Project: BOUGHT NOT BUILT - Page 4
Thread: Project: BOUGHT NOT BUILT
Page 4 of 5 FirstFirst 12345 LastLast
Results 76 to 100 of 117
  1. #76 Re: Project: BOUGHT NOT BUILT
    Louisiana
    thanks. up next is chopping off the doors and putting cage in
  2. #77 Re: Project: BOUGHT NOT BUILT
    Houston, TX
    cage kit? or building your own?
  3. #78 Re: Project: BOUGHT NOT BUILT
    Louisiana
    D&C kit
  4. #79 Re: Project: BOUGHT NOT BUILT
    Louisiana
    doors off
    now I needs a cage
    I thinks I am going to "install" a sunroof as well
    this is a crappy pic of the D&C kit
    gonna add a couple more spreaders
  5. #80 Re: Project: BOUGHT NOT BUILT
    Louisiana
    my buddys XJ on 60's
    curb crawlin
  6. #81 Re: Project: BOUGHT NOT BUILT
    Louisiana
    went crazy with the cage paint, masked off the first 2" at joints (had not pulled tape yet) . Waiting on one last cage piece then weld time.
  7. #82 Re: Project: BOUGHT NOT BUILT
    Louisiana
    some pics of the cage, still in the works
    going to eventually add an x or k brace on the c pillar, ran out of tube
  8. #83 Re: Project: BOUGHT NOT BUILT
    2nd floor Yuma, AZ motel
    Turn the heat up on that welder booby.
    Cage looks good!
  9. #84 Re: Project: BOUGHT NOT BUILT
    Louisiana
    yeah, turned out pretty good I think. We added alot to the stock D&C cage which only had single spreaders overhead at the A B & D pillars .
    Suggestions on the lateral bracing? im thinking K brace off the c pillar center node.
  10. #85 Re: Project: BOUGHT NOT BUILT
    Louisiana
    http://www.thexota.org/d/8632-1/100_5404.jpg
    http://www.thexota.org/d/8635-1/100_5405.jpg
    pics of how I want to do the tieins
    I had to buy a metric assload of channel (sell in 20 ft pieces) & I need about 6 ft so if someone wants todo something similar I can cut up pieces & ship UPS
  11. #86 Re: Project: BOUGHT NOT BUILT
    Quote Originally Posted by LouisianaZJ View Post
    some pics from today. i replaced the leaking SS with an OMD SD40, i bought from dirk about 6 months ago
    also pics of the 35's on 15x8 aluminum wheels. the mud kings will be replaced with 36" irok's or BFG MT's, have not decided yet.
    This is at 6" on 35's? Still rustys 4" + bb? Thanks Nice rig BTW
    2004 Ford Lightning
  12. #87 Re: Project: BOUGHT NOT BUILT
    Louisiana
    yup, somewhere around there, probably closer to 5.5" with alot of trimming
    got some pics with the interior back together
    http://img85.imageshack.us/slideshow...080721juq.smil
  13. #88 Re: Project: BOUGHT NOT BUILT
    Looks good. Tks.
    2004 Ford Lightning
  14. #89 Re: Project: BOUGHT NOT BUILT
    Louisiana
    thoughts on this additional bracing? for lateral roll & c pillar support
    also progress on the unitbody tieins
  15. #90 Re: Project: BOUGHT NOT BUILT
    Louisiana
    Bump. Going to start notching later this wknd
  16. #91 Re: Project: BOUGHT NOT BUILT
    May 2005
    Boone NC
    my recommendation is plate the unibody with some 3/16 or similar where you are going to tie the cage into it to spread out the load as much as possible, it will buckle the unibody over time and very quickly in a nice roll
    i like the cage though, it really takes alot of planning for interior cages.
    the only thing i would change about your c pillar bracing would be to make it an x instead of a single bar, the x will be exponentially stronger and add alot of strength to the unibody. i know zj's are prone to cracking the unibody near the back hatch if they are wheeled much ...
    my .02
  17. #92 Re: Project: BOUGHT NOT BUILT
    Louisiana
    Yeah will rake that into consideration. Main reason I have it as a diagonal is so a 36 in spare would still fit. May layout a k brace & see if that would work
  18. #93 Re: Project: BOUGHT NOT BUILT
    May 2005
    Boone NC
    k would still be alot stronger than the single diagonal bar. could you fit a Y and your spare?
  19. #94 Re: Project: BOUGHT NOT BUILT
    I lke that cage but it just seems to take up alot of room inside and the dash cant come out. Have you looked on pirate for ideas? Tons of xj's there.
    2004 Ford Lightning
  20. #95 Re: Project: BOUGHT NOT BUILT
    Louisiana
    most I have seen are exo. on pirate
    really, I have tons of space in the front seats, hardly any loss due to the cage; the rear passengers & cago are screwed though
    kinda limited on what i can add as I dont have acces to a bender w/o paying a shop.
  21. #96 Re: Project: BOUGHT NOT BUILT
    Thats pretty much what I figured. I still have to use the back seat. There was a commanche build over on pirate where the guy ran the main hoop throught the b pillars. That is the one I was thinking of. Keep goin it looks good.
    2004 Ford Lightning
  22. #97 Re: Project: BOUGHT NOT BUILT
    Louisiana
    Going to just add a rear seatbelt bar to the c pillars, boxing in that frame should give enough ridgidity for what I am doing. If I cut the roof off I will x brace it up more.
    Also looking for alloy suggestions for a full width ford hp44, brands, vendors, etc. Probably go with ctms , slugs, and full Detroit in it
  23. #98 Re: Project: BOUGHT NOT BUILT
    Louisiana
    Ending up doing the mini comp cut on the rear quarter since the 36's were rubbing there, now im thinking trimming the bumper, lol. Also repainted the bumper & lights in fine texture bedliner.
    Cut up some tubing fro C pillar framing & rear crossmember.
    Next project the HP44
  24. #99 Re: Project: BOUGHT NOT BUILT
    Is that a ford hp44 without the wedges?
    2004 Ford Lightning
  25. #100 Re: Project: BOUGHT NOT BUILT
    Louisiana
    Yup. Only drawback is it supposedly has thinner tubes, but I am trussing the whole thing probably
