel it.
    ops:
    Grand Cherokee Sellout #17
    Traded 2wd->4wd converted ZJ for TJ Rubicon
    Jeep Sellout #185,298
    Traded wrecked 04 Newbicon for 2006 Rustang GT
    Quote Originally Posted by FinlayZJ
    ops:
    Ha, you even had that Boobicon of yours in 4lo yet?
    Yes, I had to go get some Messkins unstuck on the farm land in North Carolina. Apparently 1980's Chrysler Vinivans aren't that good at wheeling.
    Pics of the Vinivan please. haha
    I can't type.
    Orlando, FL
    Both of you come wheeling with Tim and I! :shock:
    See, I can say that now because I dont have a ZJ to worry about. ops: YJ :arrow: 37's
    www.grandslamsoutheast.com
    SOLD: 98 ZJ, 6" Long Armed, Locked 33" MTR, HP 9" and HP D30
    My Build Thread
    94 YJ, tons and 40s, no leafs, 5.3/4L60e
    04.5 Dodge 2500 CTD 4x4, Smarty Jr
    Quote Originally Posted by Pearce
    Oh I will. Even though my ZJ is still non-trailered and daily driven. It's broken before and I'm sure it'll break again.. :lol: Finlay might be a different story in his shiny new Bubi.
    What day? I've got to get my high clearance skids on and i'll go. Assuming work doesn't kill me first :x
    Cam, why do you bust on my shiny new Rubicon? I think it's because you're jealous that my dana 44 front end has dana 30 outers. :shock:
    ops: Ahh, you got me.
    No, it's really just because i like to say Bubi/ booby/ booooooby
    Orlando, FL
    What day?
    Dec 18th.
    Front Bumper started:
    philly
    what size c channel? 2X5?
    i'm in the design stage of mine right now. i haven't decided how complicated i'm gonna make it, my 98 has that extra bump on each side of the grill.
    98ZJ
    Yeah it's 5" channel in the 3/16" variety. The top and bottom extend 1.75 inches back from the face of the channel. I thought about this design for a 96-98 and I think you could just snag a grille from a 95 or so and your problem is solved. Seems a hell of a lot easier that way than to account for that drop when you're working with 3/16" or 1/8" steel.
