Thread: Tuna Boat
Page 3 of 54 FirstFirst 1234567891011121353 ... LastLast
Results 51 to 75 of 1348
  1. #51 Re: Tuna Boat
    Have to make time in your life for hobbys.
  2. #52 Re: Tuna Boat
  3. #53 Re: Tuna Boat
    2nd floor Yuma, AZ motel
    looking good, what are you doing with the headlights?
  4. #54 Re: Tuna Boat
    Some Pro Comp square lights (Alah Cody Style) and some LED turn and side marker signals.
    Chad
  5. #55 Re: Tuna Boat
    Salt Lake City
    Quote Originally Posted by chadjans
    thats kind of a sad perspective.
    I try and find time between hobbies for life.
    Cody
  6. #56 Re: Tuna Boat
    Jan 2005
    Wherever the Navy needs me
    Looks awesome. Don't know what else to say.
  7. #57 Re: Tuna Boat
    looking good man.
  8. #58 Re: Tuna Boat
    cool.
    do your self a favour and run new wires for the turn signals and head lights. unless you plan on runnign 2 turn signals. per side. i didn't do that originaly and the open bulbs woudl not draw enoguh to trip my flasher.
  9. #59 Re: Tuna Boat
  10. #60 Re: Tuna Boat
  11. #61 Re: Tuna Boat
    First weekend in November progress: http://wheelingarizona.com/forums/vi...=5977&start=50
    Chad
  12. #62 Re: Tuna Boat
    Austin,Tx
    looks really good, cant wait to see how your headlights worked out
  13. #63 Re: Tuna Boat
    Got the steering wheel installed. Can't decide if I want to go with round headlights or square lights.
    http://wheelingarizona.com/forums/vi...=asc&highlight=
    Chad
  14. #64 Re: Tuna Boat
    Trimmed out the support behind the front tires. Now I think I need to trim the arched piece. Might wait and see what hits with the new tires. Also trimmed the OE brackets and cleaned up the front 60. Found here: http://wheelingarizona.com/forums/vi...?p=50405#50405
    I'd put my 20 bucks for MC to use but there is a picture size limit, so you'll have to go to my local group board for pics.
    Chad
  15. #65 Re: Tuna Boat
    Picture test:
  16. #66 Re: Tuna Boat
    Found some shifters for the hand throttle, found some new headlights and bought a new steering arm and drag link. Drag link came from Station on pirate and the arm is a rock stomper product.
    Chad
  17. #67 Re: Tuna Boat
    sweet.
    you definatly need to trim the rest of that a pillar support. There is alot of room to be had in htere.
  18. #68 Re: Tuna Boat
    Front head light conversion, hand throttle and tied the roof into the cage. Ordered the new seats should be here anyday now.
    Chad
  19. #69 Re: Tuna Boat
    i liek those lights. The roof ty in looks kinda sketchy to me. IS there a plate on the other side? I kwo its not suposed to be a super structural cage moutn but still. That thin sheet metal will eventually tear away from that, over time the roof will flex enough to fatigue on the corners of that plate. I would have used something round to weld to the roof. At least it makes it harder for a crack or tear to form.
  20. #70 Re: Tuna Boat
    It is just there to keep the roof from flaping around in the wind. Not structural at all.
    Chad
  21. #71 Re: Tuna Boat
    I don't know what you are talking about. These unit bodies are supper strong and don't move around at all with a cage. Duh.
    Chad
  22. #72 Re: Tuna Boat
    Got the front turn signal harnesses done. The ground on the rear running lamps becoming disconnected accidently threw me for a loop. Thought the new bulbs I am using wouldn't work. Ended up removing the factory splices to simplify the wiring and shortened it up a bit. They turned out really nice. Also had to add a ground wire since the new housings are self grounded.
    Chad
  23. #73 Re: Tuna Boat
    Mounted the front turn signals. Having ground fault issues. Keep tripping fuses. But hey they are mounted. Made 12 tabs and welded them on.
    Chad
  24. #74 Re: Tuna Boat
    i used those lights and found that they did not provide enough resistance to trip my breaker for the blinker.
  25. #75 Re: Tuna Boat
    They worked before I hard mounted them and introduced my ground fault issues. Two of the three bulbs are the same size as the OEM setup. Just the major turn blink bulb is smaller. I am thinking I may have to go with the two bulb version of the same housing of this light. You use the single or two bulb versions?
    Chad
There are currently 5 users browsing this thread. (0 members and 5 guests)
