Thread: Project: BOUGHT NOT BUILT
Page 1 of 5 12345 LastLast
Results 1 to 25 of 117
  1. #1 Project: BOUGHT NOT BUILT
    Louisiana
    update aug 2005:
    front & rear lockers installed, 4.56 and other axle junk complete
    original post
    Here are the specs of the jeepo
    STOCK
    4.0L HO
    AW4 auto
    SUSPENSION
    (About 6.5” overall)
    Rubicon Express superflex lower control arms
    RE super ride upper control arms
    RE control arm drop brackets and custom support brackets
    JKS swaybar quick disconnects, sway bar drop, mounts on axle relocated higher up to clear draglink
    RE 1660 Extra H.D Track Bar and RE 1665 H.D. TrackBar Bracket
    YJ brake lines
    Rusty's Springs 4” + 2” BB
    TeraFlex Bump stop extensions
    4" Rear spring pack w/shackle + degree shims
    SS, Pro Comp
    DT shocks all around
    BFG M/T 33x12.5x15 tires on 15x8” steelies w/3.75" BS
    Rear s-bar removed
    Fenders trimmed + herculined
    ZJ V8 steering
    ENGINE
    Ford MotorSport injectors
    K&N cone w/Rusty’s tube
    Bosch 7.5 mm Ignition Wires
    super 40 muffler
    HD fan clutch
    Stant HD 180* stat
    ARMOR
    Rock Sliderz
    Transfercase skid plate.. its like ” plate
    mopar gas tank skid
    class 3 receiver hitch
    front towhooks/brackets
    rear exhaust trimmed for departure angle
    AXLES/DRIVETRAIN
    Tom Woods short shaft kit w/ rear driveshaft
    The gearing is stock 3.55
    The front high pinion Dana 30 w/ LockRite locker installed, u-jointed 760x axleshafts, u jointed d-shaft
    Dana 44 rear axle with Trac-Lock limited slip
    Breather lines extended to engine bay and filtered
    OTHER aka teh BLING-BLING
    front seats out of a 01 XJ
    Hella H4 headlights
    Jeep Wrangler fog lights, light up the night good…..plus mabey I’ll get waves from some TJ Turds
    IN PROGRESS
    4.56-4.88 gears f/r, detroit rear
    PLANS
    8-10 pt cage
    front Bumper
    35-37's
    Looks too clean to me to be called shitbox!
    Great name though :shock:
    Senior Member Alaska ZJ's Avatar
    St. Louis
    That is a XJ. Who gives a shit.....box.
    "Saddam Hussein has been engaged in the development of weapons of mass destruction technology which is a threat to the countries in the region and he has made a mockery of the weapons inspection process. The responsibility of the United States in this conflict is to eliminate weapons of mass destruction, to minimize the danger to our troops and to diminish the suffering of the Iraqi peole." - Nancy Pelosi circa 1998
    And your rebuttal Ms. Communist bitch?
    Louisiana
    d44 w/detroit, superior 4.56, longer SS brakeline added
    primered
    ready to go
    permacool PS cooler
    cheapo CB wired up, still need antenna
    in progress: lebaron hewd vents, regear front turdy
    this is a lebaron hewd vent:
    mounted on an xj (not mine)
    looking good man.
    but that interior is way to clean.
    portland ct
    i was waiting to see a shit box????
    Is that right?
    Louisiana
    Kraqa, thanks
    "but that interior is way to clean."
    i do detailing on the side too, easy money
    we finally got the new rear D44 under the heep too. ended up having to swap the YJ e-brake cables that were on it with the old XJ ones. the YJ lines were like 2' too long. everything was out so just installed all new brake pads and hardware too for the hell of it.
    while installing the new axle i also noticed a slightly crimped main fuel line ops: (aboot 10-20% flow it looked like)
    bottie fabbed repair was done of course since a new line was $50 from the stealer
    i ended up cutting out about a 2" section w/ a tubing cutter. and i put on a 12" (so it overlapped a good 5"+ each side) 5/16" goodyear rubber fuel line (said 50psi on it) with 4 clamps.
    MORE motormounts went in this week
    lotsa vibes but that is supposed to die down once they break in
    drivers side
    pass side
    looks like the drivers side wears out faster due to excessive header heat, the rubber closest the header was hard and brittle[/QUOTE]
    plus i got a madd pimp new (to me) spare, ProComp 33" X Tizzerain on a chromed 15x8
    replacing my old dick cepeck mud on 15x7
    [the d-c/rim for sale btw, $25+ship]
    Louisiana
    lebaron vents were sanded, primed, painted and claer coated. pretty good color match for my rattle can skills. holes still have to be cut + vents installed they are just resting up there
    fuel line repaired
    got some spare 760x axles with hubs as a post christmas gift
    Louisiana
    getting D30 stuff together. got the cover and evo from RuffyTuffy on here. thanks again
    fresh rattle can job, bling bling (before pic )
    superior evo axle. All i need now is a PASS side!
    (for u bolts)
    btw, thanks to imageshack for the hosting. lotsa pics on here
    San Diego
    that crane cover is pretty sweet
    Louisiana
    Louisiana
    D44 diff cover
    1/4" face and 1/2" ring
    thumbnails, i ground down the weld splatter
    1/2"
    inside
    Louisiana
    mall flex (910 20*)
    xj on 31's
    NC
    Nice work on the diff cover. Did you do all of that? I want to make a beefy diff cover for my HP 30 and 8.8, but I keep getting over whelmed by the thought of a jigsaw puzzle of cardboard.
    Is that a Trout Insudtries ring?
    I break stuff.
    Senior Member Jim311's Avatar
    Gainesville, FL
    Quote Originally Posted by JeepinHank
    Same here. I want to shave my 8.8 but it would require building a custom diff cover :?
    Looking good man, mine is taking along time too.
    Louisiana
    naw, i did not have the time or tools to do all that.
    http://www.mallcrawlin.com/forum/viewtopic.php?t=1119
    8)
    its made of a single piece of pressed steel
    NC
    OK Kewl...
    I saw where you were grinding some weld spatter away, and thought maybe you made it.
    All clear now... 8)
    I break stuff.
    Louisiana
    Quote Originally Posted by Jim311
    why couldn't you buy a manufactured HD cover, and shave the cover to match the diff?
    Louisiana
    San Diego
    good thing you covered up your license plate....
    I still gave your phone number to every telemarketing company this side of the mississippi. :twisted:
    Louisiana
    oh noes!
    Louisiana
    JKS 1/2" leafspring plates with bumpstop ledges from ebay
    1"x3" rubber hockey pucks to adjust bumpstop
    the amount of bumpstop is kinda rediculous in these pics, about 5" thats b/c i am going to be moving the shock a couple inches up tommorow
    Louisiana
    Kevins LCA skids plus i added a 3/16" plate that ties it into the axle
    props to swampy who did the welding for me
    Louisiana
    well one of my old terminals cracked last week, so i pimped it out with some tewel-less terminals and used copper HD crimps. under $12 for the junk, took about 15 min
    8mm accel wires i installed a while ago too
