Suspension gutted. - Page 12
Thread: Suspension gutted.
Page 12 of 13 FirstFirst ... 2345678910111213 LastLast
Results 276 to 300 of 324
  1. #276 Re: Suspension gutted.
    Quote Originally Posted by Tommy View Post
    Thanks guys...
    While I have the lower arms disconnected, you think I should add more triangulation to them? I should be fine as far as clearance with my drive shaft to get a bit more. Any thoughts?
    Here is an old pic...
    How much does the axle move laterally?
    With your small amount of vertical seperation, I would triangulate As much as you can. Can you triangulate the uppers more? Would give you more clearence around the oil pan, no?
    What does the four link calculator tell you?
  2. #277 Re: Suspension gutted.
    Senior Member Tommy's Avatar
    Temecula,Ca
    With the lowers diconnected not much, maybe two inches. I have never plugged my info into the four link calculator. I cant really move the uppers much. They have ample clearing for the oil pan. I have rerouted the exhaust in front of the oil pan for clearnce issues...
  3. #278 Re: Suspension gutted.
    Temecula,Ca
    Looks like I am going to make it to TDS afterall. I was able to complete the front today. And I cut the driverside doors.
  4. #279 Re: Suspension gutted.
    Livermore CA
    Can we see a close up of the doors finished ? From afar they look good ! Lots of work, but good !
    5.9
  5. #280 Re: Suspension gutted.
    Kennesaw, GA
    Great looking Jeep, love the doors
    98 4.0 30x9.5 KO's, Black Soft 8's, Rusty's 3.5in coils, Front Adj Trac-bar, ES9000's, Rusty's intake, RE front lower SF arms, KMA Wincher, Procomp 55watts, New Steering Setup, CB/PA and bunch of other junk
  6. #281 Re: Suspension gutted.
    Temecula,Ca
    I just have the doors cut right now. I didn't have time to finish them before TDS. I plan on having them finished by EJS. I will get some progress pics on those once I get a little further along... Thanks for the compliments!
  7. #282 Re: Suspension gutted.
    Temecula,Ca
    Here is the begining of the first door. This is a PITA and allot of tedious work. I still have a ton of work to do on this door. But it is a start. My goal is to get all four doors welded up and mounted back on the ZJ by EJS.... Underneath the 14 guage sheet are 3 supports which are welded between the sides of the door. These supports are made out of 1.5" x .5 or so box that I had laying in the garage.
    I will flatten out these door contours later. Maybe...
  8. #283 Re: Suspension gutted.
    Temecula,Ca
    Here are some more updated pics of the door. I have never done thin sheetmetal work like this before. Again the best I can do at the moment. I will need to add some bondo to fill a couple places. Over all I am happy with it, except for the slow progress. Damn, this is way f'ng time consuming!!!!
  9. #284 Re: Suspension gutted.
    Senior Member corrupt143's Avatar
    Indiana
    Those doors are coming out nice. I like the skid too, did you just build onto the stock cross member?
    Chris- 97 ZJ, 4.0, some lift, black tires and some Autozone valve caps.
  10. #285 Re: Suspension gutted.
    Temecula,Ca
    I used 6" x 2" x 1/4" box for the main part of th skid. The only thing I took off the stock crossmember was the bracket that the t-case mount bolts to.
  11. #286 Re: Suspension gutted.
    Warwick Rhode Island
    u suck my friend with your fancy cross member and your fancy half doors bo ho
    just playing it looks good man keep up the good work.
    drunk post # who cares
  12. #287 Re: Suspension gutted.
    Temecula,Ca
    lol...
  13. #288 Re: Suspension gutted.
    Tommy everything is looking SWEET!!!!!!!!!
    When you make it up to Nor Cal be sure to let me know I would love to check it out in person.
    Dirk
  14. #289 Re: Suspension gutted.
    Keep sipping on that hennessy and they will be sure to turn out pimp. what are you doing for a latch?
  15. #290 Re: Suspension gutted.
    Livermore CA
    Door look great ! nice job !
    5.9
  16. #291 Re: Suspension gutted.
    Temecula,Ca
    Thanks for the compliments. I haven't figured out a latch yet, I am just going to be using the internal rods for now. There is an openeing on the inside of the door that you can reach in and pull the rod down to unlatch the door.
  17. #292 Re: Suspension gutted.
    Junior Member skydizzle's Avatar
    Oct 2005
    Fort Bragg, North Carolina, United States
    now entering bathroom with ky. brb
  18. #293 Re: Suspension gutted.
    Oct 2005
    how do you like the spring rate on the new springs?
  19. #294 Re: Suspension gutted.
    Temecula,Ca
    They are soft, but work well. If I had swaybars I would allot happier. I also need to install a small winch up front. It unloads on steep ass shit...
  20. #295 Re: Suspension gutted.
    Jun 2005
    Paradise, Newfoundland Canada
    Is that a double triangulated 4 link rear?
    Anthony
  21. #296 Re: Suspension gutted.
    Des Moines, Iowa
    SORRY GUYS, I can't post treads and this is the only way I know how to ask. So anyways, How big of a lift do I NEED TO RUN 35's? What do you guys recommend for the lift? PLEASE HELP.
  22. #297 Re: Suspension gutted.
    Senior Member dp96zj's Avatar
    Texas
    Quote Originally Posted by JTJeepen98 View Post
    I'm feeling a budget boost question next.....
  23. #298 Re: Suspension gutted.
    Jun 2005
    Why hicjack someone else's thread?
    That's not a way to get help.
    Anthony
  24. #299 Re: Suspension gutted.
    Des Moines, Iowa
    I had the BB I want to go bigger.
  25. #300 Re: Suspension gutted.
    Des Moines, Iowa
    Like I had said I can't post my own, and yes your right kindda shitty of me.
