Ford Taurus fan.. - Page 3
Thread: Ford Taurus fan..
Page 3 of 10 FirstFirst 12345678910 LastLast
Results 51 to 75 of 232
  1. #51 Re: Ford Taurus fan..
    Jan 2005
    Wherever the Navy needs me
    Quote Originally Posted by violatedppl
    I am looking at doing this, but on low has anyone ever had a prob with cooling, more on the trail than city/highway. if not Im not sure I Would even hook up the high, but mybe
    Low is all I had working for a while because my starter relay went out too. The bosch 30A relay worked fine for low.
  2. #52 Re: Ford Taurus fan..
    Member Zjeeper's Avatar
    Aug 2005
    Travis
    94 ZJ beaten broken and half dead
    231/35s/8.8/polished 30/locked f/r
  3. #53 Re: Ford Taurus fan..
    Aug 2005
    what kind and how did you mount the temp sensor on the 5.2?
    Travis
  4. #54 Re: Ford Taurus fan..
    Nov 2004
    Columbia SC
    i used the bosche relay listed in this ford writeup http://highrpm.org/howto/taurus%20fa...taurusfan.HTML
    for a yr now with no problems on high and low side, but get the diode as well from Radio SHack to keep from burning them up. as far as the temp control i just used the 20.00 hayden unit that probes into the grille and its what activates the relay on my setup.
    on high in the winter it came on only in traffic, now that its warmer it kicks on and off, in traffic when it kicks on on high it lowers down to 190 or so and stays under 210 all day long on the 4.0
    93 ZJ- Homebrew Long Arms, BFG 315 KM2's,ARB Bump/Warn XD9000. few lights, d30 ox locked....8.8 w/ Eaton E locker, JCR rails
    74 CJ5- Cream Puff
  5. #55 Re: Ford Taurus fan..
    Aug 2005
    so does the relay control when to switch from low to high off of the hayden unit?
    Travis
  6. #56 Re: Ford Taurus fan..
    Nov 2004
    Columbia SC
    Quote Originally Posted by Zjeeper
    no...relay just acts as a power transfer from battery to fan...hayden unit comes on at whatever temp i set it at, and it triggers on the relay( just like a switch does) i dont use low...just high now but i ran around on low a few times for the hell of it and it works fine
    74 CJ5- Cream Puff
  7. #57 Re: Ford Taurus fan..
    Aug 2005
    i found this on ebay http://cgi.ebay.com/ebaymotors/Relay...QQcmdZViewItem
    and i think i might switch out some of the main wires and relays and wire in a manual switch and give that a try
    Travis
  8. #58 Re: Ford Taurus fan..
    Nov 2004
    Columbia SC
    if that is just a 40 amp relay it wont last
    74 CJ5- Cream Puff
  9. #59 Re: Ford Taurus fan..
    For $20 looks like it is worth a shot.
  10. #60 Re: Ford Taurus fan..
    Mar 2005
    Valencia, CA
    this is the relay w/temp sensor I used,just for the low setting.
    95GC,5.2.456'sw/tru-trac's,onboard air,33s,6in lift w/all arms adjustable,231 swap,Hanson frt & rear bumpers
    jeep pics
  11. #61 Re: Ford Taurus fan..
    Mar 2005
    Virginia Beach, VA
    Not a very good place (more specifically, position) to mount that. Even though it's potted, that variable resister isn't. Should have mounted it higher and on its side (like on the inner fender on the left side of the battery). Or at least seal the rest of it up with some RTV after you get it set the way you want it.
    Do the connectors for the relay go all the way through the base so any water that gets in the contacts can drain? I think I'd be covering those with a good bit of dielectric grease!
  12. #62 Re: Ford Taurus fan..
    Nov 2004
    Columbia SC
    Quote Originally Posted by scubatch2
    dont use that for the high side....i went thorugh 2 of those and got stranded with some LA4x4 folks in Baton Rouge once...each lasted about a wk or so before they burnt up
    74 CJ5- Cream Puff
  13. #63 Re: Ford Taurus fan..
    Aug 2005
    is there an easy way to test the high/low settings when im at the junkyard?
    Travis
  14. #64 Re: Ford Taurus fan..
    Jan 2005
    bring a car battery with you?
  15. #65 Re: Ford Taurus fan..
    Aug 2005
    i dont think you can
    Travis
  16. #66 Re: Ford Taurus fan..
    Mar 2005
    Valencia, CA
    Quote Originally Posted by CurtP
    Thanks for the tip's,I will move it or grease it up real good.
    jeep pics
  17. #67 Re: Ford Taurus fan..
    New Orleans La.
    Good ol boy.. What are you running now?
    I use a ford starter solinoid ..Works fine for me..
    Off topic.. Hows everything going?? Havent talked to you lately..
  18. #68 Re: Ford Taurus fan..
    Senior Member DCHZJ's Avatar
    Mar 2005
    Leesburg, VA
    Ask them to test it for you. They should without a problem.
    Im not crazy cuz i take the right pills every day
    My Old ZJ
    My Rover
    '74 Land Rover Series III 109 Ex Norwegian Military. Right now the only things holding it together are a few rust gremlins holding hands
  19. #69 Re: Ford Taurus fan..
    Jan 2005
    solenoid or relay? is your solenoid controlling the high continuously?
  20. #70 Re: Ford Taurus fan..
    Nov 2004
    Columbia SC
    Quote Originally Posted by Swamp boy
    i used the ford and it burnt up within a wk....i ended up getting that 20.00 bosche relay that was on that mustang writeup and its triggered on by a cheap hayden temp controller....other than that i am still running that fan..the ZJ doesnt see DD duty any more so it works just fine for me
    what have you been up too, are you back in your house now? I graduated and moved to Columbia SC and moved ol girl with me( talked about a pissed out cajun mom in slidell).....her mom lost it all cause she lived right there on Carr drive right off the old hwy 11 bridge in Slidel= all washed out to lake so she wasnt too happy that i was takin her only kid far away.....other than that everything is good, i hope to get down there again in a few wks and see some folks...i told greddy and midget i would help out with his YJ if i came
    74 CJ5- Cream Puff
  21. #71 Re: Ford Taurus fan..
    Nov 2004
    Columbia SC
    he is not the only having good luck with that, i have seen others also, i may have jsut gotten a crappy one, but mine didnt last long
    74 CJ5- Cream Puff
  22. #72 Re: Ford Taurus fan..
    Jan 2005
    Quote Originally Posted by goodolboy71
    my ford relay only lasted a few months
  23. #73 Re: Ford Taurus fan..
    New Orleans La.
    Mine is on the high side I rarely use it. I have the low side on the temp switch.
    High side
    Low side
    And I am throwing in the cruise control just for shits and giggles.
  24. #74 Re: Ford Taurus fan..
    Hamburg/Germany
    Hi gents,
    since a few days I am lucky to have one of the famous taurus fans on my workbench, shipped from NC to Germany.... Throwing the hardware in the engine bay shouldn´t be a problem but I found three wires coming out of the fan: brown/green - brown/yellow - black.
    As I am not familiar with the US wire colours, does somebody know which one is ground - low - high? Can I assume that black is ground...?
    As an additional feature, I will use the waterpump/pulley out of an XJ to gain a bit more space between waterpump pulley and fan shroud.
    Thanks a lot for your help!
    Frank
    `93 ZJ 4.0
    ...only dead fish go with the flow...
  25. #75 Re: Ford Taurus fan..
    New Orleans La.
    BLack would be ground...
    Then the other two and touch them to the battery and see which makes it turn faster...
    That will be high speed..
    And conversly the one that turns slower will be low speed....
    I think the brown and yellow is high but I have been wrong before...
    The battery is the easiest way to tell without me actually getting up and going outside and looking...
    Since I am one of those lazy americans I am going to suggest the battery method...
    In other words...
    Erwarten Sie uns nicht stumme Amerikaner, alles für Sie zu tun…
    Tun Sie es sich Sie faule Scheiße.
