Well there's really not one here, so why not. I dunno jack about it. How about write ups, pics whatever. Especially pics. I've been dragging my feet with doing this, but I'm kinda forced into it now because I broke my drag link in half. completely in half. Had to leave it on the trail and run to the bone yard to get a replacement. Part numbers would be good too. If we do the first one good, then there'll be no reason for any more that arent specific. I'm interested in looking at highsteers, and everything. What have you done? what do you wish you'd done differently?
I decided on the high output PSCpowersteer TC to P pump conversion to replace my aging pump (http://www.pscpowersteer.com/Perform...gpumpsPSC3.cfm).
Then I decided on full hydro using a ram, Parker orbital valve, 4" short steering column, and clevis mount from WMS (Wagoner Machine Shop - http://www.wagonermachine.com/hydraulic_steering.htm), piped with stainless steel braided hoses and connectors I bought from Jegs and Left Hander Chassis (http://www.lefthanderchassis.com/).
After all that I purchased a Permacool Thin Line tranny cooler with the -6 AN male fittings on it from some random place.
I haven't had time to install it yet, but here's a pic of some of the parts:
Costs so far:
Ram, parker orbital, steering column and clevis: $634
PSC TC to P pump conversion: $429
Fittings and hoses: $380
Tranny cooler: $50
I may have to do some sort of conversion to get rid of my stock air filter box because it looks like the P pump conversion may impede into the stock airbox location a little. I also need to see if the stock steering wheel will work (without the turn signals of course) or if I'll have to purchase a different one.
I'll post more when the job gets started.
I've done Hydro, with and with out histeer, so I can give you a little advise about that....
The best advice I can give you is if you do Full hydro on a 60front, is don't do histeer if you can avoid it. I've broken so many damn knuckles, and replacements are pretty friggen hard to come by. I eventually went with steel replacement knuckles made by TonyK (Off Pirate, can't remember who he sells through but you can PM him over there). With these I could easily weld reinforcements, hi-steerarms, and whatnot to them as opposed to stock cast knuckles.
There also debate over single or double ended rams, I've run both, and I guess the best I can say about that debate is that double ended rams don't seem to bend as easy. For my new rig I'm running Slickrock Offroad rams which can bee seen on www.rockstomper.com (here)
Umm other than that I guess I'd just sugest making sure you WANT full hydro. I wouldnt' suggest it for someone who likes to drive on the streets (or fast like over dunes). You can get used to it, but its still not what I'd call safe. Also I wouldn't worry about getting a setup with return to center. Mine don't have return to center, and its not a bid deal. And I guess thats about the best I can do.
I don't get why it's easier to break knuckles with high steer. I was thinking for now, I may just use 1 ton tierod ends and keep a normal steering setup. I can build the hydro assist off of that. I honestly think I'll be ok keeping it below the knuckle.
It puts a LOT more stress at the top of the knuckle (Especially with a ram) which is the weakest part. Trust me. I didn't think it would be that big of a deal. Everyone is doing it after all. But I broke three knuckles within one year, and as I said they aren't an easy part to come by for replacements.Originally Posted by Trancezj
Hal
Hal,
You say no to hi-steer and full-hydro, what about hydro-assist? Have you heard of anyone breaking D60 knuckles on a regular basis using hydro-assist?
BTW, I'm glad I got a chance to talk to you about your experience with hydro at GSW(wished I would have sooner), cause I think I would have really disliked the Chalupa with full hydro if it actually had worked.
Corey
my gloriously ghetto DIY hi-steer & ram assist:
Tapping the box is cake, I'd HIGHLY suggest hydro-assist. I used a 2x8 ram from northern tool, but I think for the saginaw box, a 1.5x6 or 1.5x8 is probably better. Mine's a little slow.
hi-steer kicks ass, i don't hit half as much crap nowadays, I think it's well worth it and it'll fix a lot of your woes with the Y steering.
As for breaking knuckles, known guys to do it but only when they're running a freakin' 3" spacer under their stering arm.....
I used to say the same thing... If it were me, and I was setting up a full hydro setup, I'd get a good a dual ended ram, and set it up with no tirod at all... I'm just trying to save y'all the hassle I've gone through.Originally Posted by robselina
The Blue ZJ used to be setup with the ram pulling off the stock steering location of the knuckle, and the tierod mounted up high. I broke one knuckle, and then a couple weeks later the other knuckle. After that is when I swapped to a double ended ram with both ends attached at the regular steering points on the knuckle.
The buggy I compete in now has leaf springs so I can't run a double ended ram. So the ram is attached to the high-steer arm, and the tie rod is in the stock location. At the last comp I broke the knuckle the ram was attached to, so obviously this setup wasn't any better.
Now I was using FORD knuckles on both of these rigs, and I've heard that Ford knuckles are a bit weaker than Chevy knuckles so that coule be the problem, but regardless its a bitch to track down knuckles as spares, and its a Double Bitch to try and weld up the knuckle on the trail when you have no spare (And then nurse it slowly out), or a Triple BITCH to try and drive the rig up on the trailer when the knuckle has broken completly off, along with the wheel and tire. All of which I've had to do and this was three sperate occasions. So again it's my opinion, but I will never run hi-steer again... I guess it's like people who run stock axle shafts, and claim to never break them or break them once in a blue moon. You can run it that way, but I wouldn't...
As for hydro-assist, I don't know of anyone who's breaking knuckles with it. I would think steering assist in general would be easier on parts than full hydro, and thus less likely to break things IMO though...
Double-ended rams are a lot harder to protect though unless you're running rockwells in which you can mount the ram behined the tubes.
BTW I don't want you to think I'm picking on you, but why would having your setup save you from hitting stuff? Now you have a ram where your tirod was? I'd rather hit my tierod than the ram simply because a slight bend in a ram will screw it up (hard to steer, heat the fluid quickly, etc.)Originally Posted by robselina
Most people who mount double ended rams build a plate to sit the ram on, and a basher bar in front of it to protect the ram. It doesn't sick out as much as it sounds when I describe it. I cant try and find a pic if you want...Originally Posted by Troy
I understand the double-ram mount and protection but send me a pic of a low-profile one if you have one handy. I agree with your post to robselina... he definitely needs a skid to protect his ram.Originally Posted by ROKN ZJ
I can't find a good small one. Most of the comp guys use theirs kinda like a skid:Originally Posted by Troy
So I guess thats not exactly a low profile setup.
There's a couple other setups in this thread which are about as low profile as you can probably get...
http://www.pirate4x4.com/forum/showt...ge=1&pp=25
Hysteer version. Personally I will not be going hysteer for the reasons Rokn stated. But this system moves 45 in Terra tires around. Those tires have more tractio in mud than most tires have on slickrock...lol. Never broken knuckles....
I decided to go with histeer on my dana 44. I have to snap more pics but I have not yet bought camera. Dana44 from a 77 Ford F150, high pinion.
Here is the recipe I used and what I paid:
Mid 70s Chevy 1/2 ton flattop knuckles, both sides milled = $100
Brand new Spicer ball joints = $80
Mid 70's Chevy small bearing spindles = $60
Mid 70's Chevy Caliper bracket (2 types, make sure to check this) = free
'76 Chevy 1/2 ton Disc brake calipers = $60 remanufactured and loaded.
'77 Ford F150 disc brake rotor and hub assembly = Inlcuded with axle
Partsmike offset Histeer arms = $218
6 feet 1.375"x.188" DOM tubing = $60
Poly Performance tube inserts (having issues with them) = $60
Chevy Blazer TRES (2233L, etc) = $150
Everything fits together great except for the Tube Inserts. Even before I welded them they did not fully thread, however I stupidly didn't really pay attention and welded them anyways. Now I need to tap them to get the toe into the range I need.
Pic is dark but there's a 1/4" skid under the ram that comes up at a 45 degree angle. The ram is well protected.Originally Posted by Troy
As for hitting stuff, my usual sin was trying to climb a ledge, loosing traction and falling straight on the damn tie rod. I don't do that anymore :lol:
BTW TonyK over at the pirate4x4.com is the pro driver for rockequipment.com. They run a few buggies at the professional level. You can check out his site www.rockequipment.com. I'm running their super knuckles for the D44 with their hydro system. The ram they use is the one that comes on a stock 'vette from the factory. Pretty nice little part. It has a TRE on one side which is on the axle side. I'll have some photos for you guys of my setup in a little while.
Ty
I run hydro assist, and I moved my tie rod from the bottom to the top of the knuckle. It only moved it about 1.5", but i don't hit it that often--and my tie rod is super beefy so I don't really worry about it. You can get the hydro assist ram and fittings/lines from Rock Logic for like $220. Not a bad deal.
Hydro assist is sweet BTW.
those were 42's I climbed to get to the windshield
another
When I go to a buggy, I'm not sure what I'll do for steering. Full Hydro is the best for rock crawling, but I like to baja too and race around the dunes like a madman. Most people who drive 75+ on twisty dirt roads don't seem to think that full hydro is the best steering setup.
Cody
What about non hydro steering, what would you guys recommend. I cant afford 1000 bucks. I am looking for around 500, currie, poison spyder??? any ideas?
Make your own. Hopefully Nbaldwin will post up some pictures of his setup.
He made it. And was way less than 500.
Go get some heavy Dom and buy some Tube adapters from Blue Torch Fab for TRE and just cust and paste man. YOU CAN DO IT!
Non hydro steering? Who would wheel with such a thing?Originally Posted by wkbrdr03
I still think a shop could build you a normal 't' style steering setup for less than 500.
However, if you're set on making a shitty steering setup more HD, then I would go with the currie kit.
Cody
Originally Posted by Alaska ZJ
Dammit, why must you always plant these ideas in my head
:shock:
And why do you insist on choosing avatars which mesmerize me :x
lol- i built my sterring for 70$- lol
cut off the pitman arm tierod, adjuster and threaded end-
drilled out the kunckles to 3/4" straight hole
bought 2 rh thread 3/4" heim's and 1 lh thread with 2 jam nuts each
10 ft of sceduele 40 tubing from home depot
some 3/4 hardware
welded it all up-
lmao- its the bigest pos ive ever seen- but the truck is onthe road and running- my friend when under the jeep and kicked the tierod and bent it- lmao-
tommorow-
buying 1 1/2" .250 wall dom
some real threaded bungs
some 3/4" drilled tabs
and doing my sterring right-
it will be overly stout to make up for the shitty prototype i did- lol
Nothing wrong with a shitty prototype as long as you recognize it as such. For a first timer that is actually kinda smart. Build it out of cheap materials and get the design how you like it and then go get the more expensive materials and do it up right.
A little more expensive overall but a good learning and insurance policy with something as serious as a steering system.
I'm scared of strong steering. The way my heap has been, the tie rod would bend before the box ripped off. Now, you'd be hard pressed to bend my tierod with a BFH. I should proll address that issue. Damnit, the exspenses keep pilling up.Originally Posted by Alaska ZJ
